July 8, 201313 yr I just bought new 3tb wd green hdd and got errors when preclearing. here are the screen details ================================================================== 1.13 = unRAID server Pre-Clear disk /dev/sdi = cycle 1 of 3, partition start on sector 1 = Disk Pre-Clear-Read completed DONE = Step 1 of 10 - Copying zeros to first 2048k bytes DONE = Step 2 of 10 - Copying zeros to remainder of disk to clear it DONE = Step 3 of 10 - Disk is now cleared from MBR onward. DONE = Step 4 of 10 - Clearing MBR bytes for partition 2,3 & 4 DONE = Step 5 of 10 - Clearing MBR code area DONE = Step 6 of 10 - Setting MBR signature bytes DONE = Step 7 of 10 - Setting partition 1 to precleared state DONE = Step 8 of 10 - Notifying kernel we changed the partitioning DONE = Step 9 of 10 - Creating the /dev/disk/by* entries DONE = Step 10 of 10 - Verifying if the MBR is cleared. DONE = Elapsed Time: 13:52:59 ========================================================================1.13 == == SORRY: Disk /dev/sdi MBR could NOT be precleared == == out4= 00000 == out5= 00000 ============================================================================ 0+0 records in 0+0 records out 0 bytes (0 B) copied0000000 , 4.2438e-05 s, 0.0 kB/s this are some of the syslog. Jul 8 05:12:49 Tower kernel: sd 9:0:0:0: [sdi] Unhandled error code (Errors) Jul 8 05:12:49 Tower kernel: sd 9:0:0:0: [sdi] (Drive related) Jul 8 05:12:49 Tower kernel: Result: hostbyte=0x04 driverbyte=0x00 (System) Jul 8 05:12:49 Tower kernel: sd 9:0:0:0: [sdi] CDB: (Drive related) Jul 8 05:12:49 Tower kernel: cdb[0]=0x8a: 8a 00 00 00 00 00 e8 83 ce c8 00 00 04 00 00 00 Jul 8 05:12:49 Tower kernel: sd 9:0:0:0: [sdi] Unhandled error code (Errors) Jul 8 05:12:49 Tower kernel: sd 9:0:0:0: [sdi] (Drive related) Jul 8 05:12:49 Tower kernel: Result: hostbyte=0x04 driverbyte=0x00 (System) Jul 8 05:12:49 Tower kernel: sd 9:0:0:0: [sdi] CDB: (Drive related) Jul 8 05:12:49 Tower kernel: cdb[0]=0x8a: 8a 00 00 00 00 00 e8 83 d2 c8 00 00 04 00 00 00 Jul 8 05:12:49 Tower kernel: sd 9:0:0:0: [sdi] Unhandled error code (Errors) Jul 8 05:12:49 Tower kernel: sd 9:0:0:0: [sdi] (Drive related) Jul 8 05:12:49 Tower kernel: Result: hostbyte=0x04 driverbyte=0x00 (System) Jul 8 05:12:49 Tower kernel: sd 9:0:0:0: [sdi] CDB: (Drive related) Jul 8 05:12:49 Tower kernel: cdb[0]=0x8a: 8a 00 00 00 00 00 e8 83 d6 c8 00 00 04 00 00 00 Jul 8 05:12:49 Tower kernel: sd 9:0:0:0: [sdi] Unhandled error code (Errors) Jul 8 05:12:49 Tower kernel: sd 9:0:0:0: [sdi] (Drive related) Jul 8 05:12:49 Tower kernel: Result: hostbyte=0x04 driverbyte=0x00 (System) Jul 8 05:12:49 Tower kernel: sd 9:0:0:0: [sdi] CDB: (Drive related) Jul 8 05:12:49 Tower kernel: cdb[0]=0x8a: 8a 00 00 00 00 00 e8 83 da c8 00 00 04 00 00 00 Jul 8 05:12:49 Tower kernel: sd 9:0:0:0: [sdi] Unhandled error code (Errors) Jul 8 05:12:49 Tower kernel: sd 9:0:0:0: [sdi] (Drive related) Jul 8 05:12:49 Tower kernel: Result: hostbyte=0x04 driverbyte=0x00 (System) Jul 8 05:12:49 Tower kernel: sd 9:0:0:0: [sdi] CDB: (Drive related) Jul 8 05:12:49 Tower kernel: cdb[0]=0x8a: 8a 00 00 00 00 00 e8 83 de c8 00 00 04 00 00 00 Jul 8 05:12:49 Tower kernel: sd 9:0:0:0: [sdi] Unhandled error code (Errors) Jul 8 05:12:49 Tower kernel: sd 9:0:0:0: [sdi] (Drive related) Jul 8 05:12:49 Tower kernel: Result: hostbyte=0x04 driverbyte=0x00 (System) Jul 8 05:12:49 Tower kernel: sd 9:0:0:0: [sdi] CDB: (Drive related) Jul 8 05:12:49 Tower kernel: cdb[0]=0x8a: 8a 00 00 00 00 00 e8 83 e2 c8 00 00 04 00 00 00 Jul 8 05:12:49 Tower kernel: sd 9:0:0:0: [sdi] Unhandled error code (Errors) Jul 8 05:12:49 Tower kernel: sd 9:0:0:0: [sdi] (Drive related) Jul 8 05:12:49 Tower kernel: Result: hostbyte=0x04 driverbyte=0x00 (System) Jul 8 05:12:49 Tower kernel: sd 9:0:0:0: [sdi] CDB: (Drive related) Jul 8 05:12:49 Tower kernel: cdb[0]=0x8a: 8a 00 00 00 00 00 e8 83 e6 c8 00 00 04 00 00 00 What is the problem? What should I do? Thanks.
July 8, 201313 yr Author Anybody? Do I need to provide more information? Any links for self trouble shoot? THanks.
July 9, 201313 yr Quick searching around indicates that Result: hostbyte=0x04 means the drive went offline. I would check connections, cables, etc. If all checks out oki i would get that drive exchanged.
July 9, 201313 yr Quick searching around indicates that Result: hostbyte=0x04 means the drive went offline. I would check connections, cables, etc. If all checks out oki i would get that drive exchanged. I agree. Check cabling first and any power splitters, etc.
July 14, 201313 yr Author Quick searching around indicates that Result: hostbyte=0x04 means the drive went offline. I would check connections, cables, etc. If all checks out oki i would get that drive exchanged. I agree. Check cabling first and any power splitters, etc. Thank you. The hdd slot that I use have been used before to successfully preclear another drive(later, ive decided not to use the drive, hence the slot still empty). Most likely, cable and connection might not be the problem. To make sure, I preclear on another slot. Got the same error. If you guys still think that this might be connection error, do tell. I have attached syslog file. I have to delete some logs at the end to reduce file size. Please take a look. thanks. syslog.crop.7z.zip
July 14, 201313 yr Quick searching around indicates that Result: hostbyte=0x04 means the drive went offline. I would check connections, cables, etc. If all checks out oki i would get that drive exchanged. I agree. Check cabling first and any power splitters, etc. Thank you. The hdd slot that I use have been used before to successfully preclear another drive(later, ive decided not to use the drive, hence the slot still empty). Most likely, cable and connection might not be the problem. To make sure, I preclear on another slot. Got the same error. If you guys still think that this might be connection error, do tell. I have attached syslog file. I have to delete some logs at the end to reduce file size. Please take a look. thanks. If you've tried the same disk in another slot (with a different SATA and power connection) and it still fails, then yes, you probably have a defective disk. Joe L.
July 14, 201313 yr Author Quick searching around indicates that Result: hostbyte=0x04 means the drive went offline. I would check connections, cables, etc. If all checks out oki i would get that drive exchanged. I agree. Check cabling first and any power splitters, etc. Thank you. The hdd slot that I use have been used before to successfully preclear another drive(later, ive decided not to use the drive, hence the slot still empty). Most likely, cable and connection might not be the problem. To make sure, I preclear on another slot. Got the same error. If you guys still think that this might be connection error, do tell. I have attached syslog file. I have to delete some logs at the end to reduce file size. Please take a look. thanks. If you've tried the same disk in another slot (with a different SATA and power connection) and it still fails, then yes, you probably have a defective disk. Joe L. sigh. What do you guys recommend me to do? Send the drive back to wd for rma? If i do this, I will get a refurbish drive wont I? How reliable is refurbish drive? What would you guys do if you were in my spot? And why? Thanks.
July 14, 201313 yr Can't say without seeing a SMART report. A refurbished drive is likely to perform better than a failed drive.
July 14, 201313 yr If it stills under reseller warranty you might be able to exchange it for a new one otherwise all you can do is RMA
July 14, 201313 yr ...If i do this, I will get a refurbish drive wont I? How reliable is refurbish drive? ...That is what I would expect. However I got a NEW 3TB Green drive when I RMA'd a 2TB Green to Western Digital. So you may get upgraded drive back.
