Jump to content
Help Setting Up A 'Supermirco-AOC-SASLP-MV8' PCI-e card with UnRaid Ver-6.0.1
numpkin
Hi all,
Could someone please help an old newbie in setting up the above please .....
I already have used all my sata ports on the MB and I wish to at a later stage be able to attach more drives ....
Details:
MB: Gigabyte GA-970FXA-UD3, AMD990FX, S AM3+, DDR3, SATA III-6Gb/s, RAID SATA, PCIe2.0(x16), ATX
CPU: AMD FX-6300 Six-Core @ 3500, S AM3+
Mem: 8GB (2x4GB) Corsair DDR3 Vengence Jet Black Low Profile, PC3-12800 (16000), Non-EEC, CAS 9-9-9-24, AXP, 1.5V
Graphics Card: 1GB EVGA G 210, 1200MHz GDDR3, GPU 520MHz, Shader 1238MHz, 16 Cores, D-Sub/ Dual Link DVI-I/ HDMI
A syslog is attached ....
Hope there is enough info here ...
unraid_tower-01-syslog-20150803-1458_w-card.zip
Link to comment
You should just be able to plug one of those cards in and they start working with no special action required.  I have 2 of them in my unRAID server and no special action was required.
What problem are you seeing?  Have you go the correct type of SAS->SATA cables for the card as if you get the wrong type no drives will be recognised.
Link to comment
Hi Squid, itimpi ......
Thanks for quick reply ......... but I think I've got it sorted ......
Must check ALL connections are secure .... I'll go and stand in the corner with "D" hat on ....... and repeat 1000 times
each day for a month "I Must Check All Connections" ........
again thanks Squid, will mark as 'Solved'
Link to comment
  • Create New...
