August 12, 201511 yr Wow, it seems forever since I posted anything on these forums Read a lot, but Unraid has been rock solid for almost 5 years! Well that’s all changed an now it’s time to once again ask the experts So some history, years ago I decided I wanted an amazing storage solution and unraid was it So using an old PC build I built myself a little unraid box Now the hardware it was built upon was already 2+ years old meaning now it’s pushing 7 Saturday I lost connection with the box Thinking it was the key, I replaced that, still no good, thinking it was the router, I replaced that, thinking it was the memory (24 hr memtest proved that wrong) Thinking it was the drives scanned them clean So I think it’s the hardware itself Now I know you guys are the best and I could post logs, and more than likely you could help me find a solution But the hardware is pretty old, so it’s time to update Following the forums over the years I have seen a lot of ideas, builds and everything but could never find one that matches what I need plus it’s been almost 5 years so I have forgotten a ton of UNRAID stuff, hence this post Usage wise: So right now I have a 6 drive unit adding (more has always been the plan but prices still haven’t gotten to pre Thailand flood levels of yester-year.) All I use it for is storage and video streaming, no VMs, servers etc. MI only ever stream to one unit at a time, normally a raspberry Pi HTPC All my vids right now are 1080p, though eventually I may upgrade to 4k stuff (but first I’ll need a new TV) Hardwire wise: What I’m looking for is low power (no reason to go overboard) right now I’m using an old gaming rig so I have a 500W power supply for 6 drives…I think that’s a little excessive, but not sure A nice hot swap case that can be stored in that basement, again right now it’s a standard ATX case: Currently my server sits next to my gaming rig, but I’d like to see it downstairs in a cooler environment and out of sight Everything can be wired to the network, and I’d prefer that Cost I’d like to stay cheap (especially with a new gaming rig in the works) but at the same time quality Thanks in advance for all the suggestions
August 12, 201511 yr I'm no hardware expert, but I have to say that's a great post on your requirements, I'm sure one of the "hardware" guys will be along shortly to help. Might be useful to specify AMD vs Intel and have you given thought to consolidating your hardware, you could potentially run Unraid and your Gaming Rig on the same hardware using a VM, might save a quid or two. Only other thing is whereabouts in the world are you? Some stuff is harder to get outside of the US. Good Luck with your new build and consider posting a build thread for us all to admire.
August 13, 201511 yr Author Thanks So I'm an intel guy from birth, but that's because no one has ever been able to tell me why AMD is better, though I'm always open to seeing the other side of arguments Location wise, I'm in Michigan so I have access to most anything in the world, the US does seem to have the least amount of restrictions
August 13, 201511 yr Michigan also, Looking to upgrade my box as well. Probably best to start your own thread and give details of what you want to do with your box. For instance if you look at my sig you can see how my hardware means I can run VMs (Vt-d support & 32GB RAM) but if you just wanted a basic NAS then you could get by with far more modest hardware.
August 13, 201511 yr Thanks So I'm an intel guy from birth, but that's because no one has ever been able to tell me why AMD is better, though I'm always open to seeing the other side of arguments Location wise, I'm in Michigan so I have access to most anything in the world, the US does seem to have the least amount of restrictions I'm an Intel guy as well pretty much for the same reason and I tend to "understand" their processor naming convention better so just find it easier. How many drives are you looking to have in total (both now and in the future) Hotswap essential or desirable? What form factor mobo and case. My feeling with building I think three or four Unraid machines is that I've never regretted getting hardware with specs better than I need but no getting stuff that can cope with my future uses because it's cheaper I have always regretted. The i5 I think is a good price point between cost and performance. Don't know your home circumstances at the moment but as I've got married and moved house my needs have expanded, and I have found increasing use for my Unraid machine beyond what I initially thought so may be worth bearing in mind..
August 13, 201511 yr Cost I’d like to stay cheap (especially with a new gaming rig in the works) but at the same time quality It sounds like it is too late for you to make a gaming VM instead of having two computers? If you already bought a brand new gaming computer then I would suggest the following: Intel i5 with both VT-x & VT-d (just in case you ever decide to play with VM's (you never know)) 8GB of RAM will due but I would highly recommend 16GB Your 500W power supply seems reasonable If you still have the option of considering building a gaming VM then we can really have some fun, or another thought; if you just built a new gaming computer you could consider making it an unRAID server and then running a Windows VM ontop of that, depending on your PCs specs.
August 14, 201511 yr Author So to try to answer all the questions posed Eventually I see a system with 10 or so drives and two spares on hand But as it is I"m content with what I have now though have been having to "Sophie's Choice" some of my older content in liu of newer stuff Hot swap makes it easier but not essential I do petrabyte storage solutions at work, but those are far more business than what I need at home Case Ideally I'd love to take a server and mount it to the basement ceiling below the router, so horizontal, but I'd love it to stay quiet and cool more than anything I honestly don't see me doing any VM stuff at home so really plans around that are overkill Like I said a raspberry pi is usually my goto streaming device so I'm not overkill when it comes to watching a rerun of Hogan's Heroes on the HTPC haha I haven't built my new gaming rig yet, waiting for the new intels this month so I could do a VM But here's one of the aspects of Unraid I get lost in these days hence me asking you all When I say gaming rig I mean Metal Gear 5, GTA 5, etc I have liked building stand rigs in the past because it may be days or weeks when I don't play games so i keep the behmoths powered down and it saves electicity What are teh benefits of doing a VM?
August 20, 201510 yr Author Looking at new gaming rig parts I started to realize I'd have a bunch of left over parts from my current machine Would a recycled i5 2500K be a good heart to build a new Unraid body around?
August 25, 201510 yr Author So I think I will build a separate gaming rig and server systems Mostly because I need to get the server up and running ASAP...i miss my media As I begin to research this Is there a difference between getting a server motherboard vs standard one? Does the price difference justify it? Also I think, and hence the question an I3 should cover my needs but for those who really push the limits of Unraid, for a rock solid Media Storage System what are the ideal (price vs function) processor families I should be investigating? Because my thinking (and if I'm wrong please correct me) the processor determines the board which determines controllers which determines power supply which in turn determine if I can buy a few more drives when all said and done lol
August 25, 201510 yr You might want to read: http://lime-technology.com/forum/index.php?topic=42436.0 I have to say I'm pretty impressed with the AMD A-series APU, and there's some nice boards with excellent expansion possibilities, and they're cheap. An A8 and board is about the same price as an i3 CPU alone.
August 26, 201510 yr Author So looking at that thread, great info but once we hit AMD land I get a little lost But the gist of it the best chipset for the buck is the A88X http://www.microcenter.com/product/446584/FM2A88X_Killer_FM2_ATX_AMD_Motherboard And the way AMD works if I wanted to have some video output the chip would need a GPU so something like this am I understanding AMD world? http://www.microcenter.com/product/427566/A10_7700K_38_Ghz_Black_Edition_Boxed_processor Locally my microcenter I could get that set for 140 is that a good base?
August 26, 201510 yr So looking at that thread, great info but once we hit AMD land I get a little lost But the gist of it the best chipset for the buck is the A88X http://www.microcenter.com/product/446584/FM2A88X_Killer_FM2_ATX_AMD_Motherboard And the way AMD works if I wanted to have some video output the chip would need a GPU so something like this am I understanding AMD world? http://www.microcenter.com/product/427566/A10_7700K_38_Ghz_Black_Edition_Boxed_processor Locally my microcenter I could get that set for 140 is that a good base? The A4/A6/A8/A10 APUs have a GPU built in. The FM2 Athlons don't. The A-series' GPU can be passed through to a VM, too, which is a massive bonus compared to Intel which can't pass through the iGPU.
August 27, 201510 yr Author So after reading a ton of threads and seeing whatever one here recommends I think I've put this build together I like it because if I gathered everyone's experience right, it will be a rock solid NAS but it has room to grow as a VM/gaming rig if I choose to fiddle with that cool aspect later. All advice, changes, or questions are always a welcomed thing Processor - AMD A10 7700K 3.8 Ghz Black Edition Board - ASRock FM2A88X Killer FM2 RAM - G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBRL Power Supply - I'll carry over my existing Thermaltake 500 for now then later this year i'll go with: SeaSonic M12II 520 Bronze 520W ATX12V v2.3 / EPS 12V v2.91 SLI 80 PLUS BRONZE Certified Full Modular Active PFC Power Supply New Parity Drive (hence the wait on the power supply) - WD Red WD40EFRX 4TB IntelliPower 64MB Cache SATA 6.0Gb/s 3.5" NAS Internal Hard Drive - Bulk Case - I have a Antec 900 that is old but still such a nice case (might splurge and finally get that third drive cage) So what do you guys think Solid? Spending too much? Not enough?
August 27, 201510 yr I'm going to suggest picking a motherboard that allows ECC memory. The nice thing about AMD land is that compatible motherboards can be foudnf or decent prices. In fact "all" ASUS boards (maybe asrock as well) support ECC. The memory itself is not much of a premium but is considered a good idea if you move into virtual land and just good insurance for a data server. See my sig for my build. FWIW, if you want to consider ever passing through your video you will need a stand-alone card. For that reason you might still consider an FX cpu and for now go with a nice cheap PCI video card (http://www.amazon.com/ATI-Rage-8MB-Video-Card/dp/B000G6U2W4). I say PCI because it will leave PCI-e open for SATA card, but if your point is to eventually plug in a more capable video card for gaming then just go with a low end PCI-e card right now. Again, if you want to go gaming in the future, the build-in graphics of the A-series will be wasted unless that problem has been solved by LT and I missed it or I'm conflating two different things (on-board video vs. on-CPU video)
August 28, 201510 yr If that is true, then awesome. Of course they will never hold a candle to a discrete card, but that is then up to the OP to decide of course. My main recommendation, though not often discussed on the boards, is to go with ECC memory where possible and AMD makes that possible on the cheap compared to intel systems (same for full VM support). It just seems like a worthwhile extra layer of protection for our protected arrays.
August 28, 201510 yr If that is true, then awesome. Of course they will never hold a candle to a discrete card, but that is then up to the OP to decide of course. For gaming or other video intense applications (i.e. photoshop?), absolutely. But for a Kodi client, iGPU would work just fine!
August 28, 201510 yr I've been reading that the GPU built into a AX CPU can be passed to a VM...? Where?
August 28, 201510 yr I've been reading that the GPU built into a AX CPU can be passed to a VM...? Where? Here: http://lime-technology.com/forum/index.php?topic=42155.msg404026#msg404026 and here: http://lime-technology.com/forum/index.php?topic=42436.msg403717#msg403717 and here: http://lime-technology.com/forum/index.php?topic=42418.msg403538#msg403538
August 28, 201510 yr I've been reading that the GPU built into a AX CPU can be passed to a VM...? Where? Here: http://lime-technology.com/forum/index.php?topic=42155.msg404026#msg404026 and here: http://lime-technology.com/forum/index.php?topic=42436.msg403717#msg403717 and here: http://lime-technology.com/forum/index.php?topic=42418.msg403538#msg403538 Interesting. Thanks for linking. I honestly have no AMD systems to test with, but that's definitely something worth noting in the docs if it can be consistently proven to work!!
August 28, 201510 yr I honestly have no AMD systems to test with, A minor oversight I'm sure I mean I know you can't have EVERY system iteration out there, but that seems like a chunk to skip [shrug]
September 2, 201510 yr Author So I did it And want to thank everyone this board and the links have been a huge help if not a bit too much information...and when is that a bad thing but now I have a slew of new questions I can't seem to find anywhere on the board (i may not be wording them right) so I'm hopign the help doesn't stop now that I've upgraded lol I ended up with an 830FXe chip An asus M5A99FX board And 8GB of DDR3 ECC Ram So onto my questions My current gaming rig is an i5 2500k, still a great chip but I know from reseach my new unraid CPU is better Also in the current gaming system is a 660TI And 16GB of DDR3 ram It dawned on me after listening to a lot of you Can I take the 660TI and the 16GB and place it in the unraid then make a virtual machine that will be better than the stand alone i have? Answer: It sounds like it But a few noob questions 1) In unraid menu I see how to create a VM, and read the guide, turning that option on, does that affect my shares and setup as it is...will l lose stuff? 2)I have 8GB of ECC DDR3 (it cost a butt load too) is it really better than non-Ecc or can I return it, use that money on a bigger parity drive and use the 16GB and be perfectly happy (Note: at no time will I be watching a movie and using the gaming VM at the same time) 3)So I've given you, the gurus, the specs. Will a VM gaming rig be near identical if not better to the experience we're having now on the existing system 4) I've got a few SSDs for specific games, natural selection 2, civ 5, and defiance (yeah yeah you can judge, but I love the show, and the game is fun...if you like the show haha) can I utilize those in the VM specifically for the gaming slice?
September 2, 201510 yr So I did it And want to thank everyone this board and the links have been a huge help if not a bit too much information...and when is that a bad thing but now I have a slew of new questions I can't seem to find anywhere on the board (i may not be wording them right) so I'm hopign the help doesn't stop now that I've upgraded lol I ended up with an 830FXe chip An asus M5A99FX board And 8GB of DDR3 ECC Ram So onto my questions My current gaming rig is an i5 2500k, still a great chip but I know from reseach my new unraid CPU is better Also in the current gaming system is a 660TI And 16GB of DDR3 ram It dawned on me after listening to a lot of you Can I take the 660TI and the 16GB and place it in the unraid then make a virtual machine that will be better than the stand alone i have? Answer: It sounds like it But a few noob questions 1) In unraid menu I see how to create a VM, and read the guide, turning that option on, does that affect my shares and setup as it is...will l lose stuff? 2)I have 8GB of ECC DDR3 (it cost a butt load too) is it really better than non-Ecc or can I return it, use that money on a bigger parity drive and use the 16GB and be perfectly happy (Note: at no time will I be watching a movie and using the gaming VM at the same time) 3)So I've given you, the gurus, the specs. Will a VM gaming rig be near identical if not better to the experience we're having now on the existing system 4) I've got a few SSDs for specific games, natural selection 2, civ 5, and defiance (yeah yeah you can judge, but I love the show, and the game is fun...if you like the show haha) can I utilize those in the VM specifically for the gaming slice? Personally I'd return the ECC RAM if it's expensive and use what you've already got. I haven't set up a gaming machine in unraid as I'm not a gamer. But I have used other VMs and they don't affect your array. As for swapping SSDs, not sure how I'd go about that but I guess a hotswap bay and unassigned devices plugin (not sure it's V6.1 compatible at the moment though)
September 2, 201510 yr If that 16GB of ram is 2x8GB chips I'd return the ECC ram too. The SSD's can be used, but be warned that they will be formatted for use in unRAID. Frankly, you've got all the parts you need to try this, so why not? Answers to your questions 1) You will not lose stuff. 2) If its 2x8GB then I would. If its 4x4GB I wouldnt. 3) I would expect the same performance when setup properly. Your video card is the bottleneck here. 4) Yes, but they will be wiped when added to unRAID.
