Added a new drive and now it has errors. Process or hardware problem?
Phase 1 - find and verify superblock...
        - block cache size set to 1529832 entries
Phase 2 - using internal log
        - zero log...
zero_log: head block 6724 tail block 6720
ALERT: The filesystem has valuable metadata changes in a log which is being
destroyed because the -L option was used.
        - scan filesystem freespace and inode maps...
sb_fdblocks 21440397, counted 21448589
        - found root inode chunk
Phase 3 - for each AG...
        - scan and clear agi unlinked lists...
        - process known inodes and perform inode discovery...
        - agno = 0
        - agno = 1
        - agno = 2
        - agno = 3
        - process newly discovered inodes...
Phase 4 - check for duplicate blocks...
        - setting up duplicate extent list...
        - check for inodes claiming duplicate blocks...
        - agno = 0
        - agno = 3
        - agno = 2
        - agno = 1
Phase 5 - rebuild AG headers and trees...
        - agno = 0
        - agno = 1
        - agno = 2
        - agno = 3
        - reset superblock...
Phase 6 - check inode connectivity...
        - resetting contents of realtime bitmap and summary inodes
        - traversing filesystem ...
        - agno = 0
        - agno = 1
        - agno = 2
        - agno = 3
        - traversal finished ...
        - moving disconnected inodes to lost+found ...
Phase 7 - verify and correct link counts...
Maximum metadata LSN (1:6722) is ahead of log (1:2).
Format log to cycle 4.
        XFS_REPAIR Summary    Sat Jan 14 09:08:34 2017
Phase          Start          End            Duration
Phase 1:        01/14 09:08:33  01/14 09:08:33
Phase 2:        01/14 09:08:33  01/14 09:08:34  1 second
Phase 3:        01/14 09:08:34  01/14 09:08:34
Phase 4:        01/14 09:08:34  01/14 09:08:34
Phase 5:        01/14 09:08:34  01/14 09:08:34
Phase 6:        01/14 09:08:34  01/14 09:08:34
Phase 7:        01/14 09:08:34  01/14 09:08:34
Total run time: 1 second
I assume that I remount and monitor for errors?
Yes, it should mount now.
Yeah, it is still throwing an error immediately after mounting.
I won't pretend to understand why but it also changes from sdi to sdh
Jan 14 09:14:32 Tower emhttp: SanDisk_SDSSDA120G_162214402015 (sdi) 117220792
Jan 14 09:14:32 Tower kernel: mdcmd (1): import 0 sde 2930266532 0 WDC_WD30EZRX-00MMMB0_WD-WCAWZ2185533
Jan 14 09:14:32 Tower kernel: md: import disk0: (sde) WDC_WD30EZRX-00MMMB0_WD-WCAWZ2185533 size: 2930266532
Jan 14 09:14:32 Tower kernel: mdcmd (2): import 1 sdf 625130776 0 WDC_WD6400AAKS-07A7B0_WD-WCASY1192692
Jan 14 09:14:32 Tower kernel: md: import disk1: (sdf) WDC_WD6400AAKS-07A7B0_WD-WCASY1192692 size: 625130776
Jan 14 09:14:32 Tower kernel: mdcmd (3): import 2 sdb 1953514552 0 WDC_WD20EARS-00J2GB0_WD-WCAYY0190051
Jan 14 09:14:32 Tower kernel: md: import disk2: (sdb) WDC_WD20EARS-00J2GB0_WD-WCAYY0190051 size: 1953514552
Jan 14 09:14:32 Tower kernel: mdcmd (4): import 3 sdd 1953514552 0 WDC_WD20EARS-00MVWB0_WD-WMAZA3921612
Jan 14 09:14:32 Tower kernel: md: import disk3: (sdd) WDC_WD20EARS-00MVWB0_WD-WMAZA3921612 size: 1953514552
Jan 14 09:14:32 Tower kernel: mdcmd (5): import 4 sdg 1465138552 0 WDC_WD15EARS-00S8B1_WD-WCAVY2854733
Jan 14 09:14:32 Tower kernel: md: import disk4: (sdg) WDC_WD15EARS-00S8B1_WD-WCAVY2854733 size: 1465138552
Jan 14 09:14:32 Tower kernel: mdcmd (6): import 5
Jan 14 09:14:32 Tower kernel: mdcmd (7): import 6
Jan 14 09:14:32 Tower kernel: mdcmd (8): import 7
Jan 14 09:14:32 Tower kernel: mdcmd (9): import 8
Jan 14 09:14:32 Tower kernel: mdcmd (10): import 9
Jan 14 09:14:32 Tower kernel: mdcmd (11): import 10
Jan 14 09:14:32 Tower kernel: mdcmd (12): import 11
Jan 14 09:14:32 Tower kernel: mdcmd (13): import 12
Jan 14 09:14:32 Tower kernel: mdcmd (14): import 13
Jan 14 09:14:32 Tower kernel: mdcmd (15): import 14
Jan 14 09:14:32 Tower kernel: mdcmd (16): import 15
Jan 14 09:14:32 Tower kernel: mdcmd (17): import 16
Jan 14 09:14:32 Tower kernel: mdcmd (18): import 17
Jan 14 09:14:32 Tower kernel: mdcmd (19): import 18
Jan 14 09:14:32 Tower kernel: mdcmd (20): import 19
Jan 14 09:14:32 Tower kernel: mdcmd (21): import 20
Jan 14 09:14:32 Tower kernel: mdcmd (22): import 21
Jan 14 09:14:32 Tower kernel: mdcmd (23): import 22
Jan 14 09:14:32 Tower kernel: mdcmd (24): import 23
Jan 14 09:14:32 Tower kernel: mdcmd (25): import 24
Jan 14 09:14:32 Tower kernel: mdcmd (26): import 25
Jan 14 09:14:32 Tower kernel: mdcmd (27): import 26
Jan 14 09:14:32 Tower kernel: mdcmd (28): import 27
Jan 14 09:14:32 Tower kernel: mdcmd (29): import 28
Jan 14 09:14:32 Tower kernel: mdcmd (30): import 29
Jan 14 09:14:32 Tower kernel: md: import_slot: 29 empty
Jan 14 09:14:32 Tower emhttp: import 30 cache device: sdc
Jan 14 09:14:32 Tower emhttp: import flash device: sda
Jan 14 09:14:42 Tower kernel: XFS (sdh1): xfs_log_force: error -5 returned.
Jan 14 09:15:12 Tower kernel: XFS (sdh1): xfs_log_force: error -5 returned.
Post the complete diagnostics
Ok, so I got a brand new syba sy-pex40039 controller and added the script from the forum to make sure unraid plays nice with it.
What is this script you mention? Your controller uses an ASMedia ASM1061, which is directly supported by unRAID. You don't need a script.
Log is after a reboot but everything looks normal.
The script shouldn't cause issues but like John posted it's not needed for the asmedia, so you can remove it.
That thread was started well over four years ago. unRAID has come a long way since then.
Yeah I just rebooted to see if it would help.
It still fails.
Here is another diag.
tower-diagnostics-20170114-1008.zip
Just in case remove the script, reboot and run xfs_repair again, if it still doesn't fix better to format the disk.
It looks like one of my VMs was automatically passed through the SATA controller card.
I presume that starting that VM is possibly causing issues since the card is passed through but also being used by UNRAID?
I just don't understand why this is a thing. Why would anyone want to automatically alter their VM config when a new device is added to the host machine?
Look at your system devices, when there's an hardware change they can swap id's, e.g., you were passing through a NIC that was device 03:00.0 and after changing something it can become 02:00.0, and now 03:00.0 is a controller, so check your VM xml.
Looks like this might be it. My VM no longer has access to the OTA Tuner I had installed. So it must have swapped the tuner card for the sata.
That is a pretty significant issue for someone running multiple VMs.
  • 2 months later...
Well now I am no longer able to pass through the Tuner to the VM. I edited the XML with the correct device information but now I get a "This device cannot start. (Code 10)" in the VM under device manager.
I don't believe how user unfriendly this whole process is....
tower-diagnostics-20170405-10060642.zip
Rebooting the server fixed the issue. But I still don't understand WTF is happening.
It makes no sense (to me) that something that works fine suddenly stops working without any type of material change....
