[SOLVED] Fix Common Problems - FTP Settings = Blank Page
unRaid's built in FTP server is currently disabled, but users are defined	There is a "feature" within 6.1.9 and 6.2 beta 21 where after the server is reset, the FTP server will be automatically re-enabled regardless if you want it to be or not. Remove the users here
Fix Common Problems displays this error message.  When I click on the FTP Settings, I get a blank page - I assume because FTP is already disabled.  I've installed ProFTPd and using that for backups.  Is Fix Common Problems seeing the ProFTPd server and complaining about that?  Or is there some other reason?
Thanks in advance!
Edited by jeffreywhunter
The warning is there because of a feature where you can disable the built-in FTP all day long, but it will always re-enable itself after a reboot.  Go to Settings - FTP and remove the defined users.  No idea how everything reacts with a FTP plugin installed...
IDK how it reacts with ProFTPd installed, but since FTP settings isn't within Network settings anymore, we're getting into the realm of FCP adjusting for plugins modifying system files, and I just don't want to go down that road.   Ignore the error.
