May 8, 20188 yr May 7 11:34:13 HunterNAS cache_dirs: ---------- Caching Directories --------------- May 7 11:34:13 HunterNAS cache_dirs: Dropbox May 7 11:34:13 HunterNAS cache_dirs: FTP May 7 11:34:13 HunterNAS cache_dirs: My Backups May 7 11:34:13 HunterNAS cache_dirs: Pydio May 7 11:34:13 HunterNAS cache_dirs: RawVideoFiles May 7 11:34:13 HunterNAS cache_dirs: appdata May 7 11:34:13 HunterNAS cache_dirs: archives May 7 11:34:13 HunterNAS cache_dirs: cachebackup May 7 11:34:13 HunterNAS cache_dirs: home movies May 7 11:34:13 HunterNAS cache_dirs: jwhbackup May 7 11:34:13 HunterNAS cache_dirs: movies May 7 11:34:13 HunterNAS cache_dirs: music May 7 11:34:13 HunterNAS cache_dirs: pictures May 7 11:34:13 HunterNAS cache_dirs: tv May 7 11:34:13 HunterNAS cache_dirs: web May 7 11:34:13 HunterNAS cache_dirs: ---------------------------------------------- I can't help thinking several of these are unnecessary and wasting memory.
May 8, 20188 yr 18 minutes ago, John_M said: May 7 11:34:13 HunterNAS cache_dirs: ---------- Caching Directories --------------- May 7 11:34:13 HunterNAS cache_dirs: Dropbox May 7 11:34:13 HunterNAS cache_dirs: FTP May 7 11:34:13 HunterNAS cache_dirs: My Backups May 7 11:34:13 HunterNAS cache_dirs: Pydio May 7 11:34:13 HunterNAS cache_dirs: RawVideoFiles May 7 11:34:13 HunterNAS cache_dirs: appdata May 7 11:34:13 HunterNAS cache_dirs: archives May 7 11:34:13 HunterNAS cache_dirs: cachebackup May 7 11:34:13 HunterNAS cache_dirs: home movies May 7 11:34:13 HunterNAS cache_dirs: jwhbackup May 7 11:34:13 HunterNAS cache_dirs: movies May 7 11:34:13 HunterNAS cache_dirs: music May 7 11:34:13 HunterNAS cache_dirs: pictures May 7 11:34:13 HunterNAS cache_dirs: tv May 7 11:34:13 HunterNAS cache_dirs: web May 7 11:34:13 HunterNAS cache_dirs: ---------------------------------------------- I can't help thinking several of these are unnecessary and wasting memory. Are you saying that I should use less shares? each of these are for a specific set of files. Is there a way to calculate how much memory a share takes?
May 8, 20188 yr 24 minutes ago, jeffreywhunter said: Are you saying that I should use less shares? each of these are for a specific set of files. Is there a way to calculate how much memory a share takes? You don't have to include them all in cache-dirs. Do you really often browse all of these and need to be able to see their files listed quickly without spinning up the disk they're on? Have you read the help for cache-dirs (Folder Caching plugin)?
May 8, 20188 yr 21 minutes ago, trurl said: Have you read the help for cache-dirs (Folder Caching plugin)? No, I looked but the only help I see is the Unraid manual at the bottom of the screen.
May 8, 20188 yr You have too many options on the menu bar. No matter, you can get the 'Help' for each entry by hovering over the each item (like "Folder caching function" until the cursor changes to a '?' mark and left-clicking the mouse.
May 8, 20188 yr 1 hour ago, Frank1940 said: You have too many options on the menu bar. No matter, you can get the 'Help' for each entry by hovering over the each item (like "Folder caching function" until the cursor changes to a '?' mark and left-clicking the mouse. Ah, the browser was not wide enough. Found the help. I read through all the help, didn't see anything earth shattering. I did however, 'turn off' about half of the shares (kept, TV, Movies, Pictures, etc). We'll see if any of the backup process choke on the directories without a cache. Is there a way to measure how much memory it takes? I could always put more memory in the system. Could double it if I had to...
May 8, 20188 yr 9 hours ago, jeffreywhunter said: I could always put more memory in the system. Nobody else has these problems and many have much less memory than you already have. I think this below is the most likely cause of your problems. You have something using an incorrect path and it is filling up memory. 14 hours ago, trurl said: Not sure if you know this now but apparently you didn't at one time based on some other posts you had on another thread. Rootfs isn't the flash drive. The flash drive is /boot. Rootfs is RAM. Your FTP issue from that log tail you posted makes me wonder if you aren't filling up RAM with something using an incorrect path somewhere. You shouldn't be using any path that isn't in /mnt/user (or possibly /mnt/disk#, /mnt/cache, or /boot if you know why you're doing it). And depending on how you have your FTP server and clients setup, they might be mapping things in some way you don't understand if you don't understand mapping.
May 8, 20188 yr 2 hours ago, trurl said: Nobody else has these problems and many have much less memory than you already have. I think this below is the most likely cause of your problems. You have something using an incorrect path and it is filling up memory. You shouldn't be using any path that isn't in /mnt/user (or possibly /mnt/disk#, /mnt/cache, or /boot if you know why you're doing it). And depending on how you have your FTP server and clients setup, they might be mapping things in some way you don't understand if you don't understand mapping. I'm pretty sure you are right. The I turned on the transferlog using a path "TransferLog /mnt/user/My Backups/proftpxferlog - which is incorrect, I'm missing the \ - should be TransferLog /mnt/user/My\ Backups/proftpxferlog. Change made, no crashes yet. Fingers crossed.
