tmchow Posted January 5, 2018 Share Posted January 5, 2018 I have the Fix Common Problems plugins installed and it's warned me about call traces and to have the forum advise me. here I am with my logs. Can someone take a look and advise? tower-diagnostics-20180104-2314.zip Link to comment
Squid Posted January 5, 2018 Share Posted January 5, 2018 I have the Fix Common Problems plugins installed and it's warned me about call traces and to have the forum advise me. here I am with my logs. Can someone take a look and advise?tower-diagnostics-20180104-2314.zipOn the 31st there was a timeout on the network, so the driver tossed a call trace and then reconnected . could be as simple as a loose connection. Either way it's nothing to particularly worry about and the driver is probably being over zealous in even putting out a trace in the first place Link to comment
tmchow Posted January 5, 2018 Author Share Posted January 5, 2018 Just now, Squid said: 13 hours ago, tmchow said: I have the Fix Common Problems plugins installed and it's warned me about call traces and to have the forum advise me. here I am with my logs. Can someone take a look and advise?tower-diagnostics-20180104-2314.zip On the 31st there was a timeout on the network, so the driver tossed a call trace and then reconnected . could be as simple as a loose connection. Either way it's nothing to particularly worry about and the driver is probably being over zealous in even putting out a trace in the first place Thank you friend! Link to comment
