wgstarks Posted January 15, 2018 Share Posted January 15, 2018 I set up eth1 as bridge- Enabled dockers. Don't see an option for br1- What did I miss? Link to comment
bonienl Posted January 15, 2018 Share Posted January 15, 2018 Two corrections to make: 1. The interface address can not end on .0. Use for example 10.0.90.2 2. The gateway address must be in the same subnet as the interface. For example 10.0.90.1 (your router must use this IP address) Docker will not create br1 because of the wrong assignments. Link to comment
wgstarks Posted January 15, 2018 Author Share Posted January 15, 2018 Made some changes- Don't think it worked though. Just keeps displaying "Please Wait". Link to comment
bonienl Posted January 15, 2018 Share Posted January 15, 2018 How is your eth0 configured, can you post a screenshot? Link to comment
wgstarks Posted January 15, 2018 Author Share Posted January 15, 2018 6 minutes ago, bonienl said: How is your eth0 configured, can you post a screenshot? Looks like maybe it worked? I was able to select br1 for binhex-deluge and set static IP 10.0.1.200, but now Radarr can't connect to Deluge after entering the new IP in the settings. Both are on br1. Link to comment
bonienl Posted January 15, 2018 Share Posted January 15, 2018 Ok, sounds like progress You need to make sure that both applications themselves are also properly configured and point to the new IP addresses. Link to comment
wgstarks Posted January 15, 2018 Author Share Posted January 15, 2018 They are. I just get an unknown exception timeout when I test the connection. Link to comment
bonienl Posted January 15, 2018 Share Posted January 15, 2018 Can you ping inside one container to the other container or gateway. Eg. From my Tonido container I ping the gateway. docker exec -it Tonido /bin/bash root@9366a668ea9e:/# ping 10.0.105.1 PING 10.0.105.1 (10.0.105.1) 56(84) bytes of data. 64 bytes from 10.0.105.1: icmp_seq=1 ttl=64 time=0.421 ms 64 bytes from 10.0.105.1: icmp_seq=2 ttl=64 time=0.380 ms ^C --- 10.0.105.1 ping statistics --- 2 packets transmitted, 2 received, 0% packet loss, time 1027ms rtt min/avg/max/mdev = 0.380/0.400/0.421/0.028 ms Link to comment
bonienl Posted January 15, 2018 Share Posted January 15, 2018 What is the output of this command? docker network inspect br1 Link to comment
wgstarks Posted January 15, 2018 Author Share Posted January 15, 2018 Last login: Mon Jan 15 18:31:06 2018 from 10.0.1.10 Linux 4.14.13-unRAID. root@Brunnhilde:~# docker exec -it binhex-delugevpn /bin/bash [root@4017a32f33fd /]# ping 10.0.1.2 PING 10.0.1.2 (10.0.1.2) 56(84) bytes of data. 64 bytes from 10.0.1.2: icmp_seq=1 ttl=64 time=0.024 ms 64 bytes from 10.0.1.2: icmp_seq=2 ttl=64 time=0.020 ms 64 bytes from 10.0.1.2: icmp_seq=3 ttl=64 time=0.021 ms 64 bytes from 10.0.1.2: icmp_seq=4 ttl=64 time=0.022 ms ^C --- 10.0.1.2 ping statistics --- 4 packets transmitted, 4 received, 0% packet loss, time 3079ms rtt min/avg/max/mdev = 0.020/0.021/0.024/0.005 ms [root@4017a32f33fd /]# exit exit root@Brunnhilde:~# docker exec -it binhex-radarr /bin/bash [root@25a7af7cd5fd /]# ping 10.0.1.200 PING 10.0.1.200 (10.0.1.200) 56(84) bytes of data. 64 bytes from 10.0.1.200: icmp_seq=1 ttl=64 time=0.022 ms 64 bytes from 10.0.1.200: icmp_seq=2 ttl=64 time=0.021 ms 64 bytes from 10.0.1.200: icmp_seq=3 ttl=64 time=0.018 ms ^C --- 10.0.1.200 ping statistics --- 3 packets transmitted, 3 received, 0% packet loss, time 2062ms rtt min/avg/max/mdev = 0.018/0.020/0.022/0.004 ms [root@25a7af7cd5fd /]# exit exit root@Brunnhilde:~# docker network inspect br1 [ { "Name": "br1", "Id": "45a1955d466afeae1a73fd05e9a79c8cda334b736b6bbb5b9b13578849c12078", "Created": "2018-01-15T17:56:31.380096309-05:00", "Scope": "local", "Driver": "macvlan", "EnableIPv6": false, "IPAM": { "Driver": "default", "Options": {}, "Config": [ { "Subnet": "10.0.1.0/24", "AuxiliaryAddresses": { "server": "10.0.1.21" } } ] }, "Internal": false, "Attachable": false, "Ingress": false, "ConfigFrom": { "Network": "" }, "ConfigOnly": false, "Containers": { "25a7af7cd5fdc1307a73b03e0fc1dd1d7bb25953061c880dda538def0b5ba164": { "Name": "binhex-radarr", "EndpointID": "701ac0e610fc0ab09a686e4f90560b51af09d92eb7ff760c6c40992b1d3cb3ee", "MacAddress": "02:42:0a:00:01:02", "IPv4Address": "10.0.1.2/24", "IPv6Address": "" }, "4017a32f33fd545ef54bc79e2c2b15cf99961aaf74e0bf71afb50c7bdce81a9d": { "Name": "binhex-delugevpn", "EndpointID": "92c8dd4a949387faea8740878788c46d6972698797760a9918ca132abb4787d7", "MacAddress": "02:42:0a:00:01:c8", "IPv4Address": "10.0.1.200/24", "IPv6Address": "" }, "67d3959e78a196f780448f6119a7b580cfd2db464485fd3083a45687f88644f0": { "Name": "binhex-sonarr", "EndpointID": "6e8c0cc0800e513d4c3dce429304d0b29abdac1064c8b5a013e2af2082bb20c5", "MacAddress": "02:42:0a:00:01:03", "IPv4Address": "10.0.1.3/24", "IPv6Address": "" } }, "Options": { "parent": "br1" }, "Labels": {} } ] root@Brunnhilde:~# No problems with the pings in both directions. Link to comment
bonienl Posted January 15, 2018 Share Posted January 15, 2018 1 minute ago, wgstarks said: No problems with the pings in both directions. I don't use these containers myself, but your network connectivity is in place. Double-check if there no duplicate IP addresses (10.0.1.2, 10.0.1.3 and 10.0.1.200 not accidentally used by another device in your network) If the above is okay, it has to be something in the settings of the applications. Link to comment
wgstarks Posted January 17, 2018 Author Share Posted January 17, 2018 I disabled bridging last night and now can't get it back. I believe everything is set as before. network.cfg- # Generated settings: IFNAME[0]="eth0" DHCP_KEEPRESOLV="no" DNS_SERVER1="10.0.1.1" DHCP6_KEEPRESOLV="no" DESCRIPTION[0]="" PROTOCOL[0]="" USE_DHCP[0]="yes" IPADDR[0]="10.0.1.20" NETMASK[0]="255.255.255.0" GATEWAY[0]="10.0.1.1" METRIC[0]="211" USE_DHCP6[0]="" IPADDR6[0]="" NETMASK6[0]="" GATEWAY6[0]="" PRIVACY6[0]="" MTU[0]="" IFNAME[1]="br1" BRNAME[1]="br1" BRSTP[1]="no" BRFD[1]="0" BRNICS[1]="eth1" DESCRIPTION[1]="" PROTOCOL[1]="ipv4" USE_DHCP[1]="yes" METRIC[1]="" USE_DHCP6[1]="" MTU[1]="" SYSNICS="2" Checking br1 I get this- Linux 4.14.13-unRAID. root@Brunnhilde:~# docker network inspect br1 [] Error: No such network: br1 root@Brunnhilde:~# I even tried rebooting. Did I miss something? brunnhilde-diagnostics-20180116-1908.zip Link to comment
wgstarks Posted January 17, 2018 Author Share Posted January 17, 2018 Follow up: br1 is available in docker settings. I can and have set a custom range of IP addresses. I just don’t have the option available to set br1 in any of my docker templates. Link to comment
bonienl Posted January 17, 2018 Share Posted January 17, 2018 Sounds like Docker got out of sync. Use the below to let Docker rebuild all networks rm /var/lib/docker/network/files/local-kv.db /etc/rc.d/rc.docker restart Link to comment
wgstarks Posted January 18, 2018 Author Share Posted January 18, 2018 20 hours ago, bonienl said: Sounds like Docker got out of sync. Use the below to let Docker rebuild all networks rm /var/lib/docker/network/files/local-kv.db /etc/rc.d/rc.docker restart No luck there- Linux 4.14.13-unRAID. Last login: Thu Jan 18 10:52:53 -0500 2018 on /dev/pts/0. root@Brunnhilde:~# rm /var/lib/docker/network/files/local-kv.db rm: cannot remove '/var/lib/docker/network/files/local-kv.db': No such file or directory root@Brunnhilde:~# Link to comment
bonienl Posted January 18, 2018 Share Posted January 18, 2018 You need to start docker service first Link to comment
wgstarks Posted January 18, 2018 Author Share Posted January 18, 2018 Got it. Thanks. Worked this time. Link to comment
