francrouge Posted January 22, 2018 Share Posted January 22, 2018 Hi all I'm getting error on a 8TB hdd since i upgrade to unraid 6.4. ST8000DM004-2CX188_WG800MSE - 8 TB (sdc) 1935 errors I 'm not able to do smart test in unraid i got an error message. exiting. To continue, add one or more '-T permissive' options. Can someone tell me what to do please Thx nas-diagnostics-20180121-1918.zip Link to comment
francrouge Posted January 22, 2018 Author Share Posted January 22, 2018 * Update * I just reboot the server to see if it would solved but now the hdd is not there anymore. Link to comment
Maticks Posted January 22, 2018 Share Posted January 22, 2018 new things to check power down the server and check the SATA Data cable is connected. If you have a spare SATA data cable try replacing it. If you are using a Marvel SATA controller on your motherboard try using one of the other SATA ports. If you have ACS enabled in your VM Manager under settings try turning that off you can have IO MMU group issues cause data problems. I have had issues with ACS on and data errors across several drives. Link to comment
francrouge Posted January 22, 2018 Author Share Posted January 22, 2018 Hi again I just checked and i dont have the acs unable. ok So i swap my 8tb and installed one of my 3tb wich is alreasy in the array. I boot the server and unraid tell me that the 3tb is good and he is seeing my 8TB like a new drive .. I did a short smart test on the 8TB. Extended test is on his way But how the "/"$% the drive is working if my 3 tb works in the same slot the 8 was. nas-smart-20180121-2020.zip Link to comment
Maticks Posted January 22, 2018 Share Posted January 22, 2018 maybe the sata cable was loose.. that is the only explanation. Link to comment
francrouge Posted January 22, 2018 Author Share Posted January 22, 2018 Weird but the hdd is now been seeing like a new one. What is the next step ? Should i do a parity check ? thx Link to comment
JorgeB Posted January 22, 2018 Share Posted January 22, 2018 You need to rebuild the disable disk, either to the old or to a new disk, new disk would be safer in case there's a problem with another disk during the rebuild, if you use the old disk check that the contents of the emulated disk look correct since whatever is there is what is going to be on the rebuilt disk. Link to comment
francrouge Posted January 22, 2018 Author Share Posted January 22, 2018 12 minutes ago, johnnie.black said: You need to rebuild the disable disk, either to the old or to a new disk, new disk would be safer in case there's a problem with another disk during the rebuild, if you use the old disk check that the contents of the emulated disk look correct since whatever is there is what is going to be on the rebuilt disk. Hi Ok I will do that. But I was wondering if my problem could be related because i upgrade to 6.4 few days ago ? I'm seeing people on the forum with the same problem. thx Link to comment
JorgeB Posted January 22, 2018 Share Posted January 22, 2018 Upgrade won't disable disks. Link to comment
francrouge Posted January 22, 2018 Author Share Posted January 22, 2018 56 minutes ago, johnnie.black said: Upgrade won't disable disks. ok So what can make it disable. For exemple in my case i think it is the sata cable that was maybe loose. Do you think it could do this type of error Link to comment
JorgeB Posted January 22, 2018 Share Posted January 22, 2018 4 minutes ago, francrouge said: ok So what can make it disable. For exemple in my case i think it is the sata cable that was maybe loose. Do you think it could do this type of error Yes, the error is consistent with a bad cable, you should replace them to rule them out. Link to comment
francrouge Posted January 22, 2018 Author Share Posted January 22, 2018 7 minutes ago, johnnie.black said: Yes, the error is consistent with a bad cable, you should replace them to rule them out. cool thx Link to comment
