WorriedAboutDataLoss Posted August 1, 2018 Share Posted August 1, 2018 So - had a disk fail (disk2) few days back and the contents of the disk were in emulated mode. Yesterday had a power failure and now server needs to do a parity check due to unclean shutdown. What should my steps be so I don't lose any data? I've already received a replacement disk and can install it to be rebuilt but I wanted to make sure I follow the proper steps! Thanks in advance! Link to comment
Vr2Io Posted August 1, 2018 Share Posted August 1, 2018 @WorriedAboutDataLoss <-- , If not running 2 parity drive, no need to perform parity check, just rebuild ASAP. Except emulated disk file system not mountable or sample file read check on this disk fail. Link to comment
WorriedAboutDataLoss Posted August 2, 2018 Author Share Posted August 2, 2018 Thanks Benson but how do I start the array without doing a parity check since it was an unclean shutdown? Link to comment
Vr2Io Posted August 2, 2018 Share Posted August 2, 2018 Just insert replacement disk, start array and stop parity check. Link to comment
WorriedAboutDataLoss Posted August 2, 2018 Author Share Posted August 2, 2018 @Benson - Thanks - That did it! Data rebuild is in progress. Hopefully there will be no issues! Link to comment
WorriedAboutDataLoss Posted August 3, 2018 Author Share Posted August 3, 2018 All is well now! Thanks again! Link to comment
