nmacle01 Posted December 28, 2018 Share Posted December 28, 2018 Hello, I recently upgraded (or, rather, replaced) my unRAID machine and ever since I've had a weird problem where it appears the network isn't initialized in order for Unassigned Devices to auto-mount an NFS share. I never had any issues with this working in the past... Dec 26 11:58:03 N12345 unassigned.devices: Error: Remote SMB/NFS server '192.168.1.251' is offline and share '192.168.1.251://export/Backups' cannot be mounted. Dec 26 11:58:03 N12345 emhttpd: Starting services... Dec 26 11:58:03 N12345 emhttpd: nothing to sync Dec 26 11:58:03 N12345 sudo: root : TTY=unknown ; PWD=/ ; USER=nobody ; COMMAND=/bin/bash -c /usr/local/emhttp/plugins/unbalance/unbalance -port 6237 .. .. .. Dec 26 11:59:12 N12345 unassigned.devices: Mount SMB/NFS command: mount -t nfs -o defaults '192.168.1.251://export/Backups' '/mnt/disks/OMV-RPi2_Backups' Dec 26 11:59:12 N12345 unassigned.devices: Successfully mounted '192.168.1.251://export/Backups' on '/mnt/disks/OMV-RPi2_Backups'. Dec 26 11:59:12 N12345 unassigned.devices: Defining share 'OMV-RPi2_Backups' with file '/etc/samba/unassigned-shares/OMV-RPi2_Backups.conf' Dec 26 11:59:12 N12345 unassigned.devices: Adding share 'OMV-RPi2_Backups' to '/boot/config/smb-extra.conf' Dec 26 11:59:12 N12345 unassigned.devices: Reloading Samba configuration... Dec 26 11:59:12 N12345 unassigned.devices: Directory '/mnt/disks/OMV-RPi2_Backups' shared successfully. As you can see, it says the remote server is offline and the share is not accessible. But just 1 minute later I can successfully mount the share manually. Any advice on how to further troubleshoot this?? For reference, the new [relevant] hardware is: Supermicro X11SSM-F (only using one of the ports on the dual-NIC, and the second is disabled via jumper), Intel Xeon E3-1230 V6, Supermicro AOC-SAS2LP-MV8, and Dell PERC H310. Thank you! Neil Link to comment
Frank1940 Posted December 29, 2018 Share Posted December 29, 2018 Since no one has responded to your post, I thought I might suggest that you post an inquiry in the support thread for the Unassigned Devices Plugin. Link to comment
trurl Posted December 29, 2018 Share Posted December 29, 2018 Since you have taken it to the UD support thread, I am locking this one so nobody will waste further time on it. Link to comment
