February 16, 20197 yr Help got up and running registered trial but when i power down or reboot the guid is changing some times so no my key is invalid. anyone any idea how to solve this?
February 16, 20197 yr Community Expert 6 minutes ago, turnipisum said: Help got up and running registered trial but when i power down or reboot the guid is changing some times so no my key is invalid. anyone any idea how to solve this? The GUID is meant to be fixed at the hardware level so no idea how it can be changing.
February 16, 20197 yr Author That's what i thought 🤷♂️ ok if i just reboot it seems to keep guid but when i do full power down it changes the guid!
February 16, 20197 yr 5 minutes ago, turnipisum said: ok if i just reboot it seems to keep guid but when i do full power down it changes the guid! Show screen shots, diagnostics, etc.
February 16, 20197 yr Just some simple things to ask? Do you have more than one USB plugged in called Unraid? Not using a USB to SD card reader or anything weird like that? Are you using a reputable brand of USB stick?
February 16, 20197 yr Author What screen shots would help? i have one usb direct into motherboard port via 1ft usb extension, no other usb devices plugged in. it's kingston usb 2 32gb stick.
February 16, 20197 yr Go to Tools - Diagnostics and attach the complete diagnostics zip file to your next post.
February 16, 20197 yr Author ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300) Feb 16 19:16:59 SKYNET-UR kernel: ACPI BIOS Error (bug): Could not resolve [\_SB.PCI0.SAT0.SPT1._GTF.DSSP], AE_NOT_FOUND (20180531/psargs-330) Feb 16 19:16:59 SKYNET-UR kernel: ACPI Error: Method parse/execution failed \_SB.PCI0.SAT0.SPT1._GTF, AE_NOT_FOUND (20180531/psparse-516) Feb 16 19:16:59 SKYNET-UR kernel: ata2.00: ATA-10: KINGSTON SA400S37480G, 50026B77826C65E5, SBFKB1C2, max UDMA/133 Feb 16 19:16:59 SKYNET-UR kernel: ata2.00: 937703088 sectors, multi 1: LBA48 NCQ (depth 32), AA Feb 16 19:16:59 SKYNET-UR kernel: ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300) Feb 16 19:16:59 SKYNET-UR kernel: ACPI BIOS Error (bug): Could not resolve [\_SB.PCI0.SAT0.SPT1._GTF.DSSP], AE_NOT_FOUND (20180531/psargs-330) Feb 16 19:16:59 SKYNET-UR kernel: ACPI Error: Method parse/execution failed \_SB.PCI0.SAT0.SPT1._GTF, AE_NOT_FOUND (20180531/psparse-516) Feb 16 19:16:59 SKYNET-UR kernel: ata2.00: configured for UDMA/133 Feb 16 19:16:59 SKYNET-UR kernel: ACPI BIOS Error (bug): Could not resolve [\_SB.PCI0.SAT0.SPT0._GTF.DSSP], AE_NOT_FOUND (20180531/psargs-330) Feb 16 19:16:59 SKYNET-UR kernel: ACPI Error: Method parse/execution failed \_SB.PCI0.SAT0.SPT0._GTF, AE_NOT_FOUND (20180531/psparse-516) Feb 16 19:16:59 SKYNET-UR kernel: ata1.00: ATA-10: ST4000VN008-2DR166, ZDH5L6MN, SC60, max UDMA/133 Feb 16 19:16:59 SKYNET-UR kernel: ata1.00: 7814037168 sectors, multi 16: LBA48 NCQ (depth 32), AA Feb 16 19:16:59 SKYNET-UR kernel: ACPI BIOS Error (bug): Could not resolve [\_SB.PCI0.SAT0.SPT0._GTF.DSSP], AE_NOT_FOUND (20180531/psargs-330) Feb 16 19:16:59 SKYNET-UR kernel: ACPI Error: Method parse/execution failed \_SB.PCI0.SAT0.SPT0._GTF, AE_NOT_FOUND (20180531/psparse-516) Feb 16 19:16:59 SKYNET-UR kernel: ata1.00: configured for UDMA/133 Would this error be the issue?
February 16, 20197 yr Author If i post full diagnostic is there anything i should omit that is private data? or is good as is?
February 16, 20197 yr Complete zip was asked for because that is what we always want, not changed in any way from the downloaded zip it gives you. It is anonymized.
February 16, 20197 yr Author Well i can't use unraid as i can't register trial or paid with this system as guid is just constantly changing.
February 16, 20197 yr Author Almost gave up i didn't have another stick to try as all my others where 64gb plus then found a 16gb integra just and that seems to work, 3 power cycles and guid has stayed the same yay.
February 16, 20197 yr Have to say that if this was happening, you're the first who has ever had it happen.
February 17, 20197 yr Author Yeah just my luck @Squid 🤣😂 thankfully up and running now with different flash stick. Community apps installed so thank you for that one!
