(SOLVED) Parity upgrade = lots of problems
6 minutes ago, stor44 said:
It’s weird that they are working now, connected to the HBA.
Oh, I understood they were now on the onboard SATA ports, like I mentioned there are reports of issues with all (most?) 10TB Seagate disks and LSI, please report back if there are more issues.
  • Replies 54
  • Views 6.4k
Yes sorry I probably confused you with my posts. When I moved unRAID and the HBA to my ASUS motherboard, at first I did have the 10TB Seagates running off the motherboard SATA ports. After a few days I decided to try the 10TB’s on the HBA, and it has been fine for several days now. Strange, but I’ll take it. Will watch for any further issues.
@stor44 curious to hear if the 3 Seagate 10TB drives are continuing to work on the HBA. I'm just adding 2 to my unRAID box and wondering how you are fairing.
I put the first one in connected to the onboard SATA 2 port to rebuild parity, but the second one has options... 🙂
Hi @klogg. So far so good with these 10TB drives once I switched motherboards. In fact I’ve since added a 4th one, but it’s only been in there a couple weeks. My monthly parity check will run next week. But I haven’t had any connection issues or missing drives anymore.
Best of luck!
@stor44
awesome! Thanks for replying.
