March 26, 20215 yr 1 minute ago, CodingMicrobe said: Yeah. That’s what I had working (with monitor connected to my system with only APU graphics, no other GPU), even in a VM, until I installed AMD drivers then it broke partially. good luck with testing Parsec, just keep in mind you may not get true graphics acceleration. i know that. since it is not necessary for my server to run 24/7 i have a dedicated ssd in it for a local installation of win... maybe i can use that later as VM... i'm not that far right now... for me this is testing how it can work later on. and my server will have no monitor attached until i boot locally. otherwise it really runs headless (that was my intention with unraid)
March 27, 20215 yr 23 hours ago, Olli said: i know that. since it is not necessary for my server to run 24/7 i have a dedicated ssd in it for a local installation of win... maybe i can use that later as VM... i'm not that far right now... for me this is testing how it can work later on. and my server will have no monitor attached until i boot locally. otherwise it really runs headless (that was my intention with unraid) Did you get some game to run on your VM? Can you please tell how you got it to work? Headless would be fine for me
March 30, 20215 yr On 3/27/2021 at 10:36 AM, limital said: Did you get some game to run on your VM? Can you please tell how you got it to work? Headless would be fine for me No. I've seen that my graphic card isn't working now... it says, that it was stopped by the system...
July 11, 20215 yr On 3/7/2021 at 12:15 PM, CodingMicrobe said: Attached is the Renoir VBIOS I extracted from the ASRock DeskMini X300 BIOS file Hello, how did you get this extract? I tried with spaceinvader script without success. I tried with gpuz without success too! Which OS/tool did you use thnaks by advance
July 26, 20215 yr Extract your BIOS with uefitool (Search Text pcir AMD extract) or Cat /sys/kernel/debug/dir/0/amdgpu_vbios > /tmp/vbios
November 7, 20214 yr Hey Hello all together, could someone pls extract the VBIOS for cezanne? pls? i could not get it so extract, its the Bios from the Asrock x300, thx in advance. X3MSTX_1.70
May 19, 20224 yr So are we ready to announce 4650G passthrough does not work and it is waste of time for many people? For example I've lost surely over 10h total time of my life. OFC I can't extract bios with SI's script, because "access denied". I tried various bioses. Quote After fixing the Iommu Group I get this: internal error: Unknown PCI header type '127' for device '0000:0d:00.0' A BIOS dump of the internal gpu is not possible. Same here, no progress. Edited May 19, 20224 yr by CobraPL
December 6, 20241 yr Check out this post from me, I made Ryzen 5 5600G work via UEFI VBIOS AND fixed reset bug with vendor-reset, so 100% usable. https://forum.proxmox.com/threads/amd-ryzen-5600g-igpu-code-43-error.138665/post-726791 I think both are Vega 7. So by copying my method, maybe all you need is a different VBIOS, or maybe the supplied one also works.
