djgizmo Posted September 24, 2022 Share Posted September 24, 2022 Discovered that my flash drive seemed to be dying while troubleshooting odd stability issues. During one of my troubleshooting steps of course I rebooted the server... and it never came back up. Last flash drive backup was in the spring before I moved to 6.10 After I upgraded successfully, seems my auto backup never ran and of I don't have any manual backups. Here's where the mistakes were made. Since the spring backup, I've replaced 1-2 of my data drives. My parity drive hasn't changed. I don't have any screen shots of the disk / drive order. -I do have my spring DISK_ASSIGNMENTS file. -I do have my license file -I do have my network/docker/domain/indent cfgs I'm not sure how to proceed. I'm aware that the array data isn't lost, but I had a boatload of docker containers running and my Home Assistant running on this as well. What are the steps to recover and get back to working order? Quote Link to comment
djgizmo Posted September 24, 2022 Author Share Posted September 24, 2022 (edited) Well, I was able to boot on another USB drive, boot with the correct network config, and request a replacement key... however, my array doesn't show any drives. Based off my disk assignments file, looks like only 1 drive has changed since that backup. I have selected what I believe to be its replacement (process of elimination) I'm deathly afraid though that if I start up, that my data will wipe due to this message in red. "All existing data on this device will be OVERWRITTEN when array is Started" (EDiT, looks like this red warning is only for the parity drive) How should I proceed? Should I just need to start the array? Edited September 24, 2022 by djgizmo Quote Link to comment
JorgeB Posted September 24, 2022 Share Posted September 24, 2022 3 hours ago, djgizmo said: looks like this red warning is only for the parity drive It is, data drives are never touched, as long as parity is correctly assigned you're fine, and you can check "parity is already valid" before array start to avoid the parity sync, assuming it is valid, in doubt run a parity check after. Quote Link to comment
djgizmo Posted September 24, 2022 Author Share Posted September 24, 2022 Understood. Thank you. Is there a way to automate my USB backups to a cloud service in case this happens again? Quote Link to comment
ChatNoir Posted September 24, 2022 Share Posted September 24, 2022 1 hour ago, djgizmo said: Is there a way to automate my USB backups to a cloud service in case this happens again? The Limetech plugin My Servers. Quote Link to comment
djgizmo Posted September 24, 2022 Author Share Posted September 24, 2022 10 minutes ago, ChatNoir said: The Limetech plugin My Servers. How often does the USB Drive backup to the unraid.net servers? Quote Link to comment
ChatNoir Posted September 24, 2022 Share Posted September 24, 2022 15 minutes ago, djgizmo said: How often does the USB Drive backup to the unraid.net servers? Every single change made to the drive. Quote Link to comment
