Execution error 403, Docker Crash, Read only/Drive Full in Fix Common Problems
Unraid 6.9.2, i5-11400, 16gb RAM, 4 drive + 1 NVME cache drive
Used as media server x plex and some home projects mostly
Everything was working fine in the server for 1 year +, but recently I have noted some docker containers started to be unresponsive. Restarting the problematic docker containers failed and result in Error 403. Did some research here and on google and saw it can be due to a full cache but my cache usage on dashboard is only 26%.
In the past few days all my docker containers will crash within 20 minute of starting the server, and all containers cannot be restarted, removed or changed, rendering my server useless.
I have included the diagnostics from booting up the server to manually triggering the Error 403/Server Error/Execution error. I would appreciate some help to point me in the right direction to fix the server.
Thanks to all
tower-diagnostics-20221126-2253.zip
Solved by JorgeB
Your cache drive has been remounted as Read-Only due to corruption / IO errors
Best to wait for @JorgeB to advise
For this kind of error best bet is to backup and re-format the pool.
