allensj94 Posted January 29, 2023 Share Posted January 29, 2023 I don't know what caused this issue nor what the logs really mean. Could anybody enlighten me in what the issue is that's giving me these read errors? tartarus-diagnostics-20230129-1606.zip Quote Link to comment
Squid Posted January 29, 2023 Share Posted January 29, 2023 Jan 29 16:01:11 Tartarus kernel: mpt3sas_cm1: SAS host is non-operational !!!! Your HBA reset itself right at the time all of this happened... You can try I suppose to reseat it. But, is the HBA counterfeit? I had a counterfeit HBA at one point that did pretty similar things. Also curious why you'd be using an HBA in the first place instead of your internal ports... Quote Link to comment
allensj94 Posted January 29, 2023 Author Share Posted January 29, 2023 32 minutes ago, Squid said: Jan 29 16:01:11 Tartarus kernel: mpt3sas_cm1: SAS host is non-operational !!!! Your HBA reset itself right at the time all of this happened... You can try I suppose to reseat it. But, is the HBA counterfeit? I had a counterfeit HBA at one point that did pretty similar things. Also curious why you'd be using an HBA in the first place instead of your internal ports... This is not the first issue I've had with the HBA if that is the problem. I had initially wanted to use the HBA as a solution for future expansion, and also learning that SAS ports seem to be more reliable than onboard SATA. I'm currently doing a parity check, which I hope will (maybe temporarily) fix my problem at the moment. If I end up going through the same problem in the near future then I would probably switch to the onboard SATA anyway. Would you think that it might be a power issue? There's an available port to be connected by the PSU, that I read was generally meant for rack mount servers. Just spitballing here. Quote Link to comment
allensj94 Posted January 29, 2023 Author Share Posted January 29, 2023 1 hour ago, Squid said: Jan 29 16:01:11 Tartarus kernel: mpt3sas_cm1: SAS host is non-operational !!!! Your HBA reset itself right at the time all of this happened... You can try I suppose to reseat it. But, is the HBA counterfeit? I had a counterfeit HBA at one point that did pretty similar things. Also curious why you'd be using an HBA in the first place instead of your internal ports... Also, how should I figure out whether my card is counterfeit or not? Quote Link to comment
Squid Posted January 29, 2023 Share Posted January 29, 2023 If the HBA has an auxiliary power connector then yes I'd be using it... But either way, more expansion cards / components = more points of failure. 1 minute ago, allensj94 said: Also, how should I figure out whether my card is counterfeit or not? You can always explicitly ask Avago if it is or not. However a good rule of thumb is what price you paid for it. If you bought a supposedly new HBA for less than $100 when it retails for $650 it's a good bet that it's counterfeit. Quote Link to comment
allensj94 Posted January 29, 2023 Author Share Posted January 29, 2023 3 minutes ago, Squid said: If the HBA has an auxiliary power connector then yes I'd be using it... But either way, more expansion cards / components = more points of failure. You can always explicitly ask Avago if it is or not. However a good rule of thumb is what price you paid for it. If you bought a supposedly new HBA for less than $100 when it retails for $650 it's a good bet that it's counterfeit. I bought this card through amazon without checking the seller, but it was selling for around 500. Sounds to me like the right price for the product to me. I'll make sure to add the aux power and keep an eye on it. If this happens again I'll come back here to let everyone know what I do about this card and where it came from. Quote Link to comment
allensj94 Posted February 4, 2023 Author Share Posted February 4, 2023 On 1/29/2023 at 10:15 PM, Squid said: If the HBA has an auxiliary power connector then yes I'd be using it... But either way, more expansion cards / components = more points of failure. You can always explicitly ask Avago if it is or not. However a good rule of thumb is what price you paid for it. If you bought a supposedly new HBA for less than $100 when it retails for $650 it's a good bet that it's counterfeit. Coming back with new diagnostics. Does it look like the same issue with the HBA? Sorry about the ignorance. Could you show me which logs I should be looking into? tartarus-diagnostics-20230205-0056.zip Quote Link to comment
JorgeB Posted February 5, 2023 Share Posted February 5, 2023 18 hours ago, allensj94 said: Does it look like the same issue with the HBA? Yep: Feb 5 00:45:13 Tartarus kernel: mpt3sas_cm1: SAS host is non-operational !!!! Make sure the HBA is well seated and sufficiently cooled, you can also try it in a different PCIe slot if available. Quote Link to comment
