JorgeB Posted February 6 Share Posted February 6 Correct command is: reiserfsck --check /dev/sdh1 Assuming sdh is the correct disk device. Quote Link to comment
Rob_Dingen Posted February 7 Author Share Posted February 7 It doesn't work. But I download Unraid and then I can mout it and it's visible. Quote Link to comment
JorgeB Posted February 7 Share Posted February 7 Post the output of: fdisk -l /dev/sdi Quote Link to comment
JorgeB Posted February 7 Share Posted February 7 That's not an Unraid standard partition, also the disk capacity is wrong, if you are using an enclosure connect the disk directly to a SATA port instead. Quote Link to comment
Rob_Dingen Posted February 11 Author Share Posted February 11 I had no free SATA port so I order a SATA extension card. When it's in and installed I report back. Rob Quote Link to comment
Rob_Dingen Posted February 14 Author Share Posted February 14 (edited) I had a Supermicro AOC-SAS2LP-MV8 lyng arround and installed it. It's not visible so I take out one disk from the array and instal none put the old disk 5 in and mount it and move the content to the new disk 5. It restored my disk 4 so when this is finnished I have everything back. Thanks for all the help. Rob Edited February 14 by Rob_Dingen 1 Quote Link to comment
