Jump to content
SOLVED - how to ID if my hard drive is using SMR or PMR Technology
I am looking at purchasing some large TB's hard drivers, but then I read up on the specs a lot of them don't mention SMR, CMR or PMR.
I have seen the following on Amazon -
Seagate Enterprise Capacity v6 10TB Internal Hard Drive ST10000NM0046 SATA 3.5" HDD 256MB Cache
MDD - HGST He10 (HUH721010ALE601) 10TB 7200RPM 128MB Cache SATA 6.0Gb/s 3.5inch Enterprise Hard Drive (Renewed)
I have google around and found that you can find out via the Smart data of the hard drive, but running smartctl, so as a test I have ran this on one of my old 10 TB hard drivers, below is the test.
I have looked through and I can't see anything that talks about the technology,   can someone please point to the right location
root@Tower:/dev# smartctl --all /dev/sdg
smartctl 7.4 2023-08-01 r5530 [x86_64-linux-6.1.74-Unraid] (local build)
Copyright (C) 2002-23, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Device Model:     WDC WD101EMAZ-11G7DA0
Serial Number:    V******P
LU WWN Device Id: 5 000cca 0b0cd5dec
Firmware Version: 81.00A81
User Capacity:    10,000,831,348,736 bytes [10.0 TB]
Sector Sizes:     512 bytes logical, 4096 bytes physical
Rotation Rate:    5400 rpm
Form Factor:      3.5 inches
Device is:        Not in smartctl database 7.3/5577
ATA Version is:   ACS-2, ATA8-ACS T13/1699-D revision 4
SATA Version is:  SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Thu Jun 27 09:07:52 2024 BST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
                                        Auto Offline Data Collection: Enabled.
Self-test execution status:      (   0) The previous self-test routine completed
                                        without error or no self-test has ever
                                        been run.
Total time to complete Offline
data collection:                (   87) seconds.
capabilities:                    (0x5b) SMART execute Offline immediate.
                                        Auto Offline data collection on/off support.
                                        Suspend Offline collection upon new
                                        command.
                                        Offline surface scan supported.
                                        Self-test supported.
                                        No Conveyance Self-test supported.
                                        Selective Self-test supported.
SMART capabilities:            (0x0003) Saves SMART data before entering
                                        power-saving mode.
                                        Supports SMART auto save timer.
Error logging capability:        (0x01) Error logging supported.
                                        General Purpose Logging supported.
Short self-test routine
recommended polling time:        (   2) minutes.
Extended self-test routine
recommended polling time:        (1108) minutes.
SCT capabilities:              (0x003d) SCT Status supported.
                                        SCT Error Recovery Control supported.
                                        SCT Feature Control supported.
                                        SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x000b   100   100   016    Pre-fail  Always       -       0
  2 Throughput_Performance  0x0004   128   128   054    Old_age   Offline      -       108
  3 Spin_Up_Time            0x0007   133   133   024    Pre-fail  Always       -       613 (Average 609)
  4 Start_Stop_Count        0x0012   100   100   000    Old_age   Always       -       373
  5 Reallocated_Sector_Ct   0x0033   100   100   005    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000a   100   100   067    Old_age   Always       -       0
  8 Seek_Time_Performance   0x0004   128   128   020    Old_age   Offline      -       18
  9 Power_On_Hours          0x0012   100   100   000    Old_age   Always       -       1284
 10 Spin_Retry_Count        0x0012   100   100   060    Old_age   Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       24
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       399
193 Load_Cycle_Count        0x0012   100   100   000    Old_age   Always       -       399
194 Temperature_Celsius     0x0002   138   138   000    Old_age   Always       -       47 (Min/Max 18/52)
196 Reallocated_Event_Count 0x0032   100   100   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0022   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0008   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x000a   200   200   000    Old_age   Always       -       0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
No self-tests have been logged.  [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 1
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
The above only provides legacy SMART information - try 'smartctl -x' for more
Edited by chris_netsmart
Link to comment
The info isn't reported by smart itself, but if smartctl knows about it in its database it'll be mentioned next to the model on top. In this case
so it doesn't know.
Best is to check the manufacturer's specs/lists or actual drive datasheets, e.g. for Seagate https://www.seagate.com/products/cmr-smr-list/
There are also user-contributed lists around.
Edited by Kilrah
Link to comment
  • chris_netsmart changed the title to SOLVED - how to ID if my hard drive is using SMR or PMR Technology
  Only 75 emoji are allowed.
  • Create New...
