Unraid 7.1.4 - network interface keeps going down at 5am - More updates (11 July) and info and diagnostic zip attached - Help requested
On 7/17/2025 at 4:51 AM, CSeK said:
I actually think there are 4 similar cases where 7.1.4 is having driver related issues with the network interface between my own machine and these 3 different user posts....
user 1 - https://forums.unraid.net/topic/191773-unarid-web-guihost-sevicesssh-freezes-but-dockerservices-still-running/
user 2 - https://forums.unraid.net/topic/192047-network-issue-after-714-update-from-713/
user 3 - this one
user 4 - me
Here is the AI output comparing the various diagnostic logs together
I'm extracting and analyzing the new Unraid diagnostics from this different user ("raider") now, focusing on network stability and comparing to your logs and the prior user.
I'll identify the root cause of the network issues and build a comparison table showing key log indicators and outcomes for you.
Give me a few moments.
I've completed a detailed review of the "raider" user's diagnostics and compared them with your logs and the previously analyzed user's logs.
Summary Table: Network-Related Issues Comparison
Culprit Across All Cases:
The common and root issue is repeated NIC link flapping caused by Intel igb network driver instability on similar hardware/chipsets running Unraid 7.1.4.
This instability leads to network loss causing the Unraid web GUI (emhttp) and SSH connections to become unresponsive or fail. The kernel remains operational, so Docker containers continue running normally.
Awesome summary. Thanks.
I would suggest though, that an Unraid script is causing the issues in my machine, which triggers the network issues. The reasoning behind this is:
  • Eth1 is brought down on random days at pretty much the same time (5:00am (or a few minutes later).
  • Eth1 being brought down triggers a cascade issue with docker virtual ethernet connections
  • Before I updated the driver, and turned off power management, this would leave eth1 in a down state, requiring manual intervention to bring it back up. With the updated driver and reduced power management capabilities, the driver still goes down at 5::00am, but comes up again a little while later (See logs).
  • Again, this happens at a fixed time on a random day, pointing very strongly at a process that interacts with the network causing eth1 to go down.
  • My eth0 does not go down, and is a different model of intel NIC.
Edited by kentb
updating with more useful information
and again, at 5:00am-ish ... after going well for a few days. eth0 is all good, eth1 goes down.
May be a docker container perhaps, not sure what process is running at this time to cause the eth1 to go down completely.
Did not happen on the 22nd. Happened on the 23rd.
Jul 22 04:40:02 raider root: Fix Common Problems Version 2025.05.29
Jul 22 04:40:10 raider root: Fix Common Problems: Warning: Docker Application netdata has an update available for it
Jul 22 09:15:36 raider kernel: eth0: renamed from veth19680b2
Jul 22 09:32:06 raider kernel: veth19680b2: renamed from eth0
Jul 23 00:54:31 raider monitor_nchan: Stop running nchan processes
Jul 23 04:40:01 raider root: Fix Common Problems Version 2025.05.29
Jul 23 04:40:10 raider root: Fix Common Problems: Warning: Docker Application n8n has an update available for it
Jul 23 04:40:10 raider root: Fix Common Problems: Warning: Docker Application netdata has an update available for it
Jul 23 04:40:10 raider root: Fix Common Problems: Warning: Docker Application Omnitools has an update available for it
Jul 23 04:40:10 raider root: Fix Common Problems: Warning: Docker Application openHAB has an update available for it
Jul 23 05:00:54 raider kernel: r8168: eth1: link down
Jul 23 05:00:54 raider kernel: br1: port 1(eth1) entered disabled state
Jul 23 05:00:57 raider ntpd[2079]: Deleting 6 br1, [10.1.2.1]:123, stats: received=0, sent=0, dropped=0, active_time=259187 secs
Jul 23 05:01:01 raider kernel: r8168: eth1: link up
Jul 23 05:01:01 raider kernel: br1: port 1(eth1) entered blocking state
Jul 23 05:01:01 raider kernel: br1: port 1(eth1) entered forwarding state
Jul 23 05:01:03 raider ntpd[2079]: Listen normally on 7 br1 10.1.2.1:123
Jul 23 05:01:03 raider ntpd[2079]: new interface(s) found: waking up resolver
Jul 23 05:01:09 raider kernel: r8168: eth1: link down
Jul 23 05:01:09 raider kernel: br1: port 1(eth1) entered disabled state
Jul 23 05:01:13 raider ntpd[2079]: Deleting 7 br1, [10.1.2.1]:123, stats: received=0, sent=0, dropped=0, active_time=10 secs
Jul 23 05:01:25 raider kernel: r8168: eth1: link up
Jul 23 05:01:25 raider kernel: br1: port 1(eth1) entered blocking state
Jul 23 05:01:25 raider kernel: br1: port 1(eth1) entered forwarding state
Jul 23 05:01:27 raider ntpd[2079]: Listen normally on 8 br1 10.1.2.1:123
Jul 23 05:01:27 raider ntpd[2079]: new interface(s) found: waking up resolver
On 7/16/2025 at 2:17 AM, bmartino1 said:
the OP issue here is a different netowrk issues that is partly due to docker and the br1 setup, along with misconfiguration of the sleep plugin / autotweak plugin with power causng a disconect on the device entering a sleep state.
@gguglielmi
Your issue is not the same.
@bmartino1 The issue definitely is not the power state ... I have restored the power settings as I was not satisfied with the monitor never turning off.
the driver update stopped the system hanging, and this was excellent advice
However, eth1 still goes down every two to three days at 5:00am-ish - and this only started during the latest unraid update.
So, driver sorted the network crashing out, but the underlying issue seems to be an unraid issue.
Let me know if you strongly disagree with the above, and I'm happy to diagnose.
Then its a kernel issue... some other users have been reporting similar... without a DIAG FILE I can't see what your running or double check...
They all reverted back to 7.1.3 and the issue gone away.
From my testing when theses occur, its always a aspm thing with how they handle power states... the kerneal could be flagin it. the linux driver code could be flaggin it...
Regardless, something is telling it to go to a sleep state otherwise its physical hardware failure. the Physical traces coming undone prooble due to heat on the board. (I've seen werider...)
I have yet to experience this even with testing mutifactets of hardware with a variety of systems.
Please post a diag file...
I would even 3rd party boot a live distro / ssd install debain and see if its happening. IF you think its unraid causing it...
@bmartino1 Happy to post a diag ... both one I posted at the beginning of this thread, and one now, after tweaks and changes.
Your statement "... some other users have been reporting similar...They all reverted back to 7.1.3 and the issue gone away." very very strongly indicates not a hardware, not a trace lifting due to heat ... likely a software / kernel issue.
I posted a diagnostics file earlier in this thread, but posting again here ...
raider-diagnostics-20250724-0840.zipraider-diagnostics-20250711-0931.zip
  • 2 months later...
I also have this problem now, it stops working randomly.
I dont think it is 05:00 exact but there is something happening then. Today I left the house around 07:50 and had contact with it as it has nginx proxy manger on it which i used to open the garage doors. But later that day around 08:30 it stopped working.
I updated to 7.1.4 around 19th september I believe. (Not sure if this is logged somewhere?)
Timeline:
- 29.09 - Noticed around 07:55, reboot fixed it
- 30.09 - Not sure when, but probaly noticed it crashed in the morning around  06:40-07:10 and rebooted it before i traveled to work and enabled remote syslog at 08:05
- 01.10 - Noticed around 09:30, known to wokr 07:54:41 as it was used then.
Sep 30 22:12:31 UnraidServer sshd-session[451167]: banner exchange: Connection from 162.142.125.112 port 52362: invalid format
Sep 30 22:12:32 UnraidServer sshd-session[451168]: Connection from 162.142.125.112 port 52384 on 10.0.20.10 port 22 rdomain ""
Sep 30 22:12:35 UnraidServer sshd-session[451168]: error: kex_exchange_identification: read: Connection reset by peer
Sep 30 22:12:35 UnraidServer sshd-session[451168]: Connection reset by 162.142.125.112 port 52384
Sep 30 22:12:35 UnraidServer sshd[13589]: srclimit_penalise: ipv4: new 162.142.125.112/32 deferred penalty of 1 seconds for penalty: connections without attempting authentication
Sep 30 22:12:39 UnraidServer sshd-session[451235]: Connection from 162.142.125.112 port 54734 on 10.0.20.10 port 22 rdomain ""
Sep 30 22:12:54 UnraidServer sshd-session[451235]: Connection closed by 162.142.125.112 port 54734 [preauth]
Sep 30 22:12:54 UnraidServer sshd[13589]: srclimit_penalise: ipv4: new 162.142.125.112/32 deferred penalty of 1 seconds for penalty: connections without attempting authentication
Oct  1 05:00:06 UnraidServer root: /etc/libvirt: 919 MiB (963624960 bytes) trimmed on /dev/loop3
Oct  1 05:00:06 UnraidServer root: /var/lib/docker: 31.9 GiB (34260123648 bytes) trimmed on /dev/loop2
Oct  1 05:00:11 UnraidServer sSMTP[711079]: Creating SSL connection to host
Oct  1 05:00:11 UnraidServer sSMTP[711079]: SSL connection using TLS_AES_256_GCM_SHA384
Oct  1 05:00:11 UnraidServer sSMTP[711079]: Authorization failed (535 5.7.8  https://support.google.com/mail/?p=BadCredentials 38308e7fff4ca-36fb5282340sm38004901fa.29 - gsmtp)
Oct  1 16:17:52 UnraidServer rc.rsyslogd: Syslog server daemon...  Started.
Oct  1 16:17:52 UnraidServer root: Delaying execution of fix common problems scan for 10 minutes
Oct  1 16:17:52 UnraidServer emhttpd: /usr/local/emhttp/plugins/user.scripts/backgroundScript.sh "/tmp/user.scripts/tmpScripts/Backup Homeassistant/script" >/dev/null 2>&1
Oct  1 16:17:52 UnraidServer emhttpd: Starting services...
Oct  1 16:17:52 UnraidServer emhttpd: shcmd (68): /etc/rc.d/rc.samba reload
Oct  1 16:17:53 UnraidServer rsyslogd: [origin software="rsyslogd" swVersion="8.2102.0" x-pid="7758" x-info="https://www.rsyslog.com"] start
Oct  1 16:17:53 UnraidServer emhttpd: shcmd (72): /etc/rc.d/rc.avahidaemon reload
Oct  1 16:17:53 UnraidServer emhttpd: shcmd (82): /usr/local/sbin/mount_image '/mnt/user/system/docker/docker.img' /var/lib/docker 60
Oct  1 16:17:56 UnraidServer sysDrivers: SysDrivers Build Complete
Oct  1 16:17:56 UnraidServer kernel: loop2: detected capacity change from 0 to 125829120
Oct  1 16:17:56 UnraidServer kernel: BTRFS: device fsid fc49973f-4dd7-4d5a-961c-f2a44183485e devid 1 transid 4577222 /dev/loop2 (7:2) scanned by mount (8578)
Oct  1 16:17:56 UnraidServer kernel: BTRFS info (device loop2): first mount of filesystem fc49973f-4dd7-4d5a-961c-f2a44183485e
Oct  1 16:17:56 UnraidServer kernel: BTRFS info (device loop2): using
Edited by TUnraidUser
Update:
I managed to fix my original issue by downgrading back to my 6.x.x version. But after reverting back to my initial version, a new problem appeared, random total freezes within the first 24 hours. No screen output, no keyboard response. I even set the display to stay on permanently; it just shows the login after reboot, no errors, no hints. The system doesn’t respond to ICMP, nothing in DMESG and there’s zero traffic on the Ethernet port.
It had been rock-solid for over a year before I upgraded. So I did a upgrade back to 7.1.4 again to verify my hardware was not going bad. But the freezing continued! I wasn’t sure if the network issue was still happening since the system froze completely. Then I read that version 7.1.3 was stable for many who had problems with 7.1.4, so I did a downgrade → upgrade dance back to 7.1.3.
Still froze.
A week of freezing later, I stumbled upon this post: https://forums.unraid.net/topic/137908-unraid-server-keeps-freezing/ which pointed me to the Arch Wiki: https://wiki.archlinux.org/title/Ryzen#Soft_lock_freezing
I’m running a Ryzen 5600, so I tried the suggested kernel parameters. Went to Main → Flash → Syslinux Configuration and appended the parameters recommended from the Archlinux wiki:
kernel /bzimage
append pcie_acs_override=downstream,multifunction initrd=/bzroot rcu_nocbs=0-11 processor.max_cstate=5
After adding rcu_nocbs and processor.max_cstate, my server’s been stable for over 30 hours — a record this past week.
What puzzles me is: why was it perfectly stable before 7.1.4 upgrade? What changed? And why did it still crash even after downgrading to my previously rock-solid 6.x version?!
8 hours ago, TUnraidUser said:
Update:
Still froze.
kernel /bzimage
@JorgeB
I don't know where but I rember there being a issues with ryzen and C states.
can you point me or share here the fourm post about that issue?
as this thread and clients may be affected by a known amd bug issues due to cstate.
I know of it, I've not experienced it, but the fix was to turn off cstates...
