lanceg321 Posted November 22, 2014 Share Posted November 22, 2014 First off, I'm a NOOB to UNRAID and to LINUX, but I am pretty technically savvy. This latest issue with my unraid server has me baffled. We had a major power outage a week or so ago and I've had trouble ever since. I do have a power backup on my server for these occassions, but it doesn't seemed to have helped in this case. Here's what happened: I booted up the Unraid server after power outage When it booted, it automatically started a parity check, which I let it finish Two days later when parity check completed, I noticed that disk4 was unformatted, but the parity completed successfully and the drive array is up. All of my data appears to be in tact (from what i can tell) After seeing all the warnings in the forums about dealing with unformatted drives, I don't want to make a bad move here. My questions is this... since the parity is valid, and all of my files appear to be in tact, should I just format the drive and run parity again? Also, running the reiserifs --check on the disk fails with: "reiserfs_open: the reiserfs superblock cannot be found on /dev/md4. Failed to open the filesystem. If the partition table has not been changed, and the partition is valid and it really contains a reiserfs partition, then the superblock is corrupted and you need to run this utility with --rebuild-sb." What should I do from here? Reformat the drive or rebuild option with reiserfs? Also, ever since the power outage, the web UI access to the server has been really flaky. Sometimes it works sometimes it doesn't. Even using PUTTY I get the same result. If try to telnet in 2-3 times, it usually works eventually. Any ideas why this would happen after a power outage all of sudden? I appreciate any and all feedback. I'm sitting idle until some direction. Thank you! Link to comment
dgaschk Posted November 22, 2014 Share Posted November 22, 2014 See here: http://lime-technology.com/forum/index.php?topic=9880.0 Link to comment
Brucey7 Posted November 23, 2014 Share Posted November 23, 2014 And make buying a UPS a priority too. Link to comment
lanceg321 Posted November 23, 2014 Author Share Posted November 23, 2014 Thanks for the pointer dgashik. My syslog is attached. I'm still working on documenting the hardware specifications, but this box has worked with no issues or hardware changes for the last 2 years, until the recent power outage. Thanks Bucey7 for the reply. I do have a UPS installed on the server. Any ideas on how to move forward would be much appreciated! Thanks! disk_4_short_smart_test.txt syslog-2014-11-23.txt Link to comment
lanceg321 Posted November 30, 2014 Author Share Posted November 30, 2014 Bump... any help on this issue would be really appreciated. Should I pre-clear the drive and just add it back into the array? Thanks! Link to comment
dgaschk Posted December 5, 2014 Share Posted December 5, 2014 See here: http://lime-technology.com/wiki/index.php/Troubleshooting#What_do_I_do_if_I_get_a_red_ball_next_to_a_hard_disk.3F SMART looks ok. Link to comment
lanceg321 Posted December 5, 2014 Author Share Posted December 5, 2014 Thanks dgashk. Would you recommend that I just reformat the drive then? I'm just trying to make sure I don't lose any data. My parity is okay also. I appreciate it! Link to comment
dgaschk Posted December 6, 2014 Share Posted December 6, 2014 Do NOT format the drive unless you wish to remove its contents. Read the instructions completely and then follow them carefully to reenable and rebuild the drive. Link to comment
hackztor Posted December 7, 2014 Share Posted December 7, 2014 A checkdisk will be in order. Unformatted does not mean empty it just means the drive cannot be read (file system corruption) Do the checkdisk for reiserfs is that is what you use and it will tell you which command needs to be run to fix. Link to comment
lanceg321 Posted December 8, 2014 Author Share Posted December 8, 2014 Do NOT format the drive unless you wish to remove its contents. Read the instructions completely and then follow them carefully to reenable and rebuild the drive. I followed the directions explicitly as you suggested dgaschk. The drive was added back to the array, with no reported errors, after rebuilding the data in the array. However, it now shows a green ball, valid parity, yet it is listed as still being unformatted. What would be next? Now should I reformat it? I appreciate the input. Link to comment
dgaschk Posted December 9, 2014 Share Posted December 9, 2014 See check disk file systems in my sig. Link to comment
itimpi Posted December 9, 2014 Share Posted December 9, 2014 Do NOT format the drive unless you wish to remove its contents. Read the instructions completely and then follow them carefully to reenable and rebuild the drive. I followed the directions explicitly as you suggested dgaschk. The drive was added back to the array, with no reported errors, after rebuilding the data in the array. However, it now shows a green ball, valid parity, yet it is listed as still being unformatted. What would be next? Now should I reformat it? I appreciate the input. Do NOT reformat the disk unless you want to lose all its data. As was mentioned the next step is to run a file system check to detect/fix any corruption at the file system level. Link to comment
