July 17, 201610 yr A side note however is that the 5015 will not give you the JBOD support needed to use it on unraid. According to this post, it says the m1015 is compatible with unraid. Do you mean that unraid recognized the card but won't act like an HBA? https://lime-technology.com/wiki/index.php/Hardware_Compatibility#PCI_SATA_Controllers
July 17, 201610 yr Author You posting in a thread for the M5015. If you have the M1015 then it's all good and unRAID will thank you for it [emoji18]. However posting about the card you actually have always helps. Sent from my iPhone using Tapatalk
July 17, 201610 yr A side note however is that the 5015 will not give you the JBOD support needed to use it on unraid. According to this post, it says the m1015 is compatible with unraid. Do you mean that unraid recognized the card but won't act like an HBA? https://lime-technology.com/wiki/index.php/Hardware_Compatibility#PCI_SATA_Controllers The wiki indicates the m1015 must be cross flashed to be supported. It's on the right side.
July 17, 201610 yr You posting in a thread for the M5015. If you have the M1015 then it's all good and unRAID will thank you for it [emoji18]. However posting about the card you actually have always helps. Ha, never even noticed. Sorry about that. Thanks again!
July 19, 201610 yr Does the M1015 support 8TB HDDs? Sent from my SM-J710GN using Tapatalk I would be surprised if any controller that supports drives > 2.2TB wouldn't support any drive capacity produced for the foreseeable future.
October 16, 20187 yr On 9/19/2015 at 7:23 AM, JWMutant said: Well I want to thank everyone who helped. The card is now flashed and the drives are showing up in unraid. Ill post up a easy step by step for when someone else comes across the problem of not being able to get into shell soon. just quick for you, on most uefi motherboards you can enable CSM to auto ish and then do an F8 boot 'ASUS boards' F11/12 most others and the UEFI options should show in the boot list, this is the easiest way to boot a UEFI bootable USB/Disk
