jang430 Posted January 22, 2018 Share Posted January 22, 2018 Hi. I set up a system for a relative. Oftentimes, the machine will fill up as the user don't know how to clean/ delete shows downloaded. What app shall I use to be able to remotely access the machine, and manage unraid? The user don't use firewall, neither does he have permanent IP. Link to comment
trurl Posted January 22, 2018 Share Posted January 22, 2018 Teamviewer into another PC on his network is probably the simplest to setup. OpenVPN-AS Docker is another possibility. Link to comment
JorgeB Posted January 22, 2018 Share Posted January 22, 2018 Besides what trurl mentioned It looks like it will be possible in the future: https://lime-technology.com/forums/topic/65494-unraid-os-version-640-stable-release-available/?do=findComment&comment=619129 Link to comment
jang430 Posted January 23, 2018 Author Share Posted January 23, 2018 Besides what trurl mentioned It looks like it will be possible in the future: https://lime-technology.com/forums/topic/65494-unraid-os-version-640-stable-release-available/?do=findComment&comment=619129 Hi. Forgot about TeamViewer! Thanks. But yes, would like to try open vpn, though don't know how to set up. Will check out post of Johnnie.black Sent from my iPhone using Tapatalk Link to comment
