CaptainTivo Posted November 27, 2018 Share Posted November 27, 2018 I have been running 6.5.3 for about 5 months now and I have only one docker and no VMs so I think 8G should be sufficient, right? But, today I went to update some apps and I got some very strange behavior in the web GUI: 1. Click on "Apps" and a box pops up with a warning "Disclaimer All application listed here are 3rd party ..." Clicking "I understand closed the box and opened another copy. Rinse and repeat: 2. Click on "Plugins" and the plugins fill the page but none of them are "links", that is, a browser (Chrome) did not show a and "arrow" icon indicating a clickable link on any of the apps. 3. I check the syslog and it had one line: "Fatal error: Allowed memory size of 134217728 bytes exhausted (tried to allocate 132124704 bytes) in /usr/local/emhttp/plugins/dynamix/include/DefaultPageLayout.php(383) : eval()'d code on line 73" 4. Clicked on "diagnostics" and downloaded the zip file. It is attached below. 5. rebooted and a parity rebuild started indicating that shutdown was not clean. 6. downloaded the diag zip again (2nd file below) I'm no expert but this worries me: "Nov 26 04:41:22 Tower kernel: usb 3-1: reset high-speed USB device number 2 using ehci-pci Nov 26 04:41:27 Tower kernel: usb 3-1: device descriptor read/64, error -110" Is this the FLASH drive? How to determine which device it is? Also this: Nov 26 04:42:28 Tower emhttpd: error: put_config_idx, 609: No such file or directory (2): fopen: /boot/config/shares/Backup1.cfg Nov 26 04:42:28 Tower kernel: blk_partition_remap: fail for partition 1 Nov 26 04:42:28 Tower kernel: blk_partition_remap: fail for partition 1 Nov 26 04:42:28 Tower kernel: blk_partition_remap: fail for partition 1 Over and over. I think this says it can't open the cfg file on the USB FLASH drive, right? Then this error: v 26 04:42:28 Tower kernel: FAT-fs (sda1): Directory bread(block 32768) failed Nov 26 04:42:28 Tower kernel: blk_partition_remap: fail for partition 1 sda1 is the FLASH drive. Should I replace the FLASH drive? It is over 6 years old. I think I need to buy a new license since it is tied this drive, right? Thanks for any help. tower-diagnostics-20181127-1453.zip tower-diagnostics-20181127-1613.zip Link to comment
John_M Posted November 27, 2018 Share Posted November 27, 2018 You may well need to replace your flash, but before you do put it in your PC and check the file system for corruption. You won't need to buy a new licence. There's a procedure for replacing your licence key to match your new USB flash: https://lime-technology.com/replace-key/ Link to comment
Frank1940 Posted November 28, 2018 Share Posted November 28, 2018 I would suggest that you make a backup of your flash drive now and make sure that you have a copy of your .key file. IT should be in the config directory/folder of the flash drive. Link to comment
CaptainTivo Posted November 28, 2018 Author Share Posted November 28, 2018 Sounds like a good idea. Any thoughts on why these errors resulted in memory allocation errors? This may not be the only problem, right? Link to comment
Frank1940 Posted November 28, 2018 Share Posted November 28, 2018 I would also suggest that you make sure that your flash drive is plugged into a USB2 port (normally a black plastic insert) rather than a USB3 port (normally a blue plastic insert). USB3 ports for the boot drive have given some Unraid users problems. Link to comment
