Running into what i think is a docker networking issue
Stop the Docker and VM services (see settings)
Now under Network settings change the DNS settings to use a single server (start with 8.8.8.8)
OK done and the result of the cat /etc/resolv.conf within the container is:
sh-5.0# cat /etc/resolv.conf
# Generated DNSv4 entries:
nameserver 8.8.8.8
Same behavior with the docker trying to find the usenet, no matter which I try, the same immediate response.
 [Errno 99] Address not available
Check for internet or DNS problems
Try setup NZBGet instead? I switched around 12 months ago and will never look back. Far superior software.
  • 9 months later...
nameserver 8.8.8.8
Did you ever resolve this? I'm having the exact same issue.
  • 8 months later...
Im also having this issue, all of a sudden deluge stopped downloading files, i can't install any apps.
I've checked the network settings and cleared out DNS and re-entered 1.1.1.1, 8.8.8.8 and same issue.
Diagnostics attached.
zeus-diagnostics-20201027-1547.zip
Been a while, but have you fixed your issue?
