mihcox Posted September 25, 2019 Share Posted September 25, 2019 I recently updated my CA Fix Common Problems, but seem to have an issue. There is no settings page for it, but the APPS tab shows it as installed. How do i remove it from the system so that i can install it again? Quote Link to comment
Squid Posted September 26, 2019 Share Posted September 26, 2019 From either the Plugins Tab or Apps (Installed Apps) you can remove it. But Strange Though.... Quote Link to comment
mihcox Posted September 26, 2019 Author Share Posted September 26, 2019 It does not show up in the plugins list. When i try to remove it through the apps page, it uninstalls. So i reinstall ,but it is still not there after install. This all started when i tried to update fix common problems through a tab on Oragnizr2. After clicking update, the popup didnt load and i think it freaked out. Quote Link to comment
Squid Posted September 26, 2019 Share Posted September 26, 2019 Delete /config/plugins/fix.common.problems.plg and /config/plugins/fix.common.problems/* on the flash drive. Reboot and try reinstalling. Quote Link to comment
mihcox Posted September 27, 2019 Author Share Posted September 27, 2019 Nailed it, thank you! Quote Link to comment
