Gigabyte X570 AORUS Elite / Pro (WiFi) / Ultra Tips & Tricks
On 1/29/2020 at 2:01 PM, Dava2k7 said:
Can you tell me how you did this pls via xml
Add this to your XML:
      <driver name='vfio'/>
      <source>
        <address domain='0x0000' bus='0x07' slot='0x00' function='0x0'/>
      </source>
    </hostdev>
      <source>
        <address domain='0x0000' bus='0x07' slot='0x00' function='0x1'/>
      </source>
    </hostdev>
      <source>
        <address domain='0x0000' bus='0x07' slot='0x00' function='0x3'/>
      </source>
    </hostdev>
  • Replies 149
  • Views 91.8k
  • Here they are with F10 bios and above settings. The Fresco Logic FL1100 is a PCIe card.
  • The fun never stops, I uploaded a new 6.8.0-rc5 kernel today that incorporates a bunch of goodies for this board. Brand new k10temp patches for Ryzen, and a fix for passing through onboard audio!
  • Note that I can not pass the on board audio even though it's in it's own group. I've always used a (USB) Astro Mixamp so it's no loss to me.
      <source>
      </source>
    </hostdev>
      <source>
      </source>
    </hostdev>
      <source>
      </source>
    </hostdev>
Thank you il give it a try is there anything I need to change or look up before inputting the code I’ve got my unraid usb in bios slot which is white my oculus 3x usbs in usb 3.0 ports il save the xml before I change it so I can change it back thank you for your help 👍🏻
Make sure you update your bios to atleast f10 and make the following changes in the bios:
UEFI / BIOS Settings:
Tweaker -> Advanced CPU Settings -> SVM Mode -> Enable
Settings -> Miscellaneous -> IOMMU -> Enable
Settings -> AMD CBS -> ACS Enable -> Enable
Settings -> AMD CBS -> Enable AER Cap -> Enable
And in unraid turn off acs override. You will no longer need it.
Yeah I done IOMMU and enabled Svm whilst following space invaders vm tutorial I have turned off acs overide I have a perfect running vm with sound video passthrough and my usb keyboard mouse ect it’s working very well and love it but I need to get the oculus vr working I’ve tried following guide lines for finding the bus numbers and other bits I need for vfio and stuff and tried to follow everything I’ve seen on the unraid forum but to no success I need to try the xml suggested by phat cow Skitals kinda helped me out but I don’t know what stubing is...but I just wanna check a few things with phat cow to make sure the xml matches my usb configuration don’t want my server getting stuck at boot anymore il have a heart attack if I get much more of it lol hopefully the great minds on here can take a few minutes of the day to help me out and finally stop me posting lol
Edited by Dava2k7
5 minutes ago, Dava2k7 said:
Yeah I done IOMMU and enabled Svm whilst following space invaders vm tutorial I have turned off acs overide I have a perfect running vm with sound video passthrough and my usb keyboard mouse ect it’s working very well and love it but I wanna get the vr working I’ve tried following guide lines for finding the bus numbers and stuff and tried to follow everything I’ve seen on the unraid forum but to no success I need to try the xml suggested by phat cow but I just wanna check a few things make sure the xml matches my usb configuration don’t want my server getting stuck at boot anymore il have a heart attack if I get much more of it lol
If your usb controller is passthrough correctly then your vr stuff should be working as long as they are plugging into the correct usb conntroller. Not sure why you need the bus numbers for your vr equipment.
Edited by Sleepyme
I just get this error
Try Unplug your vr stuff then launch your vm. Once windows boots then plug them in.
K il try now I’m missing the oculus headset off the list does that matter
Nothing happens doesn’t detect them
I can see the headset if I remove unraid usb and move to usb 3.1 port and two sensors also show up but like I say non will show bloody nightmare lol 😤
Don't passthrough your vr stuff this way. Uncheck all your vr stuff. The whole purpose of passing through a usb controller is so that you don't need to passthrough individual usb devices.
K well xml didn’t work either what’s my next step and what screen shot info do you need to help get this sorted I just want it done with 😳
Getting to that point now where I’d be willing to pay someone to sort this 🤔image.jpg
Edited by Dava2k7
Post your complete xml and your iommu group.
IOMMU group 0:[1022:1482] 00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
[1022:1483] 00:01.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge
[1022:1483] 00:01.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge
[197b:0585] 01:00.0 SATA controller: JMicron Technology Corp. Device 0585
[1022:57ad] 02:00.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse Switch Upstream
[1022:57a3] 03:02.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge
[1022:57a3] 03:03.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge
[1022:57a4] 03:08.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge
[1022:57a4] 03:09.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge
[1022:57a4] 03:0a.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge
[8086:1539] 04:00.0 Ethernet controller: Intel Corporation I211 Gigabit Network Connection (rev 03)
[8086:2723] 05:00.0 Network controller: Intel Corporation Wi-Fi 6 AX200 (rev 1a)
[1022:1485] 06:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
[1022:149c] 06:00.1 USB controller: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller
[1022:149c] 06:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller
[1022:7901] 07:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 51)
[1022:7901] 08:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 51)
IOMMU group 1:[1022:1482] 00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
IOMMU group 2:[1022:1482] 00:03.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
[1022:1483] 00:03.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge
[10de:1c82] 09:00.0 VGA compatible controller: NVIDIA Corporation GP107 [GeForce GTX 1050 Ti] (rev a1)
[10de:0fb9] 09:00.1 Audio device: NVIDIA Corporation GP107GL High Definition Audio Controller (rev a1)
IOMMU group 3:[1022:1482] 00:04.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
IOMMU group 4:[1022:1482] 00:05.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
IOMMU group 5:[1022:1482] 00:07.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
IOMMU group 6:[1022:1484] 00:07.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B]
IOMMU group 7:[1022:1482] 00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
IOMMU group 8:[1022:1484] 00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B]
IOMMU group 9:[1022:1484] 00:08.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B]
IOMMU group 10:[1022:1484] 00:08.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B]
IOMMU group 11:[1022:790b] 00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 61)
[1022:790e] 00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
IOMMU group 12:[1022:1440] 00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 0
[1022:1441] 00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 1
[1022:1442] 00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 2
[1022:1443] 00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 3
[1022:1444] 00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 4
[1022:1445] 00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 5
[1022:1446] 00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 6
[1022:1447] 00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 7
IOMMU group 13:[1022:148a] 0a:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function
IOMMU group 14:[1022:1485] 0b:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
IOMMU group 15:[1022:1486] 0b:00.1 Encryption controller: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Cryptographic Coprocessor PSPCPP
IOMMU group 16:[1022:149c] 0b:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller
IOMMU group 17:[1022:1487] 0b:00.4 Audio device: Advanced Micro Devices, Inc. [AMD] Starship/Matisse HD Audio Controller
IOMMU group 18:[1022:7901] 0c:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 51)
IOMMU group 19:[1022:7901] 0d:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 51)
<domain type='kvm'>
  <name>Windows 10</name>
  <uuid>a73f1e5e-e058-810b-0873-efdafd2ce5b1</uuid>
  <metadata>
  </metadata>
  <memory unit='KiB'>16777216</memory>
  <currentMemory unit='KiB'>16777216</currentMemory>
  <memoryBacking>
    <nosharepages/>
  </memoryBacking>
  <vcpu placement='static'>12</vcpu>
  <cputune>
    <vcpupin vcpu='0' cpuset='6'/>
    <vcpupin vcpu='1' cpuset='18'/>
    <vcpupin vcpu='2' cpuset='7'/>
    <vcpupin vcpu='3' cpuset='19'/>
    <vcpupin vcpu='4' cpuset='8'/>
    <vcpupin vcpu='5' cpuset='20'/>
    <vcpupin vcpu='6' cpuset='9'/>
    <vcpupin vcpu='7' cpuset='21'/>
    <vcpupin vcpu='8' cpuset='10'/>
    <vcpupin vcpu='9' cpuset='22'/>
    <vcpupin vcpu='10' cpuset='11'/>
    <vcpupin vcpu='11' cpuset='23'/>
  </cputune>
  <os>
    <type arch='x86_64' machine='pc-i440fx-4.2'>hvm</type>
    <nvram>/etc/libvirt/qemu/nvram/a73f1e5e-e058-810b-0873-efdafd2ce5b1_VARS-pure-efi.fd</nvram>
  </os>
  <features>
    <acpi/>
    <apic/>
    <hyperv>
      <relaxed state='on'/>
      <vapic state='on'/>
    </hyperv>
  </features>
  <cpu mode='host-passthrough' check='none'>
    <topology sockets='1' cores='12' threads='1'/>
  </cpu>
  <clock offset='localtime'>
  </clock>
  <on_crash>restart</on_crash>
  <devices>
      <source file='/mnt/user/domains/Windows 10/vdisk1.img'/>
      <boot order='1'/>
    </disk>
      <source file='/mnt/user/isos/virtio-win-0.1.160-1.iso'/>
      <target dev='hdb' bus='ide'/>
      <readonly/>
    </disk>
    </controller>
    </controller>
    </controller>
      <master startport='0'/>
    </controller>
      <master startport='2'/>
    </controller>
      <master startport='4'/>
    </controller>
    <interface type='bridge'>
      <mac address='52:54:00:3f:23:bd'/>
      <source bridge='br0'/>
      <model type='virtio'/>
    </interface>
    <serial type='pty'>
        <model name='isa-serial'/>
      </target>
    </serial>
    <console type='pty'>
    </console>
    <channel type='unix'>
    </channel>
      <source>
        <address domain='0x0000' bus='0x09' slot='0x00' function='0x0'/>
      </source>
      <rom file='/mnt/cache/domains/Gigabyte.GTX1050Ti hacked.rom'/>
    </hostdev>
      <source>
        <address domain='0x0000' bus='0x09' slot='0x00' function='0x1'/>
      </source>
    </hostdev>
    <hostdev mode='subsystem' type='usb' managed='no'>
      <source>
        <vendor id='0x046d'/>
        <product id='0xc534'/>
      </source>
    </hostdev>
    <memballoon model='none'/>
  </devices>
</domain>
Oh no wonder the xml method wasn't working. You have a different board.
Try adding this to your xml (after the last </hostdev>). Also i assume you deleted the portion of the xml i gave you earlier.
<hostdev mode='subsystem' type='pci' managed='yes'>
      <source>
        <address domain='0x0000' bus='0x06' slot='0x00' function='0x0'/>
      </source>
</hostdev>
      <source>
        <address domain='0x0000' bus='0x06' slot='0x00' function='0x1'/>
      </source>
</hostdev>
      <source>
        <address domain='0x0000' bus='0x06' slot='0x00' function='0x3'/>
      </source>
</hostdev>
Ok so what would advise I do now and thank you again for you persistence 😊
Your board is a little different since its an itx board but i hope this still works for you.
Copy and paste the text above and add it to your xml but add it after the last </HOSTDEV>
Yeah That didn’t work either unfortunately
You're on the latest bios and acs override is off?
What happen when you launch your vm?
Edited by Sleepyme
Yeah I’m on f11 I believe
Did you get any error messages when launching your vm?
No but it didn’t do anything inside vm do I need the vfio config file in place before doing this? Or Somin?
