Christo Posted May 12, 2020 Share Posted May 12, 2020 Greetings people I have a very simple setup. Machine with 4 X HDD and 2 X SSD for cache. No parity Disk numebr 3 has failed but i managed to move most of the data off it and onto the remaining drives I removed the disk from all the shares so this disk is virtually empty. The issue now is that i have to de-commission the entire machine and want to move to a smaller microserver and i dont need the SSD disks for cache either. I'll only be running it as a media server with Plex, Sonarr etc. I set all shares to "yes" as per post I got on the forum and invoked the mover. It left some data on the cache pool and I saw it was a VM's disk file. Seeing that i dont need the VMs anymore, i deleted it and invoked the mover again. This time nothing moved. I then stopped the array and removed the cache disks from the config. Upon restarting the array all the containers were gone. Only after I added the SSD disks again, the containers were restored So here is the questions Can remove the cache disks and keep my containers? Once i get that done Can i remove the failed disk from the array before I move the remaining disks to the microserver ? I see you can create a new config, but i was not sure if my data would stay in tact. From post I have read it seems quite easy to migrate to the other machine .. Seems you move the disks and USB key to the new machine and Bob's your uncle It would see the order in which I need to do this it tripping me up Has anyone done something similar successfully that can assist please Thanks in advance Quote Link to comment
trurl Posted May 12, 2020 Share Posted May 12, 2020 Go to Tools - Diagnostics and attach the complete Diagnostics ZIP file to your NEXT post. Quote Link to comment
Christo Posted May 12, 2020 Author Share Posted May 12, 2020 Here is the file as requested mediaserver-diagnostics-20200512-2254.zip Quote Link to comment
trurl Posted May 12, 2020 Share Posted May 12, 2020 Mover can't move open files. Disable docker and VM services in Settings, run mover, when it completes post new diagnostics. Quote Link to comment
Christo Posted May 13, 2020 Author Share Posted May 13, 2020 Thank you for the feedback. Disabled VM manager and Docker ... Reboot system and ran mover again ... Nothing moved File attached Thank you mediaserver-diagnostics-20200513-1011v2.zip Quote Link to comment
Helmonder Posted May 13, 2020 Share Posted May 13, 2020 What about forgetting about mover and just disabling VM and Docker completely (thru settings) and then moving the files manually and then starting docker and VM again.. ? Quote Link to comment
trurl Posted May 13, 2020 Share Posted May 13, 2020 What do you get from the command line with these? ls -lah /mnt/cache/system ls -lah /mnt/disk1/system Quote Link to comment
Christo Posted May 13, 2020 Author Share Posted May 13, 2020 I get the following Quote Link to comment
trurl Posted May 13, 2020 Share Posted May 13, 2020 Do you actually have any VMs? Quote Link to comment
Christo Posted May 13, 2020 Author Share Posted May 13, 2020 I have removed all the vms two days ago already and ran mover a few times after that Interesting is that the docker image shows 20Gb ... thats the size of the file that is "stuck" on the cache disk There is some screen shots below Quote Link to comment
trurl Posted May 13, 2020 Share Posted May 13, 2020 2 hours ago, Christo said: Interesting is that the docker image shows 20Gb ... thats the size of the file that is "stuck" on the cache disk And what is in the system/docker folder of disk1? Quote Link to comment
Christo Posted May 13, 2020 Author Share Posted May 13, 2020 Docker.img of 21.5Gb Quote Link to comment
trurl Posted May 13, 2020 Share Posted May 13, 2020 And which of these docker.img files has the most recent date? Quote Link to comment
Christo Posted May 13, 2020 Author Share Posted May 13, 2020 The one on the cache drive Quote Link to comment
trurl Posted May 13, 2020 Share Posted May 13, 2020 Delete the one on disk1 since it doesn't seem to be current. You can try to get the one on cache moved if you want, or you can just forget about it since docker image is easily recreated. appdata and the docker templates on flash are all that's required to get your dockers going again exactly as they were. The templates contain all the mappings, etc of your dockers, and the Previous Apps feature of the Apps page will use those to download the dockers again with all of their settings, and the appdata contains any settings or other data the applications themselves have. Quote Link to comment
Christo Posted May 13, 2020 Author Share Posted May 13, 2020 Thank you ... I deleted the outdated files and ran mover again ... This time it cleared the cache disk completely Removed the ssd disks from the config and did a restart All containers ar present and working fine Quote Link to comment
