March 31, 20215 yr Hello, I recently got setup with my unraid server running 6.9.1, and its been working great for my needs. I installed fix common problems and initially it said everything was fine but after about 24 hours of uptime it said errors were detected. Not sure if this is relevant but hardware on the server is.. Asus z390i Intel 9900k 32gb crucial ballististix 1TB Samsung 980 Nvme 12TB Segate Ironwolf TX401 10Gb network card syslog is attached below syslog infinity-diagnostics-20210331-1414.zip Edited March 31, 20215 yr by reggienaz
March 31, 20215 yr Instead of syslog we prefer Diagnostics which contains syslog, SMART for all disks, and a lot of other things that help make sense of syslog and many other things about your hardware and configuration. Go to Tools - Diagnostics and attach the complete Diagnostics ZIP file to your NEXT post in this thread.
March 31, 20215 yr I'm not sure about those mcelog warnings. That other warning is about getting Notifications setup. You should configure Notifications to alert you immediately by email or other agent as soon as a problem is detected, at least for warnings and alerts.
March 31, 20215 yr Author Here is the diagnostics, and ill get the email alerts setup right now. infinity-diagnostics-20210331-1414.zip
March 31, 20215 yr Author 14 minutes ago, trurl said: I'm not sure about those mcelog warnings. That other warning is about getting Notifications setup. You should configure Notifications to alert you immediately by email or other agent as soon as a problem is detected, at least for warnings and alerts. Sorry for the horrible question but how do I set up notifications? I tried google but couldnt find clear instructions, very new to unraid or linux based systems in general. 4 minutes ago, trurl said: Are you planning to add parity? Yes, that drive gets delivered tomorrow, its a 12tb segate exos Edited March 31, 20215 yr by reggienaz
March 31, 20215 yr 1 minute ago, reggienaz said: how do I set up notifications? Settings - Notifications
March 31, 20215 yr Author 35 minutes ago, trurl said: Settings - Notifications Thanks, got it working with gmail!
March 31, 20215 yr The mce's are somewhat common when the system initializes the cores and affects certain hardware combinations for some reason, and can be safely ignored.
December 27, 20214 yr Author Sorry to revive this. I've started getting similar errors today along with a confirmed crash and reboot. Any help is greatly appreciated. infinity-diagnostics-20211227-1800.zip
December 28, 20214 yr Author Currently reverting settings, Unraid OS, and anything else I've changed since the 5950x upgrade last week and then going to do some more testing and stability monitoring. My current theory is the 3 windows vms running at the time of the crash may need more resources.
January 5, 20224 yr Author Still getting errors, as well as cache drive overheating and complete freezing of the gui. Not sure if the diagnostics help here but any advice is greatly appreciated. infinity-diagnostics-20220105-1540.zip
