Jump to content
Server Rebooting & Fix Common Problems "Hardware Problem"
I've been running into issues with my server in the last month or two where it'll randomly reboot, seemingly at idle most of the time. It can run fine for two weeks or as little as a day. I've done 5 passes of Memtest with no issues, but I'm stumped on what to try next.
Additionally, today I got a warning saying that Fix Common Problems found a hardware issue with my system. I've checked the logs, but I'm honestly not sure what I'm looking at.
Specs:
Unraid 6.9.0
Ryzen 3900x
ASRock X570 Taichi
2x32GB TeamGroup DDR4 3000 (running at DOCP 3000, no other tweaks)
PNY CS3030 2TB for cache, 1TB for Windows VM
RTX 2080 Super for VM
Quadro P4000 for Plex docker
Two 10TB Ironwolf, two 10TB Exos X10
Corsair RM850i
Troubleshooting:
Power Supply Idle Control at Typical
5+ passes of Memtest86
Have a drive that's got failing SMART data; working on replacing it
Edited by RandomPedestrian
Link to comment
IMHO I shouldn't have access to the diagnostics above. Squid should. I shouldn't. If I do, everyone else has?
I'm secure to the point of paranoid (until someone smarter than me kindly points out my errors).
I guess I'm kindly pointing out an error. There are no obvious "Moderators" or "Administrators" here.
LOL... I won't be able to login tomorrow. 😁
6.
Link to comment
6.
Truthfully since it's the first time I'm posting on the forums I just hit Anonymize and uploaded everything for transparency thinking it was fine. Thanks for pointing that out!
Link to comment
8 minutes ago, 6of6 said:
I shouldn't have access to the diagnostics above....There are no obvious "Moderators" or "Administrators" here.
Most people on the forum are users helping other users, even the Moderators.
It is fine, and for many things nobody can help you without diagnostics.
  • Thanks 1
Link to comment
@RandomPedestrian I would never take your information and use it against you. That said, I'm not a moderator or an administrator. I think most people are good, but, as I said...
I shouldn't be able to view your... Ooops... now I can't. Who should I thank for that? I've posted my logs here before.
Thank god it wasn't a #.unraid.net url, right?
6.
Link to comment
  Only 75 emoji are allowed.
  • Create New...
