Jump to content
[Solved] Need help with Upgrading plugins and docker and unraid 6.8.3 to 6.9.2
So, At first I tried to update the plex docker container (something I do regularly) but I found that I was unable to and unraid said version unavailable. So I check the
community applications and update that but failed because it game me some Generic error.
So now I'm thinking maybe my version of unraid isn't being supported by the community so I try to update unraid. but it also failed
plugin: updating: unRAIDServer.plg
plugin: downloading: https://s3.amazonaws.com/dnld.lime-technology.com/stable/unRAIDServer-6.9.2-x86_64.zip ... done
plugin: downloading: https://s3.amazonaws.com/dnld.lime-technology.com/stable/unRAIDServer-6.9.2-x86_64.md5 ... done
writing flash device - please wait...
Archive: /tmp/unRAIDServer.zip
plugin: run failed: /bin/bash retval: 1
not sure what retval: 1 means but im guessing its some setting that making it so I cant make file changes or something... im a suber n00b so...how does I fix dis? and by fix I mean update everything~
PS I have tried unplugging it an plugging it back in but still not a no go. I've attached the syslog if that helps
syslog.txt
Link to comment
May 27 20:53:37 Holodeck emhttpd: error: put_config, 589: Read-only file system (30): fopen: /boot/config/ident.cfg
A reboot should fix this when the system runs the file system checks on the flash drive.
If it doesn't, then pull the flash drive and toss it into another computer and run the file system checks on it.
  • Thanks 1
Link to comment
So none that worked and could not change the read only attribute on the USB so I replaced it with another USB and just copied everything over made it bootable and swap the keys... hopefully this USB will last for more then 12 months *Cross toes*
So mark this one as "Solved" problem is Corrupted USB~~
Link to comment
  • ChatNoir changed the title to [Solved] Need help with Upgrading plugins and docker and unraid 6.8.3 to 6.9.2
  Only 75 emoji are allowed.
  • Create New...
