Parity drive and data drive giving me trouble
Just now, In2Photos said:
The server had been working fine until today since 2015 when I did the conversion.
Do you have a screenshot or diagnostics from when it was working?
  • Replies 97
  • Views 7k
  • In2Photos
    In2Photos
    The new drive arrived. I moved the data from the cloned disk to the drive and copied the data from the 500 GB drive too using Krusader and the videos on Youtube from Space Invader One. All went well.
Can you actually access any data from your server? If the disks were mounted, your user shares should work, and their data would be available.
I have already installed a fresh OS on the flash drive and verified that it boots. I've done basic configuration of things like static IP. Just waiting for the new drives to arrive. Should I go into maintenance mode and check the disks?
Do you have the disk filesystems set as auto or did you force it to XFS? It won't hurt anything to set them as ReiserFS just to see if they mount, just don't ever click the format button if it asks.
No I don't believe I do.
Here is where the system sits right now. I'm basically where I was this morning before checking for updates.
Only one other thread between that one and this, shortly after "conversion", and nothing there to clear this up.
2 minutes ago, trurl said:
Can you start the array and post new diagnostics?
Disk1 unmountable but we already know it is bad and its data may be lost.
User shares are working.
Well, the screenshot proves me wrong on the ReiserFS theory, and it also shows data that you probably want to keep on the 500GB drive, so removing it without copying the data elsewhere probably isn't what you want.
Have you run the filesystem check on disk1 with the new version of Unraid in maintenance mode yet?
And parity disk is bad as we already knew. No point in even having it in the array unless you want to try and fake unraid into emulating disk1 with it.
I have not run filesystem check but I can.
Are we absolutely sure the parity disk is bad?
I can't run the check on disk 1 since it is not mountable.
Even worse than disk1.
Parity:
ID# ATTRIBUTE_NAME          FLAGS    VALUE WORST THRESH FAIL RAW_VALUE
  1 Raw_Read_Error_Rate     POSR-K   200   200   051    -    1871
197 Current_Pending_Sector  -O--CK   196   196   000    -    2164
198 Offline_Uncorrectable   ----CK   198   196   000    -    1264
199 UDMA_CRC_Error_Count    -O--CK   200   198   000    -    5
200 Multi_Zone_Error_Rate   ---R--   054   048   000    -    50224
Disk1:
197 Current_Pending_Sector  -O--CK   196   196   000    -    1160
200 Multi_Zone_Error_Rate   ---R--   199   199   000    -    270
Running filesystem check on unmountable disks is the way to make them mountable. You have to start the array in Maintenance mode.
You can't run the check if it is mounted. It must be unmounted to check it.
OK, so that's not the reason, but I still can't run the check. The option isn't there for disk 1.
1041139568_Annotation2022-06-17165536.thumb.png.f1a2435478e9612b3d8bbfb22209dd04.png1159736065_Annotation2022-06-17165537.thumb.png.b9599325b819e8ff51e5b82b286df400.png
It doesn't know what filesystem check to run since it doesn't know what filesystem it is supposed to be (and neither do we).
Try changing filesystem type to XFS, run a check and post the results, if no good outcome, we can try changing to ReiserFS and see if the results are any better. Leave the -n so we just get a view of what may happen, it won't commit any changes.
3 minutes ago, JonathanM said:
Change the filesystem type on disk 1 to XFS.
But don't start the array or let it format the unmountable disk. Just try to do the check.
Capture the results and post them
Same results as earlier today.
Phase 1 - find and verify superblock... superblock read failed, offset 0, size 524288, ag 0, rval -1 fatal error -- Input/output error
That is with xfs I assume. That might indicate that the disk isn't xfs.
Or it might just mean it is too bad to read.
