Parity drive and data drive giving me trouble
1 minute ago, trurl said:
That is with xfs I assume. That might indicate that the disk isn't xfs.
Correct. So try again with the drive as reiserfs?
Edited by In2Photos
  • Replies 97
  • Views 7k
  • In2Photos
    In2Photos
    The new drive arrived. I moved the data from the cloned disk to the drive and copied the data from the 500 GB drive too using Krusader and the videos on Youtube from Space Invader One. All went well.
6 hours ago, JorgeB said:
cloning disk1 to a new disk with ddrescue to try and recover as much data as possible
Maybe this is the way forward. At least we would have a good disk to try repair on.
And changing it to reiserfs I got this:
reiserfsck 3.6.27
Will read-only check consistency of the filesystem on /dev/md1 Will put log info to 'stdout'
The problem has occurred looks like a hardware problem. If you have bad blocks, we advise you to get a new hard drive, because once you get one bad block that the disk drive internals cannot hide from your sight,the chances of getting more are generally said to become much higher (precise statistics are unknown to us), and this disk drive is probably not expensive enough for you to you to risk your time and data on it. If you don't want to follow that follow that advice then if you have just a few bad blocks, try writing to the bad blocks and see if the drive remaps the bad blocks (that means it takes a block it has in reserve and allocates it for use for of that block number). If it cannot remap the block, use badblock option (-B) with reiserfs utils to handle this block correctly. bread: Cannot read the block (2): (Input/output error).
Well, only 1 of the 2 drives showed up tonight. I'm running ddrescue now, cloning the 1.5TB drive. This might take a while. It's been running for almost 2 hours and is only 8.5% complete on Pass 1.
9 hours ago, trurl said:
-- Input/output error
This indicates that xfs_repair is aborting due to a disk read error, xfs_repair won't work in a failing disk, you can clone the disk first with ddrescue then run xfs_repair.
Woke up this morning and expected it to be much further away from completion. Also expected a lot more errors. I realize it's only pass 1 but 0 bad areas and only 3 read errors?
Edited by In2Photos
spelling
That's good news.
When it finishes should I try to mount it? Or run a file check in maintenance mode first?
The replacement is showing as a new disk. Should I remove the bad disk from the array before starting maintenance mode and checking the filesystem on the new disk?
While there's no parity it's not a problem, if you then need to remove a disk just do a new config, note that after parity is assigned any new data disk will be cleared (erased) first.
ddrescue is finished. here were the results.
Filesystem check is still going, but here is what it looks like so far:
No luck on the file check. Do I try to run it again and repair it?
Please post the full command did you used to run xfs_repair.
I haven't done it. I'm hoping for others with more knowledge to lead me in the right direction. What do you suggest?
Sorry, that was a stupid question, you're not using the command line, is that filesystem check screenshot from UD?
No, it was from the webgui using maintenance mode.
Cloned disk won't mount in the array because it's larger than the original, but a filesystem check will still work, let it finish to see if it can find a backup superblock, strange if all are damaged, failing that unassign the disk and try to mount it with UD to see what fs error you get.
The filesystem check ran for hours and never found anything so I'll try UD.
I installed the UD plugin and tried to mount the drive. On my console screen I get the following.PXL_20220619_124946706_MP.thumb.jpg.8b3aee9593b54ca407604da68c200944.jpg
Result will likely be the same but try checking filesystem again, with UD, click on the highlighted area:
Tried to take a screenshot remotely. Not the best but here's the result.Screenshot_20220619-114115.thumb.png.577abab30218bbdfe458793642cd8fa8.png
That's better, at least there's a fix option, click on "run with correct flag"
Ok. What next? See if it mounts?
59 minutes ago, In2Photos said:
See if it mounts?
Yep, with UD
