Jump to content
(Solved) Slow write speed to NVME cache drive on 10g network, possible network issue?
poto2
Go to solution Solved by poto2,
I'm seeing slower-than-expected copy speeds between UnRaid NVME cache drive and Truenas zfs array.
Copies from UnRaid>>TrueNAS proceed at a steady 445MB/s, however copies from TrueNAS>>UnRaid start out around 700MB/s, then drop to steady 200MB/s.
Iperf3 reflects same speed discrepancy - traffic to TrueNAS maxes out 10gb connection, but traffic to UnRaid peaks at 2.8Gbps.
Direct benchmarks of UnRaid & TrueNAS perform as expected, leading me to believe I have a networking issue.
I've attached screenshots of steps taken so far, as well as current diagnostics.  I don't see any cpu cores at 100% during transfers.  Network cables are Cat5e, 2m or less.
If anyone with experience troubleshooting could take a look, I would appreciate it.
Cheers,
John
iperf3.txt truenas-02 fio ssd array.txt unraid-one-diagnostics-20220906-1342.zip
Link to comment
Still trying to eliminate possible problems here.  Tried the following:
- changed nic port
- changed switch port
- changed network cable
- removed SMB multi-channel command from "SMB Extras", and made sure "Enable SMB Multi Channel" checked "No" in SMB Settings
- changed nic
- reboot
Each run of iperf3 showed UnRaid>>TrueNAS maxing out 10Gb connection, but TrueNAS to UnRaid peaking around  2.8Gbps.
AFAIK I'm using default network configuration, and in-box nic driver, really stumped here.
root@TrueNAS-02[~]# iperf3 -c 192.168.1.162 -P 4 -i 30 -t 30 -R
Connecting to host 192.168.1.162, port 5201
Reverse mode, remote host 192.168.1.162 is sending
[  5] local 192.168.1.160 port 28353 connected to 192.168.1.162 port 5201
[  7] local 192.168.1.160 port 17600 connected to 192.168.1.162 port 5201
[  9] local 192.168.1.160 port 35904 connected to 192.168.1.162 port 5201
[ 11] local 192.168.1.160 port 34427 connected to 192.168.1.162 port 5201
[ ID] Interval           Transfer     Bitrate         Retr  Cwnd
[  5]   0.00-30.00  sec  2.49 GBytes   712 Mbits/sec
[  7]   0.00-30.00  sec  2.58 GBytes   737 Mbits/sec
[  9]   0.00-30.00  sec  2.61 GBytes   749 Mbits/sec
[ 11]   0.00-30.00  sec  2.67 GBytes   764 Mbits/sec
[SUM]   0.00-30.00  sec  10.3 GBytes  2.96 Gbits/sec
[  5]   0.00-30.13  sec  2.49 GBytes   710 Mbits/sec  134864             sender
[  5]   0.00-30.00  sec  2.49 GBytes   712 Mbits/sec                  receiver
[  7]   0.00-30.13  sec  2.58 GBytes   735 Mbits/sec  131587             sender
[  7]   0.00-30.00  sec  2.58 GBytes   737 Mbits/sec                  receiver
[  9]   0.00-30.13  sec  2.62 GBytes   746 Mbits/sec  131321             sender
[  9]   0.00-30.00  sec  2.61 GBytes   749 Mbits/sec                  receiver
[ 11]   0.00-30.13  sec  2.67 GBytes   761 Mbits/sec  131679             sender
[ 11]   0.00-30.00  sec  2.67 GBytes   764 Mbits/sec                  receiver
[SUM]   0.00-30.13  sec  10.4 GBytes  2.95 Gbits/sec  529451             sender
[SUM]   0.00-30.00  sec  10.3 GBytes  2.96 Gbits/sec                  receiver
iperf Done.
[  5] local 192.168.1.160 port 21998 connected to 192.168.1.162 port 5201
[  7] local 192.168.1.160 port 20626 connected to 192.168.1.162 port 5201
[  9] local 192.168.1.160 port 50486 connected to 192.168.1.162 port 5201
[ 11] local 192.168.1.160 port 17773 connected to 192.168.1.162 port 5201
[  5]   0.00-30.00  sec  8.50 GBytes  2.43 Gbits/sec  160    113 KBytes
[  7]   0.00-30.00  sec  7.52 GBytes  2.15 Gbits/sec  149    142 KBytes
[  9]   0.00-30.00  sec  7.74 GBytes  2.22 Gbits/sec  145    162 KBytes
[ 11]   0.00-30.00  sec  8.63 GBytes  2.47 Gbits/sec  143    174 KBytes
[SUM]   0.00-30.00  sec  32.4 GBytes  9.28 Gbits/sec  597
[  5]   0.00-30.00  sec  8.50 GBytes  2.43 Gbits/sec  160             sender
[  5]   0.00-30.12  sec  8.50 GBytes  2.42 Gbits/sec                  receiver
[  7]   0.00-30.00  sec  7.52 GBytes  2.15 Gbits/sec  149             sender
[  7]   0.00-30.12  sec  7.52 GBytes  2.14 Gbits/sec                  receiver
[  9]   0.00-30.00  sec  7.74 GBytes  2.22 Gbits/sec  145             sender
[  9]   0.00-30.12  sec  7.74 GBytes  2.21 Gbits/sec                  receiver
[ 11]   0.00-30.00  sec  8.63 GBytes  2.47 Gbits/sec  143             sender
Link to comment
Eliminating TrueNAS from the equation probably a good idea!  Iperf3 bare-metal Win10 PC>>UnRaid much better, 9Gbps from UR, 6Gbps to UR w/4 streams.
This is from bare-metal Win10 PC, 10GB nic, Intel NVME drive.
perf313>iperf3 -c unraid-one -P 4 -R
Connecting to host unraid-one, port 5201
Reverse mode, remote host unraid-one is sending
[  4] local 192.168.1.194 port 50573 connected to 192.168.1.162 port 5201
[  6] local 192.168.1.194 port 50574 connected to 192.168.1.162 port 5201
[  8] local 192.168.1.194 port 50575 connected to 192.168.1.162 port 5201
[ 10] local 192.168.1.194 port 50576 connected to 192.168.1.162 port 5201
[ ID] Interval           Transfer     Bandwidth
[  4]   0.00-1.00   sec   262 MBytes  2.20 Gbits/sec
[  6]   0.00-1.00   sec   255 MBytes  2.14 Gbits/sec
[  8]   0.00-1.00   sec   230 MBytes  1.93 Gbits/sec
[ 10]   0.00-1.00   sec   240 MBytes  2.01 Gbits/sec
[SUM]   0.00-1.00   sec   987 MBytes  8.28 Gbits/sec
[  4]   1.00-2.00   sec   277 MBytes  2.33 Gbits/sec
[  6]   1.00-2.00   sec   277 MBytes  2.33 Gbits/sec
[  8]   1.00-2.00   sec   260 MBytes  2.18 Gbits/sec
[ 10]   1.00-2.00   sec   270 MBytes  2.26 Gbits/sec
[SUM]   1.00-2.00   sec  1.06 GBytes  9.10 Gbits/sec
[  4]   2.00-3.00   sec   279 MBytes  2.34 Gbits/sec
[  6]   2.00-3.00   sec   253 MBytes  2.12 Gbits/sec
[  8]   2.00-3.00   sec   311 MBytes  2.61 Gbits/sec
[ 10]   2.00-3.00   sec   282 MBytes  2.37 Gbits/sec
[SUM]   2.00-3.00   sec  1.10 GBytes  9.44 Gbits/sec
[  4]   3.00-4.00   sec   304 MBytes  2.55 Gbits/sec
[  6]   3.00-4.00   sec   286 MBytes  2.40 Gbits/sec
[  8]   3.00-4.00   sec   274 MBytes  2.30 Gbits/sec
[ 10]   3.00-4.00   sec   262 MBytes  2.20 Gbits/sec
[SUM]   3.00-4.00   sec  1.10 GBytes  9.44 Gbits/sec
[  4]   4.00-5.00   sec   277 MBytes  2.32 Gbits/sec
[  6]   4.00-5.00   sec   284 MBytes  2.39 Gbits/sec
[  8]   4.00-5.00   sec   289 MBytes  2.42 Gbits/sec
[ 10]   4.00-5.00   sec   275 MBytes  2.30 Gbits/sec
[SUM]   4.00-5.00   sec  1.10 GBytes  9.43 Gbits/sec
[  4]   5.00-6.00   sec   268 MBytes  2.25 Gbits/sec
[  6]   5.00-6.00   sec   270 MBytes  2.26 Gbits/sec
[  8]   5.00-6.00   sec   312 MBytes  2.62 Gbits/sec
[ 10]   5.00-6.00   sec   275 MBytes  2.30 Gbits/sec
[SUM]   5.00-6.00   sec  1.10 GBytes  9.44 Gbits/sec
[  4]   6.00-7.00   sec   274 MBytes  2.30 Gbits/sec
[  6]   6.00-7.00   sec   274 MBytes  2.30 Gbits/sec
[  8]   6.00-7.00   sec   288 MBytes  2.42 Gbits/sec
[ 10]   6.00-7.00   sec   289 MBytes  2.43 Gbits/sec
[SUM]   6.00-7.00   sec  1.10 GBytes  9.44 Gbits/sec
[  4]   7.00-8.00   sec   272 MBytes  2.28 Gbits/sec
[  6]   7.00-8.00   sec   300 MBytes  2.51 Gbits/sec
[  8]   7.00-8.00   sec   285 MBytes  2.39 Gbits/sec
[ 10]   7.00-8.00   sec   269 MBytes  2.26 Gbits/sec
[SUM]   7.00-8.00   sec  1.10 GBytes  9.44 Gbits/sec
[  4]   8.00-9.00   sec   295 MBytes  2.47 Gbits/sec
[  6]   8.00-9.00   sec   284 MBytes  2.38 Gbits/sec
[  8]   8.00-9.00   sec   274 MBytes  2.30 Gbits/sec
[ 10]   8.00-9.00   sec   273 MBytes  2.29 Gbits/sec
[SUM]   8.00-9.00   sec  1.10 GBytes  9.44 Gbits/sec
[  4]   9.00-10.00  sec   276 MBytes  2.32 Gbits/sec
[  6]   9.00-10.00  sec   290 MBytes  2.43 Gbits/sec
[  8]   9.00-10.00  sec   269 MBytes  2.26 Gbits/sec
[ 10]   9.00-10.00  sec   290 MBytes  2.43 Gbits/sec
[SUM]   9.00-10.00  sec  1.10 GBytes  9.44 Gbits/sec
[ ID] Interval           Transfer     Bandwidth       Retr
[  4]   0.00-10.00  sec  2.72 GBytes  2.34 Gbits/sec    0             sender
[  4]   0.00-10.00  sec  2.72 GBytes  2.34 Gbits/sec                  receiver
[  6]   0.00-10.00  sec  2.71 GBytes  2.33 Gbits/sec    0             sender
[  6]   0.00-10.00  sec  2.71 GBytes  2.33 Gbits/sec                  receiver
[  8]   0.00-10.00  sec  2.73 GBytes  2.35 Gbits/sec    0             sender
[  8]   0.00-10.00  sec  2.73 GBytes  2.34 Gbits/sec                  receiver
[ 10]   0.00-10.00  sec  2.66 GBytes  2.29 Gbits/sec    0             sender
[ 10]   0.00-10.00  sec  2.66 GBytes  2.29 Gbits/sec                  receiver
[SUM]   0.00-10.00  sec  10.8 GBytes  9.30 Gbits/sec    0             sender
[SUM]   0.00-10.00  sec  10.8 GBytes  9.29 Gbits/sec                  receiver
iperf Done.
C:\download\iperf313>iperf3 -c unraid-one -P 4
[  4] local 192.168.1.194 port 50578 connected to 192.168.1.162 port 5201
[  6] local 192.168.1.194 port 50579 connected to 192.168.1.162 port 5201
[  8] local 192.168.1.194 port 50580 connected to 192.168.1.162 port 5201
[ 10] local 192.168.1.194 port 50581 connected to 192.168.1.162 port 5201
[  4]   0.00-1.00   sec   180 MBytes  1.51 Gbits/sec
[  6]   0.00-1.00   sec   180 MBytes  1.51 Gbits/sec
[  8]   0.00-1.00   sec   201 MBytes  1.69 Gbits/sec
[ 10]   0.00-1.00   sec   174 MBytes  1.46 Gbits/sec
[SUM]   0.00-1.00   sec   735 MBytes  6.17 Gbits/sec
[  4]   1.00-2.00   sec   166 MBytes  1.39 Gbits/sec
[  6]   1.00-2.00   sec   185 MBytes  1.55 Gbits/sec
[ 10]   1.00-2.00   sec   208 MBytes  1.75 Gbits/sec
[SUM]   1.00-2.00   sec   820 MBytes  6.88 Gbits/sec
[  4]   2.00-3.00   sec   144 MBytes  1.21 Gbits/sec
[  6]   2.00-3.00   sec   180 MBytes  1.51 Gbits/sec
[  8]   2.00-3.00   sec   180 MBytes  1.51 Gbits/sec
[ 10]   2.00-3.00   sec   180 MBytes  1.51 Gbits/sec
[SUM]   2.00-3.00   sec   684 MBytes  5.74 Gbits/sec
[  4]   3.00-4.00   sec   182 MBytes  1.53 Gbits/sec
[  6]   3.00-4.00   sec   209 MBytes  1.75 Gbits/sec
[  8]   3.00-4.00   sec   179 MBytes  1.50 Gbits/sec
[ 10]   3.00-4.00   sec   164 MBytes  1.38 Gbits/sec
[SUM]   3.00-4.00   sec   734 MBytes  6.16 Gbits/sec
[  4]   4.00-5.00   sec   150 MBytes  1.26 Gbits/sec
[  6]   4.00-5.00   sec   162 MBytes  1.36 Gbits/sec
[  8]   4.00-5.00   sec   189 MBytes  1.59 Gbits/sec
[ 10]   4.00-5.00   sec   222 MBytes  1.87 Gbits/sec
[SUM]   4.00-5.00   sec   724 MBytes  6.07 Gbits/sec
[  4]   5.00-6.00   sec   167 MBytes  1.40 Gbits/sec
[  6]   5.00-6.00   sec   174 MBytes  1.46 Gbits/sec
[  8]   5.00-6.00   sec   172 MBytes  1.45 Gbits/sec
[ 10]   5.00-6.00   sec   205 MBytes  1.72 Gbits/sec
[SUM]   5.00-6.00   sec   718 MBytes  6.03 Gbits/sec
[  4]   6.00-7.00   sec   152 MBytes  1.28 Gbits/sec
[  6]   6.00-7.00   sec   190 MBytes  1.60 Gbits/sec
[  8]   6.00-7.00   sec   211 MBytes  1.77 Gbits/sec
[ 10]   6.00-7.00   sec   196 MBytes  1.64 Gbits/sec
[SUM]   6.00-7.00   sec   750 MBytes  6.29 Gbits/sec
[  4]   7.00-8.00   sec   183 MBytes  1.53 Gbits/sec
[  6]   7.00-8.00   sec   175 MBytes  1.46 Gbits/sec
[  8]   7.00-8.00   sec   205 MBytes  1.72 Gbits/sec
[ 10]   7.00-8.00   sec   196 MBytes  1.64 Gbits/sec
[SUM]   7.00-8.00   sec   758 MBytes  6.36 Gbits/sec
[  4]   8.00-9.00   sec   223 MBytes  1.87 Gbits/sec
[  6]   8.00-9.00   sec   211 MBytes  1.77 Gbits/sec
[  8]   8.00-9.00   sec   160 MBytes  1.35 Gbits/sec
[ 10]   8.00-9.00   sec   162 MBytes  1.36 Gbits/sec
[SUM]   8.00-9.00   sec   756 MBytes  6.35 Gbits/sec
[  4]   9.00-10.00  sec   142 MBytes  1.19 Gbits/sec
[  6]   9.00-10.00  sec   167 MBytes  1.40 Gbits/sec
[  8]   9.00-10.00  sec   199 MBytes  1.67 Gbits/sec
[ 10]   9.00-10.00  sec   169 MBytes  1.42 Gbits/sec
[SUM]   9.00-10.00  sec   678 MBytes  5.69 Gbits/sec
[  4]   0.00-10.00  sec  1.65 GBytes  1.42 Gbits/sec                  sender
[  4]   0.00-10.00  sec  1.65 GBytes  1.42 Gbits/sec                  receiver
[  6]   0.00-10.00  sec  1.79 GBytes  1.54 Gbits/sec                  sender
[  6]   0.00-10.00  sec  1.79 GBytes  1.54 Gbits/sec                  receiver
[  8]   0.00-10.00  sec  1.91 GBytes  1.64 Gbits/sec                  sender
[  8]   0.00-10.00  sec  1.91 GBytes  1.64 Gbits/sec                  receiver
[ 10]   0.00-10.00  sec  1.83 GBytes  1.57 Gbits/sec                  sender
[ 10]   0.00-10.00  sec  1.83 GBytes  1.57 Gbits/sec                  receiver
[SUM]   0.00-10.00  sec  7.19 GBytes  6.17 Gbits/sec                  sender
[SUM]   0.00-10.00  sec  7.18 GBytes  6.17 Gbits/sec                  receiver
iperf Done.
File transfers are still puzzling, though.  UR to WS is as expected 500-700MB/s, but WS to UR starts out around 600MB/s, then drops to steady 200MB/s for remainder of transfer.
2026976551_copyURtoWS.jpg.d14445aac9e8493a649a5ce47017e421.jpg402879074_copyWStoUR.jpg.b85158d9357e705d30a0acb8f107373e.jpg
I tried some additonal steps to isolate problem:
- reset UR network settings to "default"
- enabled disk shares & copied direct to disk vs user share
- added different NVME drive to UR as 2nd cache pool & tried file copies there
All trials continued to show writes to UR cache drive/s being throttled to around 200MB/s.
The only thing I haven't measured is internal write speed of NVME cache.  I think the diskspeed docker only tests writes.  Ran fio sequential write against current and added nvme cache drives.  Both results seem reasonable.
root@unraid-one:~# fio -direct=1 -iodepth=128 -rw=write -ioengine=libaio -bs=128k -numjobs=1 -time_based=1 -runtime=60 -group_reporting -filename=/dev/nvme1n1 -name=test
test: (g=0): rw=write, bs=(R) 128KiB-128KiB, (W) 128KiB-128KiB, (T) 128KiB-128KiB, ioengine=libaio, iodepth=128
fio-3.23
Starting 1 process
Jobs: 1 (f=1): [W(1)][100.0%][w=626MiB/s][w=5010 IOPS][eta 00m:00s]
test: (groupid=0, jobs=1): err= 0: pid=21979: Thu Sep  8 11:24:56 2022
  write: IOPS=5028, BW=629MiB/s (659MB/s)(36.9GiB/60030msec); 0 zone resets
    slat (nsec): min=3327, max=60505, avg=9983.52, stdev=5930.32
    clat (usec): min=333, max=58025, avg=25441.33, stdev=10088.11
     lat (usec): min=340, max=58032, avg=25451.49, stdev=10088.09
    clat percentiles (usec):
     |  1.00th=[ 6915],  5.00th=[ 9110], 10.00th=[12125], 20.00th=[15664],
     | 30.00th=[18482], 40.00th=[21365], 50.00th=[25297], 60.00th=[29230],
     | 70.00th=[32113], 80.00th=[35390], 90.00th=[39060], 95.00th=[41157],
     | 99.00th=[44827], 99.50th=[46400], 99.90th=[49546], 99.95th=[50594],
     | 99.99th=[52167]
   bw (  KiB/s): min=608512, max=690944, per=100.00%, avg=644709.46, stdev=18437.83, samples=119
   iops        : min= 4754, max= 5398, avg=5036.77, stdev=144.05, samples=119
  lat (usec)   : 500=0.01%, 750=0.01%, 1000=0.01%
  lat (msec)   : 2=0.01%, 4=0.02%, 10=6.38%, 20=28.64%, 50=64.87%
  lat (msec)   : 100=0.08%
  cpu          : usr=4.09%, sys=5.33%, ctx=286419, majf=0, minf=10
  IO depths    : 1=0.1%, 2=0.1%, 4=0.1%, 8=0.1%, 16=0.1%, 32=0.1%, >=64=100.0%
     submit    : 0=0.0%, 4=100.0%, 8=0.0%, 16=0.0%, 32=0.0%, 64=0.0%, >=64=0.0%
     complete  : 0=0.0%, 4=100.0%, 8=0.0%, 16=0.0%, 32=0.0%, 64=0.0%, >=64=0.1%
     issued rwts: total=0,301881,0,0 short=0,0,0,0 dropped=0,0,0,0
     latency   : target=0, window=0, percentile=100.00%, depth=128
Run status group 0 (all jobs):
  WRITE: bw=629MiB/s (659MB/s), 629MiB/s-629MiB/s (659MB/s-659MB/s), io=36.9GiB (39.6GB), run=60030-60030msec
Disk stats (read/write):
  nvme1n1: ios=0/603433, merge=0/0, ticks=0/15330361, in_queue=15330361, util=100.00%
root@unraid-one:~# fio -direct=1 -iodepth=128 -rw=write -ioengine=libaio -bs=128k -numjobs=1 -time_based=1 -runtime=60 -group_reporting -filename=/dev/nvme0n1 -name=test
fio-3.23
Starting 1 process
Jobs: 1 (f=1): [W(1)][100.0%][w=1806MiB/s][w=14.4k IOPS][eta 00m:00s]
test: (groupid=0, jobs=1): err= 0: pid=979: Thu Sep  8 11:27:07 2022
  write: IOPS=12.8k, BW=1605MiB/s (1683MB/s)(94.1GiB/60006msec); 0 zone resets
    slat (nsec): min=3089, max=70086, avg=7303.86, stdev=4234.12
    clat (usec): min=187, max=86843, avg=9958.33, stdev=7533.10
     lat (usec): min=192, max=86848, avg=9965.76, stdev=7533.19
     |  1.00th=[  379],  5.00th=[  603], 10.00th=[  857], 20.00th=[ 3032],
     | 30.00th=[ 6390], 40.00th=[ 7832], 50.00th=[ 8848], 60.00th=[ 9896],
     | 70.00th=[12387], 80.00th=[16909], 90.00th=[18482], 95.00th=[19530],
     | 99.00th=[33817], 99.50th=[46924], 99.90th=[64226], 99.95th=[69731],
     | 99.99th=[76022]
   bw (  MiB/s): min=  577, max= 1808, per=100.00%, avg=1606.06, stdev=328.10, samples=119
   iops        : min= 4616, max=14466, avg=12848.50, stdev=2624.81, samples=119
  lat (usec)   : 250=0.08%, 500=2.80%, 750=4.74%, 1000=5.09%
  lat (msec)   : 2=6.73%, 4=0.82%, 10=40.31%, 20=35.23%, 50=3.81%
  lat (msec)   : 100=0.39%
  cpu          : usr=7.38%, sys=8.44%, ctx=548065, majf=0, minf=14
     issued rwts: total=0,770638,0,0 short=0,0,0,0 dropped=0,0,0,0
  WRITE: bw=1605MiB/s (1683MB/s), 1605MiB/s-1605MiB/s (1683MB/s-1683MB/s), io=94.1GiB (101GB), run=60006-60006msec
  nvme0n1: ios=45/768933, merge=0/0, ticks=9/7655367, in_queue=7655375, util=99.99%
root@unraid-one:~#
I don't think the switch is bad, its an unmanaged netgear 8-port 10g copper, XS708.  I could buy some cat6 cables, but hate to throw $$ at it without exhausting other options.
Thanks for looking at this anyway, I'm open to any/all suggestions.
Link to comment
Understood on the iperf streams, just making sure total bandwidth was available.
The Win10<<>>UR file copies were done using user share.
I also cleared and reformatted cache drive, then tried copying again via user share.  Same result: UR>>Win10 700MB/s, Win10>>UR 600MB/s for a couple seconds, then 200MB/s.
Grasping for straws, also checked router for duplicate IP addresses, but nothing out of the ordinary there.  And restarted switches.
Edited by poto2
Link to comment
Something is definitely wrong, nowhere near 10g with single-stream iperf3.
C:\download>cd iperf313
[  4] local 192.168.1.194 port 62698 connected to 192.168.1.162 port 5201
[  4]   0.00-1.00   sec   169 MBytes  1.42 Gbits/sec
[  4]   1.00-2.00   sec   161 MBytes  1.35 Gbits/sec
[  4]   2.00-3.00   sec   166 MBytes  1.39 Gbits/sec
[  4]   3.00-4.00   sec   176 MBytes  1.47 Gbits/sec
[  4]   4.00-5.00   sec   146 MBytes  1.23 Gbits/sec
[  4]   5.00-6.00   sec   169 MBytes  1.41 Gbits/sec
[  4]   6.00-7.00   sec   200 MBytes  1.67 Gbits/sec
[  4]   7.00-8.00   sec   176 MBytes  1.48 Gbits/sec
[  4]   8.00-9.00   sec   144 MBytes  1.20 Gbits/sec
[  4]   9.00-10.00  sec   170 MBytes  1.43 Gbits/sec
[  4]   0.00-10.00  sec  1.64 GBytes  1.41 Gbits/sec                  sender
[  4]   0.00-10.00  sec  1.64 GBytes  1.41 Gbits/sec                  receiver
iperf Done.
C:\download\iperf313>iperf3 -c unraid-one -R
[  4] local 192.168.1.194 port 62700 connected to 192.168.1.162 port 5201
[  4]   0.00-1.00   sec   552 MBytes  4.63 Gbits/sec
[  4]   1.00-2.00   sec   544 MBytes  4.56 Gbits/sec
[  4]   2.00-3.00   sec   547 MBytes  4.59 Gbits/sec
[  4]   3.00-4.00   sec   540 MBytes  4.53 Gbits/sec
[  4]   4.00-5.00   sec   544 MBytes  4.56 Gbits/sec
[  4]   5.00-6.00   sec   542 MBytes  4.55 Gbits/sec
[  4]   6.00-7.00   sec   541 MBytes  4.54 Gbits/sec
[  4]   7.00-8.00   sec   543 MBytes  4.56 Gbits/sec
[  4]   8.00-9.00   sec   546 MBytes  4.58 Gbits/sec
[  4]   9.00-10.00  sec   549 MBytes  4.60 Gbits/sec
[  4]   0.00-10.00  sec  5.32 GBytes  4.57 Gbits/sec    0             sender
[  4]   0.00-10.00  sec  5.32 GBytes  4.57 Gbits/sec                  receiver
iperf Done.
Link to comment
Did a bit more digging, and this forum already had the answer for the Windows PC network throttling.
Windows nic driver setting for interrupt moderation "disabled" resolved this issue.
For UnRaid, what worked for me was adjusting interrupt coalescing.  My nic driver didn't allow tx-usecs adjustment, but rx-usecs increase did the trick.
root@unraid-one:~# ethtool -C eth0 rx-usecs 200
root@unraid-one:~# ethtool -c eth0
Coalesce parameters for eth0:
Adaptive RX: n/a  TX: n/a
stats-block-usecs: n/a
sample-interval: n/a
pkt-rate-low: n/a
pkt-rate-high: n/a
rx-usecs: 200
rx-frames: n/a
rx-usecs-irq: n/a
rx-frames-irq: n/a
tx-usecs: 0
tx-frames: n/a
tx-usecs-irq: n/a
tx-frames-irq: n/a
rx-usecs-low: n/a
rx-frame-low: n/a
tx-usecs-low: n/a
tx-frame-low: n/a
rx-usecs-high: n/a
rx-frame-high: n/a
tx-usecs-high: n/a
tx-frame-high: n/a
CQE mode RX: n/a  TX: n/a
root@unraid-one:~#
That change increased file copy speed from Win PC or TrueNAS to UnRaid cache drive quite a bit.
I've a bit more reading to figure out how to make change permanent (user scripts?), and equivalent adjustment for TrueNAS, but problem solved AFAIK.
Thanks to @JorgeB for suggesting areas to investigate.
  • Like 3
  • Thanks 1
Link to comment
  • poto2 changed the title to (Solved) Slow write speed to NVME cache drive on 10g network, possible network issue?
  • 4 months later...
For me, all I had to do was Disable Interrupt Moderation and I got my nvme speeds back.
I did not have to adjust Interrupt coalescing.
Thank you for posting the solution.
Link to comment
  Only 75 emoji are allowed.
  • Create New...
