Jump to content
NerdTools Has Warning From Fix Common Problems!
Go to solution Solved by itimpi,
Hello!
In the wake of NerdPack not working, there was a post about a successor called NerdTools. However once I installed it, and installed a few packaged within the plugin, I noticed this warning in Fix Common Problems:
"Extra packages being installed were found in /boot/extra. It is not recommended to install any packages this way."
Upon inspection, it looks like NerdTools is putting the packages I installed into this folder. Please advise on what to do. Thank you!
Link to comment
  Only 75 emoji are allowed.
  • Create New...
