DanielPT Posted December 12, 2022 Share Posted December 12, 2022 HI all I been using Unraid for 2 months. Very happy! But i was on a Windows server 2012r2 before. When a power failure happend my windows server just booted again. 1 time i got some errros on a WD RED Pro. But what about unraid ? Can it handel it? I dont feel (money) to buy a UPS right now Thanks! Quote Link to comment
Kilrah Posted December 12, 2022 Share Posted December 12, 2022 Just like any system, it's going to be sheer luck whether the loss happens while everyting is idle or during a critical write. Unraid will do a full parity check after any power loss to verify the drives didn't get out of sync, but individual files / filesystems can still get corrupted. 2 Quote Link to comment
itimpi Posted December 12, 2022 Share Posted December 12, 2022 It is highly recommended that you invest in a UPS to minimise the chances of a power failure having undesirable consequences. You then configure the Unraid server to tidily shut itself down if the power goes off for more than a few minutes. Quote Link to comment
DanielPT Posted December 12, 2022 Author Share Posted December 12, 2022 1 hour ago, itimpi said: It is highly recommended that you invest in a UPS to minimise the chances of a power failure having undesirable consequences. You then configure the Unraid server to tidily shut itself down if the power goes off for more than a few minutes. I dosent happens very often but in the world today it cut happend Quote Link to comment
Hoopster Posted December 12, 2022 Share Posted December 12, 2022 3 hours ago, DanielPT said: But what about unraid ? Can it handel it? I dont feel (money) to buy a UPS right now As has already been mentioned, the timing of the power loss determines whether or not unRAID can "handle it." Often, the unRAID boot flash can be corrupted (usually fixed by a chkdsk in Windows) and data corruption in the array could also result. A sudden power loss will result in an unclean shutdown and parity check when the array is restarted. In the worst case, a sudden power loss has been known to damage components such as the motherboard, RAM, disk drives, etc. A UPS may be one of the better investments you can make with a server that stores important data. Sudden power cuts happen very infrequently in my area but I have had two this year. Being on a UPS allowed my server to shut down gracefully with no damage and avoided the unclean shutdown/parity check. A UPS is like insurance for your home. You don't have to have it, but if you experience some kind of loss, you are sure glad you had insurance or are left wondering why you did not purchase it. Your choice, of course. 1 Quote Link to comment
