Rebuilding on a disk with "Unmountable: wrong or no file system" and 3 other disks millions of read errors during parity check
Solved by JorgeB
Another command line
xfs_repair -L /dev/md19p1
  • Replies 51
  • Views 2.1k
  • Wish me luck! rebuild has started with a now mountable, formatted disk. Thank you guys for all the help, I will update this with any new info and/or mark any solution.
  • yes
Phase 5 - rebuild AG headers and trees...
        - reset superblock...
Phase 6 - check inode connectivity...
        - resetting contents of realtime bitmap and summary inodes
        - traversing filesystem ...
entry "A Shot Through the Wall (2022) {imdb-tt8588414} [WEBDL-1080p][AC3 5.1][h264]-EVO.mkv" in directory inode 135 not consistent with .. value (15032385667) in inode 34359738564, junking entry
entry "A Shot ThroumiHT2BPO3022) {idb-tt8588414} [WEBDL-1080p][AC3 5.1][h264]-EVO.nfo" in directory inode 135 not consistent with .. value (10737418369) in inode 136, junking entry
fixing i8count in inode 135
bad hash table for directory inode 33693602 (no data entry): rebuilding
rebuilding directory inode 33693602
entry "Season 12" in dir ino 2147483794 doesn't have a .. entry, will set it in ino 4294967438.
bad hash table for directory inode 2147483835 (no data entry): rebuilding
rebuilding directory inode 2147483835
bad hash table for directory inode 2165900194 (no data entry): rebuilding
rebuilding directory inode 2165900194
entry ".." in directory inode 2351323147 points to free inode 176, junking entry
bad hash table for directory inode 2351323147 (no data entry): rebuilding
rebuilding directory inode 2351323147
corrupt block 1 in directory inode 4294967424: junking block
entry "Memories of Murder (2003)" in dir ino 4294967424 doesn't have a .. entry, will set it in ino 4294967454.
corrupt block 3 in directory inode 4294967424: junking block
entry "Triangle of Sadness (2022)" in dir ino 4294967424 doesn't have a .. entry, will set it in ino 4294967436.
rebuilding directory inode 4294967424
Metadata corruption detected at 0x47b3d2, inode 0x10000008f dinode
fatal error -- couldn't map inode 4294967439, err = 117
This is the end of the output
Xfs_repair is unable to fix the filesystem, you can try upgrading to 7.1-beta.4 to see if a newer kernel/tools help, if still not, you will need to restore from a backup, or try a file recovery app like UFS explorer.
I do not have any backups of my array, only flash and appdata, and prefer to stay on the stable version of unraid. I don't mind losing some of the data on disk19 as I can get it back pretty easily.
Is there a way to keep whatever is being emulated and get back to a healthy parity/array state even if I lose some of what's on that bad disk19?
Also, thank you for joining in JorgeB, the support from you and trurl has been invaluable!
Not sure I follow, nothing is being emulated from disk19, since it doesn't mount.
Ah maybe I was fooled by the UI
It's emulated, but note no used/free stats for that disk, because it's not mounted:
Understood, if I'm okay losing the ~9tb that's on here, how should I proceed to get the drive working again and parity in a good state?
Would I have to restart the array and format disk19 and allow parity to resync?
Also, should I still be worried about the other drives presenting read errors again? Or was that only an issue because I was rebuilding an unmountable filesystem with bad parity.
Edited by Lean_
Finished the rebuild and format the disk, or vice versa.
Most likely.
Thank you, I am beginning the formatting process
Update:
After formatting the disk and rebuilding/resyncing everything is back to normal in a healthy state, still not sure about the root cause but quite possibly had some weird power issue even though I'm on a UPS since my uptime reset even though I had no NUT reports of an outage.
I reinstalled mover tuning plugin and re-enabled my script that runs "sudo modprobe disktemp" for my coolercontrol docker container to be able to see disk temp sensors
With so many disks I have to wonder about power.
I'm using dual platinum PWS-920P-SQ's.
- I was using a new one ONLY during the rebuild that took the past 2 days.
I wonder if plugging in the second PSU may be the culprit?
is it safe to shutdown with read errors on theses disks? I will unplug the potential bad PSU and monitor disks for a while longer.
yes
Errors look like a power/connection issue, could be a backplane issue for example.
Understood, If I run into more issues on the newer PSU I think the next steps will be swapping out the HBA, and then lastly the backplane since it's the more expensive item.
So, I went 4 days with no errors on a new PSU and decided to try out 'sudo modprobe disktemp' again for my fan controller docker container and I had 2 disks instantly get disabled.
I'm guessing it wasn't the PSU after all and just this module being incompatible
checking the filesystem status of the disks in maintenance mode returns:
Phase 1 - find and verify superblock...
Phase 2 - using internal log
        - zero log...
        - scan filesystem freespace and inode maps...
        - found root inode chunk
Phase 3 - for each AG...
        - scan (but don't clear) agi unlinked lists...
        - process known inodes and perform inode discovery...
        - agno = 0
        - agno = 1
        - agno = 2
        - agno = 3
        - process newly discovered inodes...
Phase 4 - check for duplicate blocks...
        - setting up duplicate extent list...
        - check for inodes claiming duplicate blocks...
        - agno = 0
        - agno = 1
        - agno = 3
        - agno = 2
No modify flag set, skipping phase 5
        - traversal finished ...
        - moving disconnected inodes to lost+found ...
Phase 7 - verify link counts...
No modify flag set, skipping filesystem flush and exiting.
2025-04-1707_34_39-SuperPlex_Main-Brave.thumb.png.bc622bacff9a5eb96bd28712dccad867.png
Am I going to need to rebuild again? ;(
superplex-diagnostics-20250417-0745.zip
The screenshot doesn't show any disks unmountable, just disabled. And I didn't notice anything in syslog that indicated filesystem repair was needed.
4 minutes ago, Lean_ said:
rebuild again?
That is the way you take care of disabled disks.
Will do, thank you guys for all your time and help, much appreciated!
If you do get a disabled disk that is also unmountable, best to repair before rebuild. Otherwise you rebuild an unmountable disk.
