Rebuilding on a disk with "Unmountable: wrong or no file system" and 3 other disks millions of read errors during parity check
Solved by JorgeB
Luckily, they are both mountable and being emulated correctly. Rebuild ETA is 12hrs for these 4tb drives not bad :)
  • Replies 51
  • Views 2.1k
  • Wish me luck! rebuild has started with a now mountable, formatted disk. Thank you guys for all the help, I will update this with any new info and/or mark any solution.
  • yes
Just chiming in here, I see the issue was identified as coming from enabling drivetemp. Another CoolerControl user had essentially the same issue and identified that in versions of Unraid earlier than 7.0.1 there was a kernel bug that caused issues with drivetemp and spun down drives: https://lore.kernel.org/linux-cve-announce/2025012131-CVE-2025-21656-b967@gregkh/T/#u
I've updated the CoolerControl docs to warn users about this issue and sorry you ran into this!
Edited by guniv
