Drive failed during rebuild for a drive I upgraded
I'm assuming this is an issue considering none of the files are in the right place
Edit: I haven't formatted disk3 yet, I might remove the 2TB drive from my PC just to get the files back and shrink the array with the smaller drive later
Edited by peterpeter
  • Replies 56
  • Views 607
Lost+found folder is created when the filesystem repair cannot correctly fix the paths, you can manually examine the files, and then move them accordingly, but that would have already been visible in the emulated disk.
Right, I might just end up clearing out disk2 and working with the backup I had. A lot of the files in lost+found are thumbnails/other things that Immich needs to work that I cannot put back in their places because I do not know where they came from. I might just end up working with the backup and just reuploading the images again.
7 hours ago, peterpeter said:
high-water in Unbalanced where I split my data between a 1TB Drive (the failed one) and this 250GB one
Not sure about how Unbalanced implements that, but Highwater allocation for an Unraid User Share would not have put anything on the smaller drive until the larger drive had gone through half full (500G), then half again (250G), then half again, before it would switch to the smaller drive.
The overall used size of the entire array is 300 something GB, the backup that I have - 500GB. It is very possible I misconfigured something (clearly not for the first time here). And I fucked up the Unbalanced copy process because I fully remember how the 250GB drive was almost full. I'm not blaming Unbalanced at all for this since this is a user error on my part
I managed to get back my things from the backup and if anything is missing - the lost+found data. Thanks to everyone that tried to help (you guys absolutely rock) and I'll know to be more careful with my data next time. You all are amazing <3
Also how am I supposed to close this thread :D
