***GUIDE*** Passthrough Entire PCI USB Controller
So then I suppose even with hostdev you will still have to go through the entire first process of finding out which controller you want?
Yes you still have to do the steps up to and including 9.
  • Replies 509
  • Views 455.8k
  • Baltostar
    Baltostar
    I automated steps 1-9 of this guide.   The output shows USB bus #, PCI Address, and IOMMU group #   Bus 1 PCI 0000:00:1a.0 IOMMU 20     Intel Corp.     Linux Foundation 2.0 root hub Bus 2
  • I believe users with this specific card (Startech PEXUSB3S44V) have no issues passing them to the machine, but have issues once passed to the machine inside the VM. Mine throws a Code 10 error on the
  • Not if you use the xen-pciback.hide= method. You use the PCI number instead of id. So yours will look like below for the last two.  xen-pciback.hide=(0d:00.3)(43:00.3)
Slightly OT, but would hostdev work for gfx cards?
Oops good catch, I was editing the whole first page at a million miles a minute and sort of word vomitted that.
Man you are quick  ;D
Yes :)
Yes :)
Might try in with OSX just for science....
Can someone explain what the difference is between qemu passthrough and hostdev please?  I'm not entirely clear on the use cases for each...
I just edited my post :)
It's the same. The hostdev way is used in the XML and qemu:arg is not a part of the XML. Did that confuse you more maybe?  ::)
No, I've wondered why there are two separate ways to do things, but never given it too much thought.  So basically they're like two routes to the same destination...
No advantages or disadvantages either way?  No reason to choose one over the other?
That was a better explanation than mine :D
As far as I know there are no differences other than hostdev being easier and the right way to do it as it's the way I do it  ;D
The only thing I can think of is your OSX VM needs qemu:arg to work.
Yes :)
Let me know what you find!
So using it for USB, the machine boots but doesn't recognise inputs from my mouse or keyboard.  Using it for GFX, and it boots and to all intents and purposes via the Unraid webui, looks like it's working, but I just get a black screen...
Interesting nonetheless..  ::)
Hi again,
I want to ask a question while it is still fresh in my mind. I find that out of 10 USB socket that the forwarding has killed all but two USB headers which were on the back of the server. I knew this was going to be the case but I am now rethinking this and may wish to switch them around.
Can you give me guidance/instruction on how to go back to ground zero with the re-assigning the USB (group 1) back to the server and not the VM? I'm not concerned about the changing the XML.
Advanced thanks
Hi again,
Advanced thanks
Reboot Unraid after the relevant bits of the XML are deleted.  Start again...
Hi again,
Advanced thanks
So this will revert step 9 in your instructions?
Thanks
Hi again,
Advanced thanks
Thanks
Not quite sure I follow...
Step 9 is just checking the IOMMU groups...
All a VM is to Unraid is an XML file.... All the webui does is add bits to the XML, delete those bits and changes are undone...
I am a little confused as you can see. I am surprised that the all of the USB are not available to the server if no VM are up.
Regards.
Regards.
Have you rebooted?
Don't forget it a USB BUS we're talking about, not a USB PORT, One BUS may encompass several ports
Alright, made an 11.a and 11.b step giving users the choice
Just tried passthrough hostdev with a windows machine and that works fine..  But again a gfx card just gives a black screen/no output..
If I remember correctly, JonP mentioned many months ago in a forum post long forgotten, that he had much better luck with the arg format as opposed to the hostdev approach in regards to GPU... [disclaimer, I may have made all that up but I want to say I remember reading that]
Regards.
Once a controller gets past through unRAID no longer can see the controller. Once the VM gets shutdown, unRAID doesn't know that the controller is available so you have to restart the server in order for unRAID to see it again. There may be some sort of script you can create that will let unRAID know that the controller is free.
Ok thanks for clearing that up for me. Us newbies are learning.  :)
It might be that it works better for graphics in OVMF and qemu arg  better in seabios. I haven't checked it that thorough I have to admit.
I forgot I wrote this.....
Quite a nice detailed way of doing the method saarg has told us how to do....  What's worse is I was reading his post thinking, that's pretty cool.... Completely forgot, must be going senile...  ;D
LOL  ;D
hello guys. Im having some problems passing through a USB pcie card (http://www.amazon.com/gp/product/B00FPIMICA?psc=1&redirect=true&ref_=oh_aui_detailpage_o01_s00)
i have attached a usb bluetooth device in the pcie card that i want to passthrough and it shows that is in bus 003:
Bus 003 Device 003: ID 0a5c:2198 Broadcom Corp. Bluetooth 3.0 Device
this is the result from readlink /sys/bus/usb/devices/usbX
root@Tower:~# readlink /sys/bus/usb/devices/usb1
../../../devices/pci0000:00/0000:00:14.0/usb1
root@Tower:~# readlink /sys/bus/usb/devices/usb2
../../../devices/pci0000:00/0000:00:14.0/usb2
root@Tower:~# readlink /sys/bus/usb/devices/usb3
../../../devices/pci0000:00/0000:00:1c.3/0000:04:00.0/0000:05:05.0/0000:08:00.0/usb3
root@Tower:~# readlink /sys/bus/usb/devices/usb4
../../../devices/pci0000:00/0000:00:1c.3/0000:04:00.0/0000:05:05.0/0000:08:00.0/usb4
root@Tower:~# readlink /sys/bus/usb/devices/usb5
../../../devices/pci0000:00/0000:00:1c.6/0000:0a:00.0/usb5
root@Tower:~# readlink /sys/bus/usb/devices/usb6
../../../devices/pci0000:00/0000:00:1c.6/0000:0a:00.0/usb6
root@Tower:~# readlink /sys/bus/usb/devices/usb7
../../../devices/pci0000:00/0000:00:1a.0/usb7
root@Tower:~# readlink /sys/bus/usb/devices/usb8
../../../devices/pci0000:00/0000:00:1d.0/usb8
this is the IOMMU Groups:
/sys/kernel/iommu_groups/0/devices/0000:00:00.0
/sys/kernel/iommu_groups/1/devices/0000:00:01.0
/sys/kernel/iommu_groups/1/devices/0000:01:00.0
/sys/kernel/iommu_groups/1/devices/0000:01:00.1
/sys/kernel/iommu_groups/2/devices/0000:00:14.0
/sys/kernel/iommu_groups/3/devices/0000:00:16.0
/sys/kernel/iommu_groups/4/devices/0000:00:19.0
/sys/kernel/iommu_groups/5/devices/0000:00:1a.0
/sys/kernel/iommu_groups/6/devices/0000:00:1b.0
/sys/kernel/iommu_groups/7/devices/0000:00:1c.0
/sys/kernel/iommu_groups/7/devices/0000:00:1c.2
/sys/kernel/iommu_groups/7/devices/0000:00:1c.3
/sys/kernel/iommu_groups/7/devices/0000:00:1c.6
/sys/kernel/iommu_groups/7/devices/0000:03:00.0
/sys/kernel/iommu_groups/7/devices/0000:04:00.0
/sys/kernel/iommu_groups/7/devices/0000:05:01.0
/sys/kernel/iommu_groups/7/devices/0000:05:03.0
/sys/kernel/iommu_groups/7/devices/0000:05:05.0
/sys/kernel/iommu_groups/7/devices/0000:05:07.0
/sys/kernel/iommu_groups/7/devices/0000:07:00.0
/sys/kernel/iommu_groups/7/devices/0000:08:00.0
/sys/kernel/iommu_groups/7/devices/0000:09:00.0
/sys/kernel/iommu_groups/7/devices/0000:0a:00.0
/sys/kernel/iommu_groups/8/devices/0000:00:1d.0
/sys/kernel/iommu_groups/9/devices/0000:00:1f.0
/sys/kernel/iommu_groups/9/devices/0000:00:1f.2
/sys/kernel/iommu_groups/9/devices/0000:00:1f.3
and this is the list of devices that i currently have on my unraid build (taken from system devices)
00:00.0 Host bridge: Intel Corporation 4th Gen Core Processor DRAM Controller (rev 06)
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor PCI Express x16 Controller (rev 06)
00:14.0 USB controller: Intel Corporation 9 Series Chipset Family USB xHCI Controller
00:16.0 Communication controller: Intel Corporation 9 Series Chipset Family ME Interface #1
00:19.0 Ethernet controller: Intel Corporation Ethernet Connection (2) I218-V
00:1a.0 USB controller: Intel Corporation 9 Series Chipset Family USB EHCI Controller #2
00:1b.0 Audio device: Intel Corporation 9 Series Chipset Family HD Audio Controller
00:1c.0 PCI bridge: Intel Corporation 9 Series Chipset Family PCI Express Root Port 1 (rev d0)
00:1c.2 PCI bridge: Intel Corporation 9 Series Chipset Family PCI Express Root Port 3 (rev d0)
00:1c.3 PCI bridge: Intel Corporation 9 Series Chipset Family PCI Express Root Port 4 (rev d0)
00:1c.6 PCI bridge: Intel Corporation 9 Series Chipset Family PCI Express Root Port 7 (rev d0)
00:1d.0 USB controller: Intel Corporation 9 Series Chipset Family USB EHCI Controller #1
00:1f.0 ISA bridge: Intel Corporation 9 Series Chipset Family Z97 LPC Controller
00:1f.2 SATA controller: Intel Corporation 9 Series Chipset Family SATA Controller [AHCI Mode]
00:1f.3 SMBus: Intel Corporation 9 Series Chipset Family SMBus Controller
01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Caicos [Radeon HD 6450/7450/8450 / R5 230 OEM]
01:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Caicos HDMI Audio [Radeon HD 6400 Series]
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 11)
04:00.0 PCI bridge: ASMedia Technology Inc. Device 1184
05:01.0 PCI bridge: ASMedia Technology Inc. Device 1184
05:03.0 PCI bridge: ASMedia Technology Inc. Device 1184
05:05.0 PCI bridge: ASMedia Technology Inc. Device 1184
05:07.0 PCI bridge: ASMedia Technology Inc. Device 1184
07:00.0 SATA controller: ASMedia Technology Inc. ASM1062 Serial ATA Controller (rev 02)
08:00.0 USB controller: Fresco Logic Device 1100 (rev 10)
09:00.0 SATA controller: ASMedia Technology Inc. ASM1062 Serial ATA Controller (rev 02)
0a:00.0 USB controller: ASMedia Technology Inc. ASM1042A USB 3.0 Host Controller
my 2 main questions are:
1- do i need to passthrough all the devices currently on group 7? if so, how do i make sure that all those devices are not critically importat for unraid to properly work? (my unraid usb is on bus 001)
2- which one is the right address for my bus 003? (as it shows ../../../devices/pci0000:00/0000:00:1c.3/0000:04:00.0/0000:05:05.0/0000:08:00.0/usb3)
PD: I'm passing it through to use it with El Capitan Virtual Machine.
thanks in advance for any help that can be provided. suggestions and/or corrections are very welcome.
Edit: I have figured it out.
First I had to enable the option "PCIe ACS Override" on VM Manager under settings. Second, I was using the wrong method to Pass it through because I'm using this method in a q35 machine (Mac OS X El Capitan). I was using the Hostdev method and I needed to use the qemu:arg method.
Wrong (Hostdev method):
<driver name='vfio'/>
<source>
<address domain='0x0000' bus='0x08' slot='0x00' function='0x0'/>
</source>
</hostdev>
Right (qemu:arg method):
    <qemu:arg value='-device'/>
    <qemu:arg value='vfio-pci,host=08:00.0,bus=root.1,addr=00.1'/>
Note that the addr=00.1 because in the addr=00.0 i have my GPU passed through.
Is now working like a charm. Hope it can help somebody.
Evening,
I've tried both methods of USB hub pass-through and neither will work with my keyboard and mouse but weirdly it will with a portable hard drive.
here is my XML
<domain type='kvm' xmlns:qemu='http://libvirt.org/schemas/domain/qemu/1.0'>
  <name>Ash</name>
  <uuid>ae944ea6-a892-a1a1-f512-6c076484b968</uuid>
  <description>Ashly's machine</description>
  <metadata>
    <vmtemplate name="Custom" icon="windows.png" os="windows"/>
  </metadata>
  <memory unit='KiB'>8388608</memory>
  <currentMemory unit='KiB'>8388608</currentMemory>
  <memoryBacking>
    <nosharepages/>
    <locked/>
  </memoryBacking>
  <vcpu placement='static'>6</vcpu>
  <cputune>
    <vcpupin vcpu='0' cpuset='0'/>
    <vcpupin vcpu='1' cpuset='1'/>
    <vcpupin vcpu='2' cpuset='2'/>
    <vcpupin vcpu='3' cpuset='3'/>
    <vcpupin vcpu='4' cpuset='4'/>
    <vcpupin vcpu='5' cpuset='5'/>
  </cputune>
  <os>
    <type arch='x86_64' machine='pc-i440fx-2.3'>hvm</type>
  </os>
  <features>
    <acpi/>
    <apic/>
    <hyperv>
      <relaxed state='on'/>
      <vapic state='on'/>
    </hyperv>
  </features>
  <cpu mode='host-passthrough'>
    <topology sockets='1' cores='6' threads='1'/>
  </cpu>
  <clock offset='localtime'>
  </clock>
  <on_crash>restart</on_crash>
  <devices>
    <emulator>/usr/bin/qemu-system-x86_64</emulator>
      <source file='/mnt/disk1/Ash/Ash/vdisk1.img'/>
      <boot order='1'/>
    </disk>
      <source file='/mnt/disk1/Storage/Ash/vdisk2.img'/>
      <target dev='hdd' bus='virtio'/>
    </disk>
      <source file='/mnt/disk1/ISO's/virtio-win-0.1.112.iso'/>
      <target dev='hda' bus='ide'/>
      <readonly/>
      <boot order='2'/>
    </disk>
    <controller type='usb' index='0'>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x2'/>
    </controller>
    </controller>
    </controller>
    <interface type='bridge'>
      <mac address='52:54:00:e8:9a:3e'/>
      <source bridge='br0'/>
      <model type='virtio'/>
    </interface>
    <serial type='pty'>
      <target port='0'/>
    </serial>
    <console type='pty'>
    </console>
    <channel type='unix'>
      <source mode='bind' path='/var/lib/libvirt/qemu/channel/target/Ash.org.qemu.guest_agent.0'/>
    </channel>
    <memballoon model='virtio'>
    </memballoon>
  </devices>
  <qemu:commandline>
    <qemu:arg value='ioh3420,bus=pci.0,addr=1c.0,multifunction=on,port=2,chassis=1,id=root.1'/>
    <qemu:arg value='vfio-pci,host=01:00.0,bus=root.1,addr=00.0,multifunction=on,x-vga=on'/>
    <qemu:arg value='vfio-pci,host=06:00.0,bus=root.1,addr=00.1'/>
  </qemu:commandline>
</domain>
Two questions I would have would be related to ECHI Hand off settings and PCIe ACS Override.
Apart from this not working correctly everything else is perfect.
Cheers for the help.
Do you happen to have a different USB keyboard and mouse you could try? If the portable hard drive works then technically it is working, so the issue is most likely that keyboard and mouse. Does your keyboard/mouse manufacture have any additional software you can install? For example Logitech has their Setpoint software which I have found to be helpful with my devices.
