April 23, 201511 yr CPU: Intel® Core™2 Quad CPU Q8300 @ 2.50GH Direct Steaming of video, transcoding audio via plex (docker) to a roku 3. I have not noticed any streaming issue to my PC. Core2 is pretty slow for Plex transcoding. It's just about half the performance per core recommended by Plex. Plex recommend 2000 CPU Marks per core for acceptable transcoding, the Q8300 is just over 1000.
April 23, 201511 yr Author Has anyone else experienced this with their setups on beta 15? I am also experiencing the same issue with videos stuttering on B15. The same videos streamed fine in B14. Could you post up your CPU, MB and amount of Memory and the device you are using to play your Media? System: Supermicro - C2SEA CPU: Intel® Core™2 Quad CPU Q8300 @ 2.50GH Memory: 3072 MB (max. installable capacity 4 GB) Network: eth0: 1000Mb/s - Full Duplex Direct Steaming of video, transcoding audio via plex (docker) to a roku 3. I have not noticed any streaming issue to my PC. From a telnet session, run htop from the command line. Play a video under the conditions that cause the shuttering. Observe what happens to the CPU percentages when the shuttering occurs. Does it go up or down? (May seem like a stupid question but my CPU percentage actually drops when the 'bad' events happen!)
April 23, 201511 yr CPU: Intel® Core™2 Quad CPU Q8300 @ 2.50GH Direct Steaming of video, transcoding audio via plex (docker) to a roku 3. I have not noticed any streaming issue to my PC. Core2 is pretty slow for Plex transcoding. It's just about half the performance per core recommended by Plex. Plex recommend 2000 CPU Marks per core for acceptable transcoding, the Q8300 is just over 1000. Only audio is being transcoded. Core2 can handle that no prob. The CPU only runs at 10-20% during playback. Either way I just realized plex is not using SMB, So my issue is not the exact same Frank's.
April 24, 201511 yr I actually had stalls from B14 & B15. I'm running it off a Windows 7 machines (didn't change a thing for 4 years). Once I upgraded from 5 to 6beta, I started having stalling issues. One odd thing I noticed was that if I ran the same movie twice (from 0:00), it would stall/stutter at the same point...but if I skip chapters, it doesn't happen at that point. The stalling points are different for each movie but a stall is pretty much guaranteed with EVERY viewing. I tried downgrading back to Unraid 5 but had samba issues (couldn't mount). Has anyone downgraded B15 to the latest Unraid 5? Any help would be appreciated.
April 24, 201511 yr Author I actually had stalls from B14 & B15. I'm running it off a Windows 7 machines (didn't change a thing for 4 years). Once I upgraded from 5 to 6beta, I started having stalling issues. One odd thing I noticed was that if I ran the same movie twice (from 0:00), it would stall/stutter at the same point...but if I skip chapters, it doesn't happen at that point. The stalling points are different for each movie but a stall is pretty much guaranteed with EVERY viewing. I tried downgrading back to Unraid 5 but had samba issues (couldn't mount). Has anyone downgraded B15 to the latest Unraid 5? Any help would be appreciated. My personal suggestion would be to make a backup (of your flash drive) of your current version 6 setup. (I assume you didn't do this before you installed version 6 or you would be asking this question.) Then reformat the Flash, install the latest version 5.0.6 and run make bootable. (You can use the instructions from LimeTech to do this is you should need them.) Then copy over the files that are in the config folder of your backup to the config folder on the Flash. You will be over-writing files so you will allow this to occur! Then copy ONLY the files from your saved config/shares folder to the flash drive's config/shares folder. You should then be able to boot into unRAID and find your configuration intact. Basically, you are doing the reverse of the instructions contained here: http://lime-technology.com/wiki/index.php/Upgrading_to_UnRAID_v6 You will have to install any ver 5 plugins that you want and/or need! None of the version 6 stuff is going to work...
April 24, 201511 yr I actually had stalls from B14 & B15. I'm running it off a Windows 7 machines (didn't change a thing for 4 years). Once I upgraded from 5 to 6beta, I started having stalling issues. One odd thing I noticed was that if I ran the same movie twice (from 0:00), it would stall/stutter at the same point...but if I skip chapters, it doesn't happen at that point. The stalling points are different for each movie but a stall is pretty much guaranteed with EVERY viewing. I tried downgrading back to Unraid 5 but had samba issues (couldn't mount). Has anyone downgraded B15 to the latest Unraid 5? Any help would be appreciated. I have actually been having trouble since B14 as well that continues with B15. I thought that it was a hardware issue, but nothing has changed and I have ruled everything out. I've gone a few days without a stall, but the problem is intermittent on my end. My hardware is in my sig. craigr
April 27, 201511 yr For those experiencing playback issues, please report back the network driver in use on your system. You can determine this by typing the following command: lspci -k Look for Ethernet controller(s) (you may have more than one). Look at the "Kernel driver in use" and report back. As an example: 00:19.0 Ethernet controller: Intel Corporation Ethernet Connection I217-V (rev 04) Subsystem: Gigabyte Technology Co., Ltd Device e000 Kernel driver in use: e1000e Kernel modules: e1000e
April 27, 201511 yr Author For those experiencing playback issues, please report back the network driver in use on your system. You can determine this by typing the following command: lspci -k Look for Ethernet controller(s) (you may have more than one). Look at the "Kernel driver in use" and report back. As an example: 00:19.0 Ethernet controller: Intel Corporation Ethernet Connection I217-V (rev 04) Subsystem: Gigabyte Technology Co., Ltd Device e000 Kernel driver in use: e1000e Kernel modules: e1000e 01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 03) Subsystem: Biostar Microtech Int'l Corp Device 2309 Kernel driver in use: r8169 Kernel modules: r8169
April 27, 201511 yr For those experiencing playback issues, please report back the network driver in use on your system. You can determine this by typing the following command: lspci -k Look for Ethernet controller(s) (you may have more than one). Look at the "Kernel driver in use" and report back. As an example: 00:19.0 Ethernet controller: Intel Corporation Ethernet Connection I217-V (rev 04) Subsystem: Gigabyte Technology Co., Ltd Device e000 Kernel driver in use: e1000e Kernel modules: e1000e 01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 03) Subsystem: Biostar Microtech Int'l Corp Device 2309 Kernel driver in use: r8169 Kernel modules: r8169 Thanks Frank. Do you have multiple ethernet connections to your system? Are you doing bonding or bridging? If not, do you know which of those two you are connected to right now? If not, can you at least try switching the cable to the other port (maybe shutdown first, switch cable, then turn back on)? Curious if this has any impact.
April 27, 201511 yr Author For those experiencing playback issues, please report back the network driver in use on your system. You can determine this by typing the following command: lspci -k Look for Ethernet controller(s) (you may have more than one). Look at the "Kernel driver in use" and report back. As an example: 00:19.0 Ethernet controller: Intel Corporation Ethernet Connection I217-V (rev 04) Subsystem: Gigabyte Technology Co., Ltd Device e000 Kernel driver in use: e1000e Kernel modules: e1000e 01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 03) Subsystem: Biostar Microtech Int'l Corp Device 2309 Kernel driver in use: r8169 Kernel modules: r8169 Thanks Frank. Do you have multiple ethernet connections to your system? Are you doing bonding or bridging? If not, do you know which of those two you are connected to right now? If not, can you at least try switching the cable to the other port (maybe shutdown first, switch cable, then turn back on)? Curious if this has any impact. Both of my systems are using the NIC on the motherboard and are very inexpensive motherboards that have only one NIC. Both systems have been tested using 6b15 and both have the same problem. Of course, both are basically using the same NIC chip...
April 27, 201511 yr For those experiencing playback issues, please report back the network driver in use on your system. You can determine this by typing the following command: lspci -k Look for Ethernet controller(s) (you may have more than one). Look at the "Kernel driver in use" and report back. As an example: 00:19.0 Ethernet controller: Intel Corporation Ethernet Connection I217-V (rev 04) Subsystem: Gigabyte Technology Co., Ltd Device e000 Kernel driver in use: e1000e Kernel modules: e1000e 01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 03) Subsystem: Biostar Microtech Int'l Corp Device 2309 Kernel driver in use: r8169 Kernel modules: r8169 Thanks Frank. Do you have multiple ethernet connections to your system? Are you doing bonding or bridging? If not, do you know which of those two you are connected to right now? If not, can you at least try switching the cable to the other port (maybe shutdown first, switch cable, then turn back on)? Curious if this has any impact. Both of my systems are using the NIC on the motherboard and are very inexpensive motherboards that have only one NIC. Both systems have been tested using 6b15 and both have the same problem. Of course, both are basically using the same NIC chip... Hmm, well one of the NICs you posted was a Realtek, not Intel. So was each of those that you posted from different systems?
April 27, 201511 yr Author For those experiencing playback issues, please report back the network driver in use on your system. You can determine this by typing the following command: lspci -k Look for Ethernet controller(s) (you may have more than one). Look at the "Kernel driver in use" and report back. As an example: 00:19.0 Ethernet controller: Intel Corporation Ethernet Connection I217-V (rev 04) Subsystem: Gigabyte Technology Co., Ltd Device e000 Kernel driver in use: e1000e Kernel modules: e1000e 01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 03) Subsystem: Biostar Microtech Int'l Corp Device 2309 Kernel driver in use: r8169 Kernel modules: r8169 Thanks Frank. Do you have multiple ethernet connections to your system? Are you doing bonding or bridging? If not, do you know which of those two you are connected to right now? If not, can you at least try switching the cable to the other port (maybe shutdown first, switch cable, then turn back on)? Curious if this has any impact. Both of my systems are using the NIC on the motherboard and are very inexpensive motherboards that have only one NIC. Both systems have been tested using 6b15 and both have the same problem. Of course, both are basically using the same NIC chip... Hmm, well one of the NICs you posted was a Realtek, not Intel. So was each of those that you posted from different systems? You have gotten confused looking at all the quoted posts. That Intel NIC was actually the one that you used as an example of the output expected from the lspci -k command.
April 27, 201511 yr For those experiencing playback issues, please report back the network driver in use on your system. You can determine this by typing the following command: lspci -k Look for Ethernet controller(s) (you may have more than one). Look at the "Kernel driver in use" and report back. As an example: 00:19.0 Ethernet controller: Intel Corporation Ethernet Connection I217-V (rev 04) Subsystem: Gigabyte Technology Co., Ltd Device e000 Kernel driver in use: e1000e Kernel modules: e1000e 01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 03) Subsystem: Biostar Microtech Int'l Corp Device 2309 Kernel driver in use: r8169 Kernel modules: r8169 Thanks Frank. Do you have multiple ethernet connections to your system? Are you doing bonding or bridging? If not, do you know which of those two you are connected to right now? If not, can you at least try switching the cable to the other port (maybe shutdown first, switch cable, then turn back on)? Curious if this has any impact. Both of my systems are using the NIC on the motherboard and are very inexpensive motherboards that have only one NIC. Both systems have been tested using 6b15 and both have the same problem. Of course, both are basically using the same NIC chip... Hmm, well one of the NICs you posted was a Realtek, not Intel. So was each of those that you posted from different systems? You have gotten confused looking at all the quoted posts. That Intel NIC was actually the one that you used as an example of the output expected from the lspci -k command. Ah lol! My bad. Ok. What about storage controllers? Do you just use on board storage controllers or did you buy an add on card?
April 27, 201511 yr Author Jonp --- They are both on-board NIC Chip sets. (I have two servers. Both of which have been on 6b15 at one time or the other) Frank Edit: Just re-read the question. I am using the motherboard SATA ports. No other plug-in SATA cards.
April 28, 201511 yr For those experiencing playback issues, please report back the network driver in use on your system. You can determine this by typing the following command: lspci -k Look for Ethernet controller(s) (you may have more than one). Look at the "Kernel driver in use" and report back. As an example: 00:19.0 Ethernet controller: Intel Corporation Ethernet Connection I217-V (rev 04) Subsystem: Gigabyte Technology Co., Ltd Device e000 Kernel driver in use: e1000e Kernel modules: e1000e I'm here also having issues with streaming on b15 and previous, the problem happens when transferring small files too . I've done the command and here is the result, if anyone could help it would be great. Thanks! 02:00.0 Ethernet controller: Qualcomm Atheros AR8121/AR8113/AR8114 Gigabit or Fast Ethernet (rev b0) Subsystem: ASUSTeK Computer Inc. P5KPL-CM Motherboard Kernel driver in use: ATL1E Kernel modules: atl1e
April 28, 201511 yr For those experiencing playback issues, please report back the network driver in use on your system. You can determine this by typing the following command: lspci -k Look for Ethernet controller(s) (you may have more than one). Look at the "Kernel driver in use" and report back. As an example: 00:19.0 Ethernet controller: Intel Corporation Ethernet Connection I217-V (rev 04) Subsystem: Gigabyte Technology Co., Ltd Device e000 Kernel driver in use: e1000e Kernel modules: e1000e I'm here also having issues with streaming on b15 and previous, the problem happens when transferring small files too . I've done the command and here is the result, if anyone could help it would be great. Thanks! 02:00.0 Ethernet controller: Qualcomm Atheros AR8121/AR8113/AR8114 Gigabit or Fast Ethernet (rev b0) Subsystem: ASUSTeK Computer Inc. P5KPL-CM Motherboard Kernel driver in use: ATL1E Kernel modules: atl1e Please describe your setup. Are you using dune players and the like?
April 28, 201511 yr For those experiencing playback issues, please report back the network driver in use on your system. You can determine this by typing the following command: lspci -k Look for Ethernet controller(s) (you may have more than one). Look at the "Kernel driver in use" and report back. As an example: 00:19.0 Ethernet controller: Intel Corporation Ethernet Connection I217-V (rev 04) Subsystem: Gigabyte Technology Co., Ltd Device e000 Kernel driver in use: e1000e Kernel modules: e1000e I'm here also having issues with streaming on b15 and previous, the problem happens when transferring small files too . I've done the command and here is the result, if anyone could help it would be great. Thanks! 02:00.0 Ethernet controller: Qualcomm Atheros AR8121/AR8113/AR8114 Gigabit or Fast Ethernet (rev b0) Subsystem: ASUSTeK Computer Inc. P5KPL-CM Motherboard Kernel driver in use: ATL1E Kernel modules: atl1e Please describe your setup. Are you using dune players and the like? Here is the thread where I explain all my setup and so. http://lime-technology.com/forum/index.php?topic=39397 Thanks for being so fast jonp!
April 28, 201511 yr For those experiencing playback issues, please report back the network driver in use on your system. You can determine this by typing the following command: lspci -k Look for Ethernet controller(s) (you may have more than one). Look at the "Kernel driver in use" and report back. As an example: 00:19.0 Ethernet controller: Intel Corporation Ethernet Connection I217-V (rev 04) Subsystem: Gigabyte Technology Co., Ltd Device e000 Kernel driver in use: e1000e Kernel modules: e1000e I'm here also having issues with streaming on b15 and previous, the problem happens when transferring small files too . I've done the command and here is the result, if anyone could help it would be great. Thanks! 02:00.0 Ethernet controller: Qualcomm Atheros AR8121/AR8113/AR8114 Gigabit or Fast Ethernet (rev b0) Subsystem: ASUSTeK Computer Inc. P5KPL-CM Motherboard Kernel driver in use: ATL1E Kernel modules: atl1e Please describe your setup. Are you using dune players and the like? Here is the thread where I explain all my setup and so. http://lime-technology.com/forum/index.php?topic=39397 Thanks for being so fast jonp! No prob. Not sure this is the exact same issue necessarily, but could be related. Thank you for posting.
April 29, 201511 yr For those experiencing playback issues, please report back the network driver in use on your system. You can determine this by typing the following command: lspci -k Look for Ethernet controller(s) (you may have more than one). Look at the "Kernel driver in use" and report back. As an example: 05:00.0 Ethernet controller: Intel Corporation 82574L Gigabit Network Connection Subsystem: Intel Corporation Gigabit CT Desktop Adapter Kernel driver in use: e1000e Kernel modules: e1000e I also have a Realtek on board NIC that is disabled in the motherboard bios. I have tried both NIC's (removed Intel card and enabled Realtek in bios) and both exhibit the same problems. craigr
April 29, 201511 yr For those experiencing playback issues, please report back the network driver in use on your system. You can determine this by typing the following command: lspci -k Look for Ethernet controller(s) (you may have more than one). Look at the "Kernel driver in use" and report back. As an example: 05:00.0 Ethernet controller: Intel Corporation 82574L Gigabit Network Connection Subsystem: Intel Corporation Gigabit CT Desktop Adapter Kernel driver in use: e1000e Kernel modules: e1000e craigr Craig, since we last spoke on the phone, have you had any more skips? You had mentioned removing an SSD from your LSI controller seemed to have solved the problem. Wanted to see if that is still the case or not.
April 29, 201511 yr For those experiencing playback issues, please report back the network driver in use on your system. You can determine this by typing the following command: lspci -k Look for Ethernet controller(s) (you may have more than one). Look at the "Kernel driver in use" and report back. As an example: 05:00.0 Ethernet controller: Intel Corporation 82574L Gigabit Network Connection Subsystem: Intel Corporation Gigabit CT Desktop Adapter Kernel driver in use: e1000e Kernel modules: e1000e craigr Craig, since we last spoke on the phone, have you had any more skips? You had mentioned removing an SSD from your LSI controller seemed to have solved the problem. Wanted to see if that is still the case or not. I have not seen the problem since removing the SSD drive from the SAS card. However,I have not used the system very much the past couple days. I primarily use the system for BD ISO playback in the theater, but also for small mkv cartoons when going to sleep. I've only encountered the problem once with the small low bit-rate mkv files; all other incidents have been with BD ISO. I did play a Downton Abbey BD ISO two nights ago and had no issues. Before transplanting the SSD from the LSI to the MB, Downton Abbey was freezing about once per episode. Downton Abbey is on my disc 9 which is connected to the LSI SAS card. We will probably watch something this evening. craigr
April 29, 201511 yr In case you are interested: 00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD/ATI] RD890 PCI to PCI bridge (external gfx0 port B) (rev 02) Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] RD890 PCI to PCI bridge (external gfx0 port B) 00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD/ATI] RD990 I/O Memory Management Unit (IOMMU) Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] RD990 I/O Memory Management Unit (IOMMU) 00:02.0 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] RD890 PCI to PCI bridge (PCI express gpp port B) Kernel driver in use: pcieport 00:0d.0 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] RD890 PCI to PCI bridge (external gfx1 port B) Kernel driver in use: pcieport 00:11.0 SATA controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 SATA Controller [AHCI mode] (rev 40) Subsystem: Gigabyte Technology Co., Ltd Device b002 Kernel driver in use: ahci Kernel modules: ahci 00:12.0 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 USB OHCI0 Controller Subsystem: Gigabyte Technology Co., Ltd Device 5004 Kernel driver in use: ohci-pci 00:12.2 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 USB EHCI Controller Subsystem: Gigabyte Technology Co., Ltd Device 5004 Kernel driver in use: ehci-pci 00:13.0 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 USB OHCI0 Controller Subsystem: Gigabyte Technology Co., Ltd Device 5004 Kernel driver in use: ohci-pci 00:13.2 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 USB EHCI Controller Subsystem: Gigabyte Technology Co., Ltd Device 5004 Kernel driver in use: ehci-pci 00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD/ATI] SBx00 SMBus Controller (rev 42) Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] SBx00 SMBus Controller Kernel driver in use: piix4_smbus Kernel modules: i2c_piix4 00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 LPC host controller (rev 40) Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 LPC host controller 00:14.4 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] SBx00 PCI to PCI Bridge (rev 40) 00:14.5 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 USB OHCI2 Controller Subsystem: Gigabyte Technology Co., Ltd Device 5004 Kernel driver in use: ohci-pci 00:15.0 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] SB700/SB800/SB900 PCI to PCI bridge (PCIE port 0) Kernel driver in use: pcieport 00:15.3 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] SB900 PCI to PCI bridge (PCIE port 3) Kernel driver in use: pcieport 00:16.0 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 USB OHCI0 Controller Subsystem: Gigabyte Technology Co., Ltd Device 5004 Kernel driver in use: ohci-pci 00:16.2 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 USB EHCI Controller Subsystem: Gigabyte Technology Co., Ltd Device 5004 Kernel driver in use: ehci-pci 00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 10h Processor HyperTransport Configuration 00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 10h Processor Address Map 00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 10h Processor DRAM Controller 00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 10h Processor Miscellaneous Control Kernel driver in use: k10temp Kernel modules: k10temp 00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 10h Processor Link Control 01:00.0 Serial Attached SCSI controller: LSI Logic / Symbios Logic SAS2008 PCI-Express Fusion-MPT SAS-2 [Falcon] (rev 03) Subsystem: LSI Logic / Symbios Logic Device 3020 Kernel driver in use: mpt2sas Kernel modules: mpt2sas 02:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] RV370 [Radeon X300] Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] Device 0f02 02:00.1 Display controller: Advanced Micro Devices, Inc. [AMD/ATI] RV370 [Radeon X300 SE] Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] Device 0f03 05:00.0 Ethernet controller: Intel Corporation 82574L Gigabit Network Connection Subsystem: Intel Corporation Gigabit CT Desktop Adapter Kernel driver in use: e1000e Kernel modules: e1000e craigr
April 29, 201511 yr Another point. I have three Dune players hooked up to the network. I can have all three streaming the same, or a different BD ISO, simultaneously and it still all streams play smoothly. I agree that it's not a question of utilization. craigr
April 29, 201511 yr Ok, good. Frank was kind enough to purchase an Intel based NIC and confirmed for me today that resolved his problems, but you already have an Intel based NIC, so I think your issue was different from his. Considering bonienl in this thread also has dune players in his setup (and not experiencing issues), I have a feeling you resolved your issue already by moving the SSD to the on board controller as opposed to the LSI. Not sure still why that should have made a difference, but as long as its working and you are happy, I'm happy.
April 30, 201511 yr Author As jonp stated in the above post, he and I in a series of E-mails were discussing this problem and one of the items that came up was to replace the on-board Realtek NIC with a one that used another chipset. (As many of you might recall, Realtek drivers have been a big issue in the past.) I started investigating the available NIC adapters and quickly found that most of the cheaper cards that were in the $10 to $15 range either used the Realtek chip set or the chip set wasn't even mentioned. The lowest priced unit that seemed to be cut from a different fabric were Intel units. Intel advertises that their chip set generates fewer interrupts and have lower CPU usage than most other solutions. (Think dedicated audio cards vs on-board audio solutions.) Plus, Intel NIC's have been favorably recommended by many unRAID users over the past several years. The least expensive Intel one I could located (on Amazon.com) was this unit for about $32. http://www.amazon.com/gp/product/B001CY0P7G/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1 I got the Intel Gigabit CT PCI-E Network Adapter yesterday and installed it first into my Test Bed server. We tested it for over an hour and did not have a single audio dropout or picture stall. We then played two high bitrate HD streams simultaneously and still no issues for approximately another hour. In the past, we ALWAYS had a video and/or audio dropout with a few seconds to the most four or five minutes with the average being close to a minute between occurrences. So apparently the issue is in the Realtek hardware/drivers and/or their interaction with the underlining OS. From the standpoint that this issue can be 'fixed' by replacing the on-board Realtek NIC, one could consider that this issue has been solved. I just wonder if the problem is only in the Realtek driver, or is the issue really with any on-board NIC that uses the CPU, or is the issue with on-board NIC's only present with low-power CPU's. There are still a number of questions that do require further investigation. The problem seems to surface only with high bitrate data streams (think ~40MB/sec) that can be common with straight BluRay rips with the highest picture quality. If you are successfully playing these types of files, it might provide some clues if you would post your setup including the device you are using to actually play these files. EDIT: Please include which Realtek NIC chip is used on your motherboard. This information can generally be found in the motherboard manual.
