Jump to content
I think there is still a problem with SAS cards in 6 Beta-rc3
guyonphone
Hello dgaschk,
Here is my smart report
smartctl 6.2 2013-07-26 r3841 [x86_64-linux-4.0.4-unRAID] (local build)
Copyright (C) 2002-13, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Vendor:               /12:0:1:
Product:              0
User Capacity:        600,332,565,813,390,450 bytes [600 PB]
Logical block size:   774843950 bytes
Physical block size:  3166222336 bytes
Lowest aligned LBA:   12602
>> Terminate command early due to bad response to IEC mode page
A mandatory SMART command failed: exiting. To continue, add one or more '-T permissive' options.
I had this issue just happen, and then resolved it. There is a thread I marked as resolved here https://lime-technology.com/forum/index.php?topic=40210.0
In that thread RobJ says the following:
That looked very familiar, and then I realized you are still running 6.0-beta14b.  We used to see a fair number of cases of this, where a whole SAS card seems to drop, and whatever drive is accessed next is often dropped from the array, because all or most of the drives on that card can no longer respond.  PLEASE upgrade, at least to 6.0-beta15, or the latest -rc.  Since beta15 was released, I don't think I've seen a case of this since.  SAS card support does not even yet seem to be completely stable, and if I had one, I would constantly check for newer firmware for the card, and newer unRAID releases, even if they are beta, in order to always have the latest SAS support modules and drivers and firmware.  Support for them does seem to be improving, with fewer problems now.
I thought upgrading to 6 Beta-RC3 would resolve this, but it looks like im still having an issue.
I have two different cards
Sata Controller 1: SUPERMICRO AOC-SASLP-MV8
Sata Controller 2: SUPERMICRO AOC-SAS2LP-MV8
The SAS2LP I think has a newer firmware I can upgrade, so I will try that, but the older SASLP does not have any firmware update software available to download from the manufacturer.
What would you recommend I do next? And thanks in advance for your support :-)
Link to comment
Hello dgaschk,
Smart Report is here:
Model Family:     Seagate Barracuda 7200.14 (AF)
Device Model:     ST3000DM001-1CH166
Serial Number:    Z1F2HEZY
LU WWN Device Id: 5 000c50 05002695c
Firmware Version: CC24
User Capacity:    3,000,592,982,016 bytes [3.00 TB]
Sector Sizes:     512 bytes logical, 4096 bytes physical
Rotation Rate:    7200 rpm
Device is:        In smartctl database [for details use: -P show]
ATA Version is:   ATA8-ACS T13/1699-D revision 4
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is:    Thu Jun  4 19:51:08 2015 PDT
==> WARNING: A firmware update for this drive may be available,
see the following Seagate web pages:
http://knowledge.seagate.com/articles/en_US/FAQ/207931en
http://knowledge.seagate.com/articles/en_US/FAQ/223651en
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x00)	Offline data collection activity
				was never started.
				Auto Offline Data Collection: Disabled.
Self-test execution status:      (   0)	The previous self-test routine completed
				without error or no self-test has ever
				been run.
Total time to complete Offline
data collection: 		(  584) seconds.
capabilities: 			 (0x73) SMART execute Offline immediate.
				Auto Offline data collection on/off support.
				Suspend Offline collection upon new
				command.
				No Offline surface scan supported.
				Self-test supported.
				Conveyance Self-test supported.
				Selective Self-test supported.
SMART capabilities:            (0x0003)	Saves SMART data before entering
				power-saving mode.
				Supports SMART auto save timer.
Error logging capability:        (0x01)	Error logging supported.
				General Purpose Logging supported.
Short self-test routine
recommended polling time: 	 (   1) minutes.
Extended self-test routine
recommended polling time: 	 ( 340) minutes.
Conveyance self-test routine
recommended polling time: 	 (   2) minutes.
SCT capabilities: 	       (0x3085)	SCT Status supported.
SMART Attributes Data Structure revision number: 10
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x000f   112   099   006    Pre-fail  Always       -       42516568
  3 Spin_Up_Time            0x0003   094   094   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   099   099   020    Old_age   Always       -       1898
  5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000f   066   055   030    Pre-fail  Always       -       30099042447
  9 Power_On_Hours          0x0032   081   081   000    Old_age   Always       -       16833
10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       179
183 Runtime_Bad_Block       0x0032   100   100   000    Old_age   Always       -       0
184 End-to-End_Error        0x0032   100   100   099    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   099   000    Old_age   Always       -       13 13 13
189 High_Fly_Writes         0x003a   097   097   000    Old_age   Always       -       3
190 Airflow_Temperature_Cel 0x0022   061   052   045    Old_age   Always       -       39 (Min/Max 37/39)
191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -       0
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       125
193 Load_Cycle_Count        0x0032   061   061   000    Old_age   Always       -       79277
194 Temperature_Celsius     0x0022   039   048   000    Old_age   Always       -       39 (0 18 0 0 0)
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       4222h+04m+20.742s
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       18157344808
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       265931052632
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline       Completed without error       00%     16629         -
# 2  Short offline       Completed without error       00%      5023         -
# 3  Short offline       Completed without error       00%      5019         -
# 4  Short offline       Completed without error       00%       168         -
# 5  Short offline       Interrupted (host reset)      00%       168         -
# 6  Short offline       Completed without error       00%       167         -
SMART Selective self-test log data structure revision number 1
SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Also I am starting to check the firmware of my cards, they are as follows:
Sata Controller 1: SUPERMICRO AOC-SASLP-MV8 - Firmware Version: 3.1.0.21 (Latest Version)
Sata Controller 2: SUPERMICRO AOC-SAS2LP-MV8- Firmware Version: 4.0.0.1808 (Newer Version Avaliable 4.0.0.1812)
I am working on updating the firmware on the AOC-SAS2LP-MV8 right now.
Link to comment
OK, I have updated my SAS card firmware:
Sata Controller 1: SUPERMICRO AOC-SASLP-MV8 - Firmware Version: 3.1.0.21 (Latest Version as of 6/4/2015)
Sata Controller 2: SUPERMICRO AOC-SAS2LP-MV8- Firmware Version: 4.0.0.1812 (Latest Version as of 6/4/2015)
I have also updated to 6 Beta-RC4. However my disk 13 is still disabled. What is the safest way to recover it?
Thank You
Link to comment
I consistently have had these problems on 12, 14b, and 15 (I have a single SAS2LP).  It only seems to affect some hardware configurations, but it's common enough to worry.  I'll upgrade to RC4 this weekend and see what happens.
FYI, I also have 1812 and power cycling brings back the missing drive with a healthy SMART report.
Link to comment
My Parity is rebuilding.
I think that my failure occurred this time during heavy writes to the server. I think I was copying too and from the server on different machines with 3 separate copies going at one time, and the mover may have been running as well.
Would it be beneficial for me to move my cache drive to a sata port on my motherboard? I suspect that I may have just overloaded the SAS card.
Link to comment
If this is true then you need a new SAS card. Working cards do not fail when loaded. There is no way to overload a SATA card. It will just slow down.
Link to comment
Hello dgaschk,
I don't know specifically if the card is bad, it was just speculation on my part. I know as much as I see in the logs. If this continues to happen at times of high load, then I will assume a bad card, but as of now its not enough information for a definitive analysis.
Looking at the log of the failue, does it provide any hints as to what went wrong? Or are you as much in the dark as I am?
Thanks for your help!
Link to comment
  • Create New...
