tmchow Posted April 17, 2016 Share Posted April 17, 2016 I want to change my split level of a share but it has data on it. Will changing split level then move existing files? I found an old post about v5 saying it only affects future writes, but not sure if that's still the case in v6. http://lime-technology.com/forum/index.php?topic=8187.0 If it is correct still that it only affects future writes, what is the current recommended way of executing this so all existing files in a share obey the new split levels? Link to comment
Squid Posted April 17, 2016 Share Posted April 17, 2016 No changing the split level will not move existing files but will only affect new files being written to the array Sent from my LG-D852 using Tapatalk Link to comment
gundamguy Posted April 18, 2016 Share Posted April 18, 2016 If it is correct still that it only affects future writes, what is the current recommended way of executing this so all existing files in a share obey the new split levels? If you want to change the existing data so that it matches these split levels then you are going to have to do some manual moving of files. I'm not sure if anyone has written a plugin to make this easier, but the unbalance plugin might do this? Link to comment
