Temperature based fan speed control?
  • Replies 117
  • Views 102.6k
  • Hey folks - I know this is a long-dead thread, but I found it very useful in getting my unRAID server setup.   Because I had to piece together instructions from all over the place, I wrote u
  • Thank you very much for this script, I used it as a basis for one of my own scripts.   I made an enhancement that you might like in yours as well, to allow more steps in fan speed depending on tempera
No, I just have stock unRAID, no other sensors related stuff has been done. What is the order for configuring and which commands should I run?
Here is the output of sensors-detect
root@tower:~# sensors-detect
# sensors-detect revision 5337 (2008-09-19 17:05:28 +0200)
This program will help you determine which kernel modules you need
to load to use lm_sensors most effectively. It is generally safe
and recommended to accept the default answers to all questions,
unless you know what you're doing.
We can start with probing for (PCI) I2C or SMBus adapters.
Do you want to probe now? (YES/no): YES
Probing for PCI bus adapters...
Use driver `i2c-i801' for device 0000:00:1f.3: Intel ICH9
We will now try to load each adapter module in turn.
Load `i2c-i801' (say NO if built into your kernel)? (YES/no): YES
FATAL: Module i2c_i801 not found.
Loading failed... skipping.
If you have undetectable or unsupported I2C/SMBus adapters, you can have
them scanned by manually loading the modules before running this script.
To continue, we need module `i2c-dev' to be loaded.
Do you want to load `i2c-dev' now? (YES/no):
FATAL: Module i2c_dev not found.
Loading failed, expect problems later on.
We are now going to do the I2C/SMBus adapter probings. Some chips may
be double detected; we choose the one with the highest confidence
value in that case.
If you found that the adapter hung after probing a certain address,
you can specify that address to remain unprobed.
Some chips are also accessible through the ISA I/O ports. We have to
write to arbitrary I/O ports to probe them. This is usually safe though.
Yes, you do have ISA I/O ports even if you do not have any ISA slots!
Do you want to scan the ISA I/O ports? (YES/no):
Probing for `National Semiconductor LM78' at 0x290...      No
Probing for `National Semiconductor LM78-J' at 0x290...    No
Probing for `National Semiconductor LM79' at 0x290...      No
Probing for `Winbond W83781D' at 0x290...                  No
Probing for `Winbond W83782D' at 0x290...                  No
Probing for `IPMI BMC KCS' at 0xca0...                      Success!
    (confidence 4, driver `ipmisensors')
Probing for `IPMI BMC SMIC' at 0xca8...                    No
Some Super I/O chips may also contain sensors. We have to write to
standard I/O ports to probe them. This is usually safe.
Do you want to scan for Super I/O sensors? (YES/no):
Probing for Super-I/O at 0x2e/0x2f
Trying family `National Semiconductor'...                  No
Trying family `SMSC'...                                    No
Trying family `VIA/Winbond/Fintek'...                      Yes
Found `Winbond W83627HF/F/HG/G Super IO Sensors'            Success!
    (address 0x295, driver `w83627hf')
Probing for Super-I/O at 0x4e/0x4f
Trying family `VIA/Winbond/Fintek'...                      No
Trying family `ITE'...                                      No
Some south bridges, CPUs or memory controllers may also contain
embedded sensors. Do you want to scan for them? (YES/no):
Silicon Integrated Systems SIS5595...                      No
VIA VT82C686 Integrated Sensors...                          No
VIA VT8231 Integrated Sensors...                            No
AMD K8 thermal sensors...                                  No
AMD K10 thermal sensors...                                  No
Intel Core family thermal sensor...                        Success!
    (driver `coretemp')
Intel AMB FB-DIMM thermal sensor...                        No
VIA C7 thermal and voltage sensors...                      No
Now follows a summary of the probes I have just done.
Just press ENTER to continue:
Driver `ipmisensors' (should be inserted):
  Detects correctly:
  * ISA bus, address 0xca0
    Chip `IPMI BMC KCS' (confidence: 4)
Driver `w83627hf' (should be inserted):
  Detects correctly:
  * ISA bus, address 0x295
    Chip `Winbond W83627HF/F/HG/G Super IO Sensors' (confidence: 9)
Driver `coretemp' (should be inserted):
  Detects correctly:
  * Chip `Intel Core family thermal sensor' (confidence: 9)
Do you want to generate /etc/sysconfig/lm_sensors? (yes/NO): YES
Copy prog/init/lm_sensors.init to /etc/init.d/lm_sensors
for initialization at boot time.
You should now start the lm_sensors service to load the required
kernel modules.
The generated /etc/init.d/lm_sensors file looks like this.
MODULE_0=ipmi-si
MODULE_1=ipmisensors
MODULE_2=w83627hf
MODULE_3=coretemp
However, those modules can't be find and loaded. Should I get them from a Slackware distro and simply insmod them in that order?
root@tower:~# lsmod
Module                  Size  Used by
md_mod                 37868  14
xor                    12825  1 md_mod
ata_piix               17076  4
e1000e                 96516  0
sata_mv                19903  11
No, install a full Slackware dev system on that box, build the drivers needed, and TEST whether you will have pwm fan control.  No need to go on a scavenger hunt if what you are looking for won't work when you find it.
Yeah, install a full slackware as a test then run the same sensors-detect and make sure those sensors are loaded. Then test if you can control the fans. If that all works then you just need to compile a new kernel for unraid with the sensor modules for your hardware. You can follow the unraid wiki for the full slackware install to compile the kernel. Just make sure you go to the hardware sensors section in "make menuconfig" and enable those same sensor modules so they will be built (you can compile them into the kernel as an alternative but then sensors-detect will complain that they can't be found. But it should still work).
Installed full Slackware 13.0. Ran sensors-detect, it outputs in /etc/sysconfig/lm_sensors that I need following modules in that order:
ipmi-si
coretemp
w83627hf
w83793
Loaded each of them manually by calling modprobe. Ran sensors again and voila, all fans are now shown (see below for output). So it looks like this monitoring hardware is definitely supported but unRAID is looking for fans1..3 on the w83627hf-isa-0290, Adapter: ISA adapter instead on w83793-i2c-0-2f, Adapter: SMBus I801 adapter at 1100.
However, I did a find in /sys and couldn't locate any pwm?_enable files and this looks strange to me. Do I have to create them manually somehow?
fan1..3 are the three fans located on the mid fanboard of a Norco 4220 case
fan4..5 are the case fans located on the back of a Norco 4220 case
fan7 is the CPU fan
all are 4-pin PWM enabled fans
# sensors
coretemp-isa-0000
Core 0:      +46.0°C  (high = +78.0°C, crit = +100.0°C)
coretemp-isa-0001
Core 1:      +46.0°C  (high = +78.0°C, crit = +100.0°C)
w83627hf-isa-0290
in0:         +0.00 V  (min =  +1.09 V, max =  +1.50 V)   ALARM
in1:         +0.00 V  (min =  +1.09 V, max =  +1.50 V)   ALARM
in2:         +0.00 V  (min =  +2.82 V, max =  +3.79 V)   ALARM
in3:         +3.06 V  (min =  +3.82 V, max =  +4.06 V)   ALARM
in4:         +0.00 V  (min =  +3.57 V, max =  +4.02 V)   ALARM
in5:         +0.00 V  (min =  +2.54 V, max =  +1.89 V)   ALARM
in6:         +0.00 V  (min =  +3.95 V, max =  +2.03 V)   ALARM
in7:         +3.38 V  (min =  +4.00 V, max =  +4.08 V)   ALARM
in8:         +3.26 V  (min =  +4.08 V, max =  +3.82 V)   ALARM
fan1:          0 RPM  (min =    0 RPM, div = 2)
fan2:          0 RPM  (min =    0 RPM, div = 2)
fan3:          0 RPM  (min = 25000 RPM, div = 2)  ALARM
temp1:      +127.0°C  (high = +45.0°C, hyst = -69.0°C)  ALARM  sensor = thermistor
temp2:      +127.0°C  (high = +80.0°C, hyst = +75.0°C)  ALARM  sensor = thermistor
temp3:      +127.0°C  (high = +80.0°C, hyst = +75.0°C)  ALARM  sensor = thermistor
cpu0_vid:   +1.519 V
beep_enable:enabled
w83793-i2c-0-2f
VcoreA:      +1.28 V  (min =  +0.92 V, max =  +1.38 V)
VcoreB:      +1.26 V  (min =  +0.00 V, max =  +2.05 V)
in2:         +1.18 V  (min =  +0.99 V, max =  +1.33 V)
in3:         +0.50 V  (min =  +0.40 V, max =  +0.67 V)
in4:         +1.82 V  (min =  +1.62 V, max =  +1.98 V)
in5:         +3.26 V  (min =  +2.96 V, max =  +3.63 V)
in6:         +1.00 V  (min =  +0.90 V, max =  +1.10 V)
+5V:         +5.09 V  (min =  +4.64 V, max =  +5.65 V)
5VSB:        +5.09 V  (min =  +4.64 V, max =  +5.65 V)
Vbat:        +3.20 V  (min =  +2.96 V, max =  +3.63 V)
fan1:       2591 RPM  (min =  712 RPM)
fan2:       2523 RPM  (min =  712 RPM)
fan3:       2528 RPM  (min =  712 RPM)
fan4:       1802 RPM  (min =  712 RPM)
fan5:       1819 RPM  (min =  712 RPM)
fan6:          0 RPM  (min =  712 RPM)  ALARM
fan7:       1142 RPM  (min =  712 RPM)
fan8:          0 RPM  (min =  712 RPM)  ALARM
fan9:          0 RPM  (min =  712 RPM)  ALARM
fan10:         0 RPM  (min =  712 RPM)  ALARM
temp1:       +51.0°C  (high = +83.0°C, hyst = +78.0°C)  sensor = Intel PECI
temp2:      -103.0°C  (high = +83.0°C, hyst = +78.0°C)  sensor = Intel PECI
temp3:      -128.0°C  (high = +83.0°C, hyst = +78.0°C)  sensor = Intel PECI
temp4:      -128.0°C  (high = +83.0°C, hyst = +78.0°C)  sensor = Intel PECI
temp5:       +50.0°C  (high = +50.0°C, hyst = +45.0°C)  ALARM  sensor = thermistor
temp6:       +46.0°C  (high = +50.0°C, hyst = +45.0°C)  sensor = thermistor
beep_enable:disabled
# lsmod
Module                  Size  Used by
w83793                 27256  0
w83627hf               23148  0
hwmon_vid               2684  2 w83793,w83627hf
coretemp                5660  0
ipmi_si                38060  0
ipmi_msghandler        31276  1 ipmi_si
appletalk              29452  20
ipv6                  243508  12
pcmcia                 33772  0
pcmcia_core            32016  1 pcmcia
agpgart                29256  0
lp                      9316  0
ppdev                   7200  0
parport_pc             24036  0
parport                30700  3 lp,ppdev,parport_pc
fuse                   54008  1
joydev                  9504  0
evdev                   9152  3
thermal                15096  0
psmouse                41676  0
serio_raw               5024  0
i2c_i801                8784  0
sg                     24912  0
e1000e                113100  0
rtc_cmos               10124  0
rtc_core               15992  1 rtc_cmos
container               3132  0
rtc_lib                 2332  1 rtc_core
button                  5708  0
processor              38600  1 thermal
shpchp                 31888  0
thermal_sys            10756  2 thermal,processor
hwmon                   2104  4 w83793,w83627hf,coretemp,thermal_sys
Yes, I am attaching the output of pwmconfig below.
pwmconfig.txt
I found this file for the X7SBU (mine is X7SBE) and used it instead of /etc/sensors3.conf:
http://www.lm-sensors.org/wiki/Configurations/SuperMicro/X7SBU
Here the sensors output now:
# sensors
coretemp-isa-0000
Core 0:      +47.0°C  (high = +78.0°C, crit = +100.0°C)
coretemp-isa-0001
Core 1:      +44.0°C  (high = +78.0°C, crit = +100.0°C)
w83627hf-isa-0290
+5.0V:      +5.13 V  (min =  +6.42 V, max =  +6.83 V)  ALARM
cpu0_vid:  +1.519 V
beep_enable:enabled
w83793-i2c-0-2f
CPU Core:    +1.28 V  (min =  +0.92 V, max =  +1.38 V)
+1.25V:      +1.26 V  (min =  +0.00 V, max =  +2.05 V)
VTT:        +1.18 V  (min =  +0.99 V, max =  +1.33 V)
-12V:      -12.36 V  (min = -12.85 V, max = -11.46 V)
DIMM:        +1.82 V  (min =  +1.62 V, max =  +1.98 V)
+3.3V:      +3.26 V  (min =  +2.96 V, max =  +3.63 V)
+12V:      +12.00 V  (min = +10.75 V, max = +13.25 V)
+5V:        +4.94 V  (min =  +4.49 V, max =  +5.50 V)
5VSB:        +4.97 V  (min =  +4.49 V, max =  +5.50 V)
VBAT:        +3.20 V  (min =  +2.96 V, max =  +3.63 V)
disk fan1:  2591 RPM  (min =  712 RPM)
disk fan2:  2532 RPM  (min =  712 RPM)
disk fan3:  2551 RPM  (min =  712 RPM)
case fan1:  1809 RPM  (min =  712 RPM)
case fan2:  1819 RPM  (min =  712 RPM)
cpu fan:    1140 RPM  (min =  712 RPM)
CPU Temp:    +52.0°C  (high = +83.0°C, hyst = +78.0°C)  sensor = Intel PECI
Sys Temp:    +50.0°C  (high = +50.0°C, hyst = +45.0°C)  sensor = thermistor
My guess is that the mobo manufacturer either has not exposed the control interface on the chip to be software controlled, or there is something in the BIOS you need to change to enable it.
I'd e-mail tech support.
Which boards are you guys using that allow software fan speed control?
I would need 2 PCI-X slots preferable on two busses (but may theoretically change controllers to PCIe), IPMI, Intel GigE NIC, C2D 775 slot and preferably DDR2 800 ECC Memory as this is what I already have. 4 SATA ports are ok, 6 or 8 would be nice.
I have found PWM fan control that I could manipulate with software on every mobo I've tried, on at least one fan port.
You can also check the speedfan website, and review sites like SPCR, which will often report where fan speed control was possible.
Unfortunately, your requirement of  PCI-X slots, ECC memory, and IPMI greatly limits your choices.  Why do you have such odd hardware demands?
Well, I have two AOC-SAT2-MV8 PCI-X controllers but may change them against the PCI-E versions as they are also supported in unRAID and running well. May change the memory also depending on the mainboard. It's only that I already have those, but nothing stops me actually from swapping (except from loosing money).
IPMI however is almost a must as I don't want to deal with monitor and keyboard at any time. I would need at least two PCI-E slots, best would be to have three 8x PCI-E.
Intel NICs are also a must, because of performance and wake-up, etc.
Intel NICs are cheap and plentiful.  Intel NICs built into mobos are not as common.
IPMI is not very common.  Inexpensive KVM over IP boxes are easy to find.
The AOC-SAT2-MV8 works in a PCI slot, and does not have to have PCI-X.
OTOH. you can buy a 3rd party fan controller board with PWM control, and roll your own software to control it.
If you want a specialized feature, particular multiple ones, you are really limiting yourself by demanding it all come in one unified package.  Pick one (IPMI, Intel Nic, PCI-X, Fan control) that you want integrated in the mobo, then use alternatives for the other ones.
bubbaQ, thanks for your hints. Can you recommend some PWM 4-pin fan board control that is software controllable from Linux? Must be good, cost doesn't matter.
Other option would be to get a hardware fan control, one channel with control for my three fans, off in addition to three other speeds with selectable temperature should be fine. I may position the flat temp sensors between the disks in the Norco 4220 case. Would not be that precise like a software based option though.
I still haven't got a reply from Supermicro regarding how I may vary fan speed on the X7SBE.
Thanks again!
  • 2 months later...
I can confirm that the fan speed control script is working with the Supermicro X7SPA-HF-O Mini ITX mainboard!
The fan device is /sys/class/hwmon/hwmon4/device/pwm4
The modified script is attached. And don't forget to use a 4-pin PWM fan with this script.
unraid-fan-speed.sh.zip
Will this work for the SuperMicro X7SBE?
Not yet. I am at the moment giving up on this. Tested from full Linux install, even Supermicro confirmed that this won't work with the X7SBE, fans are controlled only from the BIOS.
I may connect the fans to an AMX cardframe with 3x VAIG cards (analog voltage out set to 0..12V) and make it login to unRAID and based on smart data and HDD temp, control the voltage on the fans directly. Sounds complicated but this is the best I have come up with. All other fan control solutions I have seen so far can't be controlled from scripts but are autonomous based on some temperature sensors.
I have been playing around with this script a little bit on a Supermicro X8SIL-F-O.  The fan speeds can be set through pwm2, but it would seem that the implementation has a fail safe built in.  If I try to drop the fan speed too low (100 is fine, but 50 or 0 are not), pwm2_enable goes from 1 to 4 (which is apparently automatic) and the fan speed kicks back up.  I don't think this will be too big of a deal, but was curious whether I am missing something and there is a way around this.
Edit:  It seems this is only a problem if there is a fan plugged into the first fan header.  The other 4 don't exhibit this behavior.  So likely a built in fail safe for the CPU fan.
There are many hardware solutions out there that allow fan speed control via scripts... check out:
http://www.sidewindercomputers.com/fancontrollers.html
I use the Matrix Orbital, but the T-balancer is a good choice too.
Been using this script for 5 days now with good results.  Definitely a good option for anybody using an X8SIL-F with PWM fans.  The 3 120mm deltas I replaced the 4 stock 80mm fans that came with the Norco 4220 run quieter then the other equipment in the room 80% of the time.  The other 20% has been running at the medium speed which isn't at all bad either.  It has not yet needed to kick the fans up to full.
bubbaQ, thank you very much!
I am just looking at the mCubed T-Balancer bigNG at http://www.sidewindercomputers.com/tbalancerbigng.html and I think it should do the job. Do you know if the Linux software (http://sourceforge.net/projects/xban/forums/forum/462785/topic/1271826) may be executed straight from unRaid (booted from USB, without full Slack install)? I think I am going to order it straight away...
This should be a section in the FAQ! Great find!
Matt, great info, thanks! Could you also post the device path for the fans for this board or better your updated version of the script?
The script as I have been using it is attached.  One note, it seems the X8SIL-F has a built in fail safe as mentioned in one of my previous posts.  I initially thought it was just on fan port 1, but it is in fact on all the fan ports.  If you set the fans too low, the motherboard will kick PWM back to automatic and the fans will go to full speed.  This happens pretty quickly, so it is easy to test and find out where the limit is.
You will have to excuse me as Linux is not my first language!
So, basically, I purchased a SuperMicro SC933T-R760B and a SuperMicro C2SEE-O for a new unRAID build.  The fans in in this case scream (at almost 5000rpm) all of the time.  I have tried hooking them up to the motherboard and the backplane.  All of the fans in the case are 3-wire fans.  In BIOS, there are three options: Default, 4-wire Super Quiet and 4-wire Workstation.  I have tried al three settings.  My guess is it doesn't matter since none of the fans have 4 wires.
So, my question is, where do I go from here?  Will any of the scripts on these pages slow my fans down to a more livable speed?  I suppose I could get a fan controller, but I would really prefer not to mess up this beautiful case.
Yes, I know I purchased a "server" class chassis, but this is ridiculous.  All of my HP Proliant DL-series servers (running Windows) slow the fans down after a few seconds of booting.
Thanks!
