deaerator Posted March 4, 2018 Share Posted March 4, 2018 1. Using built in dnsmasq, is it possible to add an entry to work around NAT Loopback or Split DNS 2. If I can, how do I add that entry? Link to comment
CHBMB Posted March 4, 2018 Share Posted March 4, 2018 What router have you got? It's pretty obvious you're attached to it. You sure your router doesn't support it? Link to comment
bonienl Posted March 4, 2018 Share Posted March 4, 2018 1 hour ago, deaerator said: 1. Using built in dnsmasq, is it possible to add an entry to work around NAT Loopback or Split DNS 2. If I can, how do I add that entry? The DNS service on unRAID is unaware of the public address used on the WAN interface of your router. Any hairpinning has to be done on your router. Link to comment
deaerator Posted March 4, 2018 Author Share Posted March 4, 2018 1 hour ago, CHBMB said: What router have you got? It's pretty obvious you're attached to it. You sure your router doesn't support it? I have a Sagecom Router (Home Hub 3000), I already asked my ISP about and they don't support it. I just didn't want to buy another router because I need the router for TV. Unless there is router that supports Fibre Optic Cable with Vlans and HPNA Network Link to comment
Caldorian Posted May 4, 2018 Share Posted May 4, 2018 On 3/4/2018 at 6:36 PM, deaerator said: I have a Sagecom Router (Home Hub 3000), I already asked my ISP about and they don't support it. I just didn't want to buy another router because I need the router for TV. Unless there is router that supports Fibre Optic Cable with Vlans and HPNA Network You find a solution for this? Considering spinning up some services myself, and I'm in your same situation (Bell Fibe customer?). Additionally, I wanted to get things entirely up and tested before I setup the port forwards on the router, so being able to do a split dns would be useful. Link to comment
deaerator Posted May 5, 2018 Author Share Posted May 5, 2018 I purchased an Edge Router X-SFP, and placed my hh3k in the closet. Link to comment
