July 11, 20197 yr 11 minutes ago, fluisterben said: The x16 slot now has a card with 3 M.2 NVME SSD's, and the manual says the x16 slot will auto-switch to x8 when that (other) x8 slot is occupied. Not sure if the ssd card is using the full x16 bandwidth. Will have to check.. This will be interesting, I guess after insert the card, 3 M.2 would only detect 2 instead 3. ( You may verify by insert any PCIe card ) Edited July 11, 20197 yr by Benson
July 11, 20197 yr 9 minutes ago, Benson said: This will be interesting, I guess after insert the card, 3 M.2 would only detect 2 instead 3. ( You may verify by insert any PCIe card ) I don't think so, the PCI-E x16 slot is already set to x8/x4/x4 mode in BIOS. Check this mail correspondence I had with ASRockrack about it; > -----Original Message----- > Subject: RE: #ULTRA QUAD M.2 CARD# compatibility motherboard > > Hello, > >> My colleague from ASRock Rack borrowed me an E3C246D4U. >> The bifurcation settings that are available for the PCIe 3.0 x16 slot are: >> X16 >> X8/x8 >> X8/x4/x4 >> >> As far as I can tell, the C246 chipset does not support x4/x4/x4/x4. > > Is this not fixable by a workaround in BIOS? > Or truly a strict limitation of the hardware for C246 ? > >> I tested with an Ultra Quad M.2 Card on this motherboard, filled with >> 4 NVME >> M.2 SSDs. >> >> Set PCIE6 Link Width to x8/x4/x4. >> >> As expected, 3 out of 4 SSDs were detected (sockets M2_1, M2_3 and >> M2_4 on the Ultra Quad M.2 Card). > > OK, so I can run 3 of the 4 slots. At least that's something. > I was not aware of such strange limitations for a very current Intel chipset. > I truly don't understand these manufacturers of chipsets. > Why would you create support for x8/x4/x4, but not x4/x4/x4/x4 ? > Seems to me that's just some strange management decision, not an > actual hardware limitation. > > But hey, thanks a lot for this valuable info! > > Regards, Hello, I would think it is an artificial limitation built into the chipset/CPU, to differentiate between different price ranges/classes. To be sure I have asked ASRock Rack R&D to check. When I get a reply I will let you know :) Kind regards, ASRock Support
July 12, 20197 yr If bifurcation haven't 4444 option, then 1 M.2 should be detect if other slot insert a card, like a quad M.2 card can use three M.2 currently. Edited July 12, 20197 yr by Benson
July 12, 20197 yr 18 hours ago, Benson said: If bifurcation haven't 4444 option, then 1 M.2 should be detect if other slot insert a card, like a quad M.2 card can use three M.2 currently. That would be the case if it was logical division (x8 and x8 bandwidth divided over the x16 + x8 slots), but I don't think it is. I'll let y'all know what it ends up doing.
August 7, 20206 yr On 7/12/2019 at 5:11 PM, fluisterben said: That would be the case if it was logical division (x8 and x8 bandwidth divided over the x16 + x8 slots), but I don't think it is. I'll let y'all know what it ends up doing. Hi - any update on this?
