Jump to content
Help using Unraid without an array
My data needs have dropped dramatically to the point where I can really get by with two 1tb NVME drives without parity since i have regular cloud backups.
If I want to use unRAID for its fantastic gui, docker implementation, and plugs-ins, but not for array/parity is there a good way to accomplish this?
My initial thought is to setup both of the NVMEs as unassigned devices with share turned on and then move docker to the /mnt/disks/NVME.
But any suggestions or traps i'm missing by moving to this setup would be greatly appreciated.
Edited by veritas2884
Link to comment
Best bet would be to grab a spare HDD, or even a USB and make that the 'array' (also disable mover etc).
Then put your two drives into a btrfs cache pool (raid1 or raid0), that way TRIM is still supported and everything else is 'out of the box' functionality.
Edited by tjb_altf4
  • Like 1
Link to comment
  Only 75 emoji are allowed.
  • Create New...
