Gothix Posted July 29, 2021 Share Posted July 29, 2021 (edited) Firefox browser said it needed a restart, so i closed it and now i cant get bk into the GUI or access the server in any way other than through the command prompt. i tried to restart and a full shutdown even pulled the discs to make sure it wasn't the vm starting and nothing. its IP shows up in my network but none of the SMB shares are just empty. i can access everything else from the web on unraid im writing this on it now. But I can't access unraid in any way not in the command. when unraid starts it pops up Firefox window with: Unable to connect Firefox can’t establish a connection to the server at localhost. The site could be temporarily unavailable or too busy. Try again in a few moments. If you are unable to load any pages, check your computer’s network connection. If your computer or network is protected by a firewall or proxy, make sure that Firefox is permitted to access the Web. as does it from all other computers. stores.r.us-diagnostics-20210729-1330.zip Edited July 30, 2021 by Gothix added stuff Quote Link to comment
Gothix Posted July 30, 2021 Author Share Posted July 30, 2021 It is some sort of settings issue really wish somebody would respond to either of my help requests....... Quote Link to comment
Squid Posted July 30, 2021 Share Posted July 30, 2021 Delete the contents of /config/ssh and /config/ssl on the flash drive and reboot Quote Link to comment
Gothix Posted July 30, 2021 Author Share Posted July 30, 2021 3 hours ago, Squid said: Delete the contents of /config/ssh and /config/ssl on the flash drive and reboot Thank you going to try this now Quote Link to comment
Gothix Posted July 30, 2021 Author Share Posted July 30, 2021 10 minutes ago, Gothix said: Thank you going to try this now Omg thank you it works Quote Link to comment
Gothix Posted July 30, 2021 Author Share Posted July 30, 2021 Is there anything I need to do before starting the system up? Quote Link to comment
trurl Posted July 30, 2021 Share Posted July 30, 2021 You mentioned using a new install on that other thread. 5 minutes ago, Gothix said: Is there anything I need to do before starting the system up? Is this the original install or a new one? Quote Link to comment
Gothix Posted July 30, 2021 Author Share Posted July 30, 2021 6 minutes ago, trurl said: You mentioned using a new install on that other thread. Is this the original install or a new one? This is the original with the SSH and SSL folders removed it's up and running but I have not started the array yet Quote Link to comment
trurl Posted July 30, 2021 Share Posted July 30, 2021 If your disk assignments are correct start the array. Quote Link to comment
Gothix Posted July 30, 2021 Author Share Posted July 30, 2021 2 minutes ago, trurl said: If your disk assignments are correct start the array. Everything started up I'm not sure if everything's working fine seems to be. Is there anybody who can tell me what I broke so I don't break it again Quote Link to comment
trurl Posted July 30, 2021 Share Posted July 30, 2021 Make sure you keep a current backup of flash. You can download a zipped backup at Main - Boot Device - Flash - Flash Backup or use the My Servers plugin to backup to Limetech cloud. Quote Link to comment
DrLucasMendes Posted August 6, 2021 Share Posted August 6, 2021 I had the same problem when I added a nvme in my system. In my case, I found out that Unassigned Devices plugins were messing up something and not letting the Web GUI boot. I access ssh (ssh root@SERVERIP) I manually delete them in the flashdrive rm /boot/config/plugins/unassigned.devices/* rmdir /boot/config/plugins/unassigned.devices rm /boot/config/plugins/unassigned.devices-plus/* rmdir /boot/config/plugins/unassigned.devices-plus rm /boot/config/plugins/unassigned.device* I also had to manually delete all removed plugins too before re-instaling the Unassigned devices back. rm /boot/config/plugins-removed/* After it, I reboot the system. It came back to normal and I reinstalled the Unassigned devices plugins back. I hope it helps. All the best, Lucas Quote Link to comment
