Help - Read-Check will take 176 Days to complete.
Aug  6 15:36:17 Tower kernel: XFS (md1): Mounting V5 Filesystem
Aug  6 15:36:17 Tower kernel: XFS (md1): Starting recovery (logdev: internal)
Aug  6 15:36:17 Tower kernel: XFS (md1): Ending recovery (logdev: internal)
Aug  6 15:36:17 Tower kernel: ata9.00: exception Emask 0x10 SAct 0x400000 SErr 0x190002 action 0xe frozen
Aug  6 15:36:17 Tower kernel: ata9.00: irq_stat 0x80400000, PHY RDY changed
Aug  6 15:36:17 Tower kernel: ata9: SError: { RecovComm PHYRdyChg 10B8B Dispar }
Aug  6 15:36:17 Tower kernel: ata9.00: failed command: READ FPDMA QUEUED
Aug  6 15:36:17 Tower kernel: ata9.00: cmd 60/08:b0:b8:47:5c/00:00:07:00:00/40 tag 22 ncq dma 4096 in
Aug  6 15:36:17 Tower kernel:         res 40/00:b0:b8:47:5c/00:00:07:00:00/40 Emask 0x10 (ATA bus error)
Aug  6 15:36:17 Tower kernel: ata9.00: status: { DRDY }
Aug  6 15:36:17 Tower kernel: ata9: hard resetting link
Aug  6 15:36:24 Tower kernel: ata6: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Aug  6 15:36:24 Tower kernel: ata6.00: configured for UDMA/133
Aug  6 15:36:27 Tower kernel: ata9: softreset failed (1st FIS failed)
Aug  6 15:36:27 Tower kernel: ata9: hard resetting link
Aug  6 15:36:33 Tower kernel: ata9: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Aug  6 15:36:33 Tower kernel: ata9.00: configured for UDMA/133
Aug  6 15:36:33 Tower kernel: ata9: EH complete
  • Replies 163
  • Views 9.8k
[6:0:0:0]    disk    ATA      WDC WD40EFAX-68J 0A83  /dev/sdg   /dev/sg6
  state=running queue_depth=32 scsi_level=6 type=0 device_blocked=0 timeout=30
  dir: /sys/bus/scsi/devices/6:0:0:0  [/sys/devices/pci0000:00/0000:00:17.0/ata6/host6/target6:0:0/6:0:0:0]
[9:0:0:0]    disk    ATA      OOS12000G        OOS1  /dev/sdj   /dev/sg9
  dir: /sys/bus/scsi/devices/9:0:0:0  [/sys/devices/pci0000:00/0000:00:1b.0/0000:01:00.0/ata9/host9/target9:0:0/9:0:0:0]
[10:0:0:0]   disk    ATA      WDC WD40EFAX-68J 0A83  /dev/sdk   /dev/sg10
  dir: /sys/bus/scsi/devices/10:0:0:0  [/sys/devices/pci0000:00/0000:00:1b.0/0000:01:00.0/ata10/host10/target10:0:0/10:0:0:0]
00:17.0 SATA controller [0106]: Intel Corporation 400 Series Chipset Family SATA AHCI Controller [8086:a382]
	DeviceName: Onboard - SATA
	Subsystem: ASUSTeK Computer Inc. Device [1043:8694]
01:00.0 SATA controller [0106]: Marvell Technology Group Ltd. 88SE9215 PCIe 2.0 x1 4-port SATA 6 Gb/s Controller [1b4b:9215] (rev 11)
	Subsystem: Marvell Technology Group Ltd. 88SE9215 PCIe 2.0 x1 4-port SATA 6 Gb/s Controller [1b4b:9215]
02:00.0 SATA controller [0106]: Marvell Technology Group Ltd. 88SE9215 PCIe 2.0 x1 4-port SATA 6 Gb/s Controller [1b4b:9215] (rev 11)
Is it showing anything concerning?
I think this all means disk1 is on the Intel controller, and disks 5 and 9 are on the 1st Marvell controller. So maybe their problems are unrelated.
And you are still having connection problems on disk9
Looks ok for now
Since all disks are read to emulate disk1, lets leave that one for later.
Check filesystem on disk9. Be sure to capture the output so you can post it.
ok
How do I capture the output? Just screen capture?
Might not fit in one screenshot. Try copy/paste
Are you running this from webUI with -n?
Yes
I'm surprised there was that much from a mountable disk.
Start array in Normal mode (no rebooting) and post new diagnostics.
