Help - Read-Check will take 176 Days to complete.
 PCIE 3.0 X4 to 6-Ports Serial ATA/SATA 3.0 Host Controller, Plug and Play on Windows OS, MAC OS, and Linux Kernel Systems-6X 6Gbps Max SATA 3.0 None Raid Ports-Support AHCI Boot Up (PCE-G3S6)
  • Replies 163
  • Views 9.8k
Yes, that is it.
This is the latest Diag. New controller card in place,
Connection problems with disk9, this controller I assume is on motherboard
00:17.0 SATA controller [0106]: Intel Corporation 400 Series Chipset Family SATA AHCI Controller [8086:a382]
	DeviceName: Onboard - SATA
	Subsystem: ASUSTeK Computer Inc. Device [1043:8694]
Yes, the new controller is a Pcie controller
Check connections disk9
I formatted disk9 and then I replaced disk1. I rebooted and let the system go through a full parity check and everything is now back to normal.
Way back on the first page
On 8/6/2022 at 1:30 PM, trurl said:
Why do you have parity2 but no parity?
On 8/6/2022 at 1:33 PM, trurl said:
And it looks like what should be your cache you have assigned as disk22 in the parity array
SSDs in the array cannot be trimmed, and can only be written at parity speed.
Do you want to get that SSD disk22 out of the array and setup as cache? Then you can reconfigure Docker for better performance and allow array disks to spin down. And since removing that disk from the array will require parity rebuild, you could change that parity2 to parity at the same time.
Sounds good. Thanks.
Not sure what you mean. Do you want to change those things or not?
